09-23-2004, 09:01 AM
#211
I think initially I want to start with a standard installation (other than the kernel). I was going to go with Xfree, even though it is a little bloated, because of the support for accelerated video for the CLE266 (A large percentage of people on these boards use this chipset). I wasn't aware that microwindows had that support, but I will look into it. I had looked into busybox, but there was some functionality missing that I wanted to use. I don't remember what it was but I will investigate using this. For GPS, what about using some of the linux GPS software out there. I know that turn-by-turn is still missing, but for person's in the US, Roadmap is able to be compiled with QT and therefore would not need to have any more dependancies installed. It also has address location built in.
This is just a few of my thoughts but input is deffinately welcome.
I didn't turn my back on my country, my country turned it's back on me.
09-23-2004, 09:32 AM
#212
VENDOR - SpatialMinds
I am running it with X and no window manager at all. Since it is a full screen app, the window manager isn't really needed.
--Craig
09-23-2004, 01:15 PM
#213
You may want to take a look at my PyCar ISO image I built. It is based upon the DirectFB( HW accelerated FB ), it uses kernel with built in drivers+ busybox. The whole thing without Python and PyCar takes about 5Mb. I'm working on installation CD atm so people can install it on their EPIA-M in 2-3 mins.
https://sourceforge.net/project/show...ckage_id=89980
09-23-2004, 01:25 PM
#214
Slower EPIA M10000
Hi!
Just to share something with M10000 owners, especially those using linux 2.6.8.1: My beloved EPIA get extremly slow without any explanation under certain circumstances. Because it was from time to time I did not relate the problem to the kernel after I updated it. After I checked in the BIOS if everything was OK and did extensive test, I reboot on a 2.4 kernel. Problems gone. It seems via82cxx module is faulty. It also seems a patch is on his way and will be included in kernel 2.6.9! Phew! I breath better now! :-D
Anyway, Infomap navigator 4 was suffering from this bug, and now it is almost as fast as my 1.6 P4 laptop both under linux/windows. Also I heard they were working actively on a touchscreen interface at infomap, that may be available within few months, for PCs for both Linux/Windows also using Qt (not PDA yet).
Herve
09-23-2004, 05:49 PM
#215
On second thought, I think you are right about going with Xfree (do the CLE266 drivers work with X.org?) for the driver support. I'm pretty sure that Nano-X does not support these drivers. BTW, Via has also released framebuffer drivers for the CLE266 so we shouldn't rule out FB support just yet.
I know about the Roadmap software, but I've been spoiled by iGuidance and I don't think I'd be able to settle for anything less. We could of course make it an option...
Good point!
jbors, i checked out your iso image. Nice work... very clean.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
09-23-2004, 09:28 PM
#216
Seg faults after upgrading to xine-lib-1_rc6
Hi folks,
So I emerged xine-lib-1_rc6 (man does gentoo make it easy to do updates) and headunit gives me segmentation faults when I try to run it. Tried a fresh cvs download and compile of headunit and found that I can make it through the database sync ok, but the application still segfaults when it comes time to bring up the headunit display. I've since reinstalled xine-lib-1_rc5-r3 and things are working again. Anyone else have this experience?
Herve,
I'm runnung a 2.6.8.1 kernel and I can't say I've really noticed any slowdowns... then again, all i'm really doing with my epiam10k is web surfing sampling carpc software for my upcoming install.
-momanz
09-24-2004, 03:02 PM
#217
Looks like infomap is also coming out with NorthAmerican maps. I emailed them to ask about starting on a US port and here is the reply:
"Benjamin,
We are already working on US and Canada map data - we hope to release
this in october/november.
Regards
Tomas"
09-27-2004, 01:40 AM
#218
Headunit is coming along nicely. It's actually motivated me some more to work on finishing my carpc. Had a few questions about possible features in the future:
Will it be able to play DVDs off of the hard drive? (or can it now and I just missed it?)
What about playing from cd/dvd images? (iso/bin/...)
Another thought (that I haven't messed with) is will it be possible (or is it now) to remove the volume controls by option? Or can that be done through skinning? I plan on running through my alpine headunit so I have a seperate sub control and a physical volume knob (incase the computer locks or something). I don't want people getting into my car and messing with the PC volume and the alpine volume.
Just thoughts and some Q's. It looking good though!
-Hex
09-28-2004, 08:06 AM
#219
Hex,
I am using the xine library as a backend for the audio, video and DVD. So, you can play .VOB files through the Video playback screen like any other video file. But, I'm not sure if Xine will play an entire DVD w/ menus, etc. straight from the harddrive. I'll have to look into this... Personally, I convert my DVDs to DivX format since the resulting files are smaller and the quality is the almost the same.
I'm pretty sure that Xine will not let you play from CD images either... Have you looked into ripping your CDs using FLAC compression? It's a lossless compression format for audio that results in files that are half the size of the original.
I know this doesn't help you, but it's probably going to be a lot of work to implement direct playback of CD and DVD images. I'm probably going to work on more critical issues initially.
Thanks for the positive comments though!
In other news, I'm looking into replacing the bloated Qt library with OpenGUI ( http://www.tutok.sk/fastgl/). It's extremely fast and lightweight. And it works with X11, framebuffer, and Win32.
09-28-2004, 09:42 PM
#220
well I would go for divx as well... but since the majority (if only) DVDs on the hard drive will be music DVDs. So I will have to go through the menus to get to the different videos. I'm to lazy to rip each chapter individually.
Once the apps section works maybe I can use a 3rd party linux app to open the .iso or DVD files for the movies.
All my music is in 192kbps mp3, actually using headunit for that now in my room  .
10-04-2004, 04:17 PM
#221
I personally think you should stick with QT. There are more QT developers out there, which will increase the chance that others will want to contribute to the project.
Why do you want to go to a lighter framework? Is QT a memory hog or causing you other performance problems?
--Craig
10-04-2004, 07:22 PM
#222
Super Moderator
from my experiences with QT, with is only about 5 months. The only issue i see with modern computers is load time of the application
'98 Explorer Sport
80% done
10-05-2004, 04:01 PM
#223
Yeah, the library is close to 6MB in size. It eats a lot of memory and takes a while to load. Also, the bitmaps flicker and the playlist scroller is a little slow in windows.
I really love Qt and if I can find a good solution to the load time problem, I would prefer to keep using it. However, on my machine it takes more than 10 seconds to load HeadUnit. If you add to that the startup time for X-windows and the boot up of the PC, it gets to be close to 30 seconds for me from power-up to hearing music. For me, that's not acceptable. I spent a lot of effort to get my linux boot time down to around 15 seconds from cold-start to the end of X-windows loading. The extra 10 seconds just for loading what should be a simple UI app (HeadUnit) is killing me.
However, I haven't spent much time getting down to the exact cause of the long boot time. It may turn out to be something non-Qt related (like sqlite or the large skin images). If that's the case (which I hope it is) then it can probably be fixed...
10-10-2004, 10:39 PM
#224
this is a great software. excellent.
i'll try it on my car pc system.
question:
which GPS software can you use on this interface?
i was thinking of using gpsdrive .
10-11-2004, 12:49 PM
#225
I still haven't gotten around to integrating GPS or external apps yet, but gpsdrive seems like a decent option. The other possiblity is running Wine and use windows software like iGuidance, Destinator, etc... I'll try to get external app support in soon... sorry, i'be been really busy with school lately.
| Thread Tools |
| Display Modes |
Linear Mode
