Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Other Cool Front Ends
Old 07-02-2004, 04:18 PM   #16
NoPistonPC's Avatar
NoPistonPC is on a distinguished road
Quote: Originally Posted by stevieg
Hiya, glad to see you're getting along well with it
Got a question!!!!
Will it support an External App/GPS App so (as you tested before) I can make/use a windows app such as destinator/ app in MapPoint control?
That's the plan. In the best case, it will run inside an embedded window, and in the worst case, it will just launch the GPS app in its own window.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
NoPistonPC is offline   Reply With Quote
Old 07-02-2004, 04:24 PM   #17
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
Cool, It would be great to be able to, in a transition period be able to utilise some of the little custom apps I've written on the new car pc, and make sure the missus still understands how to use the system
Also what do you think about having an http interface (or some kind of socket interface) for controlling the software from shell scripts and the like that I can fire off from other parts of the system?
EDIT: also just like to say I'm not a fan of X, so FB support would sell it to me!!!!!
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 07-02-2004, 04:36 PM   #18
mobileh1's Avatar
mobileh1 is on a distinguished road
NoPiston
I got the files over CVS, but theres no checked in makefile. Was this an oversight or should I make one up?
.//Daren
(Epia M10000/C134) (C137/MII 10000) Liliput /Opus 150W/DVD/512MB/80GB/Hummer H1
MediaCar/CoPilot7/Routis
mobileh1 is offline   Reply With Quote
Old 07-02-2004, 04:38 PM   #19
mobileh1's Avatar
Forget it! My error. duh!
.//Daren
Old 07-02-2004, 05:19 PM   #20
mobileh1's Avatar
NoPiston
Got it all compiled and running now. One correction to the INSTALL file, it says it s ok to use paths that contain ~ in the headunitrc.
These dont work, they are not expanded (because the shell does that).
So
~daren/mp3car/headunit ***isnt*** valid, but:
/home/daren/mp3car/headunit ***IS*** valid
Hope this helps a little
.//Daren
Old 07-02-2004, 06:23 PM   #21
NoPistonPC's Avatar
mobileh1,
I'm glad to hear you got it running! Thanks for pointing out the "~" issue, i'll modify the INSTALL file. There are plenty of bugs to fix right now. Some important ones:
* when one file stops playing, the next one doesn't start
* no fast forward, rewind
* double clicking on a file in the playlist doesn't play it
* DVD playback screen doesn't register mouse clicks
* Some files cause the database initialization to hang (probably have to check for bad characters in filename or something)
If you think you can help me fix these bugs, let me know and I'll give you write permission to the CVS tree.
stevieg, I'll work on getting framebuffer working as soon as I get some free time. But I agree with you, it is a much better alternative to running a full blown X server.
Old 07-02-2004, 06:30 PM   #22
NoPistonPC's Avatar
Just to verify that the skinning code works correctly, I tried out more mods' Alpine skin. I have to fix the font code so that they are loaded properly, but here is a screenshot:
Old 07-02-2004, 07:14 PM   #23
[iG] is on a distinguished road
Wow, good stuff. If this really gets off the ground I might even switch to a linux distro as well.
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Old 07-02-2004, 07:23 PM   #24
yunusyu's Avatar
yunusyu is on a distinguished road
NoPistonPC, What are plannign to name this software ?
Thanks for DESTIN
DICE Los Angeles
yunusyu is offline   Reply With Quote
Old 07-02-2004, 07:25 PM   #25
yunusyu's Avatar
Is this program set to be called xCar?
DICE Los Angeles
Old 07-02-2004, 07:50 PM   #26
more mods's Avatar
more mods
thanks
more mods is offline   Reply With Quote
Old 07-03-2004, 12:04 PM   #27
Phat Boy
Pudge's Avatar
Pudge is on a distinguished road
Sweet deal man, I was going to test it out with College Linux on my other partition, but none of the mirrors have your file on them yet. Can't wait.
Got the CVS , I'll fiddle with it later and let you know.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Pudge is offline   Reply With Quote
Old 07-03-2004, 01:27 PM   #28
NoPistonPC's Avatar
yunusyu, i haven't put much thought into it, but for now, it's called "headunit". If anyone has any better ideas, let me know...
pudge, i'm very interested to know if it compiles on your distro. i think as long as you have the latest qt, xine-lib and sqlite libraries, it should work. make sure you read the INSTALL file.
Old 07-03-2004, 02:12 PM   #29
Phat Boy
Pudge's Avatar
I'm installing QT as I speak, and SQLite and xine are next. I'll let you know.
edit:: QT takes a longggg time to make. Also, I saw your avatar and didn't get , and I just noticed you have an RX-7 lol.
2 Kicker Comp 10"
Check it out?!
Old 07-03-2004, 03:32 PM   #30
NoPistonPC's Avatar
1.3 liters of rotary power! (and one apex seal that's seen one too many detonations )
Yeah Qt is big. Did you make sure to include all the configure flags listed in the INSTALL file? The important ones are -plugin-sql-lite and -pthread. Also for xine-lib make sure you --enable-sdl. Good luck!
CarPC sound through car speakers without a headunit?, how? DSM97RS Car Audio 40 07-03-2006 06:38 AM
More Fuel to the Fire (New Frontend Software Screenshots) qjones Other Cool Front Ends 82 10-20-2005 03:38 PM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
