08-29-2004, 05:53 AM
#166
FreeDrive Creator
good point, I never thought of doing that.. on the cpu stats and stuff I have included a file that I use on IRC.. I'm unsure if it will be any good, but it does include a .dll which you may be able to use. Sorry if this is no good, but I think its better to mention it just incase it does help.
CdR
just added a more upto date version of moo.dll
08-29-2004, 08:33 AM
#167
FreeDrive Creator
just tried the 2nd released version of headunit (win32).. its looking good :-) I know theres still alot to do on it, but its certainly grown. I was wondering how you have mapped the volume. It doesnt seem like its mapped to master volume, when I click up/down my slider doesnt move, although the sound does increase. But my master is always set to around 10%, which means I dont start hearing music till HU is showing 60% if you know what I mean. Thats my only question at the mo.. hope the moo.dll file comes in handy, if you view one of the files with it, you can see how the dll will return values you need, from graphics cards to temps :-)
cheers
CdR
08-29-2004, 08:21 PM
#168
cdr, thanks for the moo.dll file. I'm not sure if I can use it directly without any sort of API information, but I'll look into it. Also, you're right, the volume buttons only control the "local" volume of the headunit program. I'll change it so it controls the master volume.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
08-30-2004, 01:25 AM
#169
I was playing around with it a little today and got access to the functions in the dll. Just a matter of pasting it into headunit and finding a good spot to report the info. Here's the typedef for the functions:
typedef int (__stdcall *TMooDll)(HWND,HWND,char*,char*,BOOL,BOOL);
It exports functions connection, cpuinfo, diskcapacity, gfxinfo, interfaceinfo, mbm5info, mbm5version, meminfo, netcapacity, osinfo, rambar, screeninfo, uptime and version. The char parameters are really the ones of use. The window handles are for the mirc window, first char * is for data, second is for parameters into the dll function. The return type tells you what(if any) data is valid. For example, a return of 3 means the 3rd parameter passed has data(the first char *).
I've got a VS project that reads the values from the function if you want me to pass it over. Otherwise, whoever gets to it first gets it into headunit.
The mbm5 functions are the ones dealing with the sensors on the motherboard.
08-30-2004, 05:28 AM
#170
knobby, nice work.  I just checked in some more new code into the CVS tree so you can go ahead and add in the sensor stuff if you want.
Meanwhile, I just finished adding in support for ID3 tags and album art. (Just use the link to headunit-0.2.exe in my first post to try it out). To use album art, just put a .jpg file containing the picture into the directory containing your album tracks. As long as the file end in ".jpg" it will automatically be used as the album cover. I am storing them in the database as well, so if you change an album cover, be sure to re-sync the database.
I'll try to do the video code in the next couple of days. After that, I'm going to get started on embedding iGuidance.
08-30-2004, 04:10 PM
#171
FreeDrive Creator
I will have ago at doing a skin for the motherboard sensors if you want.. I will include
connection, cpuinfo, diskcapacity, gfxinfo, interfaceinfo, mbm5info, mbm5version, meminfo, netcapacity, osinfo, rambar, screeninfo, uptime and version in it.. If this is ok, what skin would you prefer it to be in.. the brush alum one maybe ? also in the skin config file, are you using the L01 as the index (unsure if this is the right word) or you using ie. 'time' ?
cheers
CdR
08-30-2004, 05:40 PM
#172
cheers
CdR
Cdr, fantastic! Let's do the brush alum first, since it's the default anyway. I was thinking that since we will be adding even more features that MediaCar never supported (like sensors, XM and, so it may make more sense for us to do our own skin from scratch (unless we can get feb or more mods to consistently work with us on the new mods to their skins). Cdr, if you have skinning skills, maybe you can take over on this?
Anyway, regarding the L01 index v. "TIME" issue, it turns out that MediaCar used the latter ("TIME") so I adopted that same scheme. So, you would do something like this:
L01,xxx,yyy,www,hhh,rrr,ggg,bbb,pt,font,"TEMP","CP U Temperature"
The L01 doesn't matter, as long as it starts with an "L" and it is unique.
Also, can you add a button on the main page that takes you to the status screen? Thanks.
08-30-2004, 05:59 PM
#173
Looking forward to playing around with the latest version. Good to see you're still working on it!
08-31-2004, 01:40 AM
#174
FreeDrive Creator
will something like this do ?
08-31-2004, 08:38 PM
#175
cdr, looks great! thanks for the other skins you sent me as well. knobby or I will try to work on integrating the satus info asap.
rgardjr, thanks. good to see there is still interest...
09-01-2004, 10:28 AM
#176
I could not get through the db sync, it crashed every time. here's what I did every time it crashed i deleted the folder that was being added to the db until it made it through db build. I think its because of duplicate files. I have complete albums so a song may be on more than one album, but its still the same artist/song.
Also the player doesnt play music, I can browse and queue, but not play.
09-01-2004, 02:07 PM
#177
Head Unit Distribution
Hey just wanted to know if there had been a distribution started. I saw talks of one but nothing stated where to find it. The reason that I asked is that I have started on my CarPC and have completed building LFS. I am also pretty good at linux bash scripting, and splicing things together and would liket to help create a distribution for this.
Thanks,
Benjamin Pierce
I didn't turn my back on my country, my country turned it's back on me.
09-01-2004, 05:54 PM
#178
More mods, can you send me a list of the files in the bad directory? Duplicate files shouldn't be a problem. Try deleting the headunit.db file as well before you sync (in case it was there from a previous version).
Regarding the playback, did you try turning the volume up? The default is set to 50% when you first run the program and it is very quiet. Were you able to play songs using an older version of headunit?
09-01-2004, 06:01 PM
#179
Thanks,
Benjamin Pierce
Benjamin,
Pudge was going to look into this, but I think he's been pretty busy lately with other things. If you could try to put something together that contained qt, sqlite, xine, alsa, id3lib and headunit (plus all their dependencies), that would be fantastic! We would need to provide an option during installation of what hardware is in your setup to keep the installed drivers to a minimum.
09-01-2004, 07:00 PM
#180
I'm running into the same problem. It will crash at number 23 when it builds the db. If I change the directory to single album it will build the db and I can browse the songs, but it won't play the music. Turning volume up doesn't help in may case. The song doesn't get played-I see a dos command window that states: open failed: d:\\mp3\\a perfect circle\thirteenth step\\01-The Package.mp3 The previous version of headunit ran on this pc. Hope this is of some help.
| Thread Tools |
| Display Modes |
Linear Mode
