Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Other Cool Front Ends
Old 07-06-2004, 04:48 PM   #61
more mods's Avatar
more mods
Quote: Originally Posted by febsperanza
Psst... there may be a few more tricks up the monkey's fur
Is that trick a full screen audio browser?
more mods is offline   Reply With Quote
Old 07-06-2004, 05:54 PM   #62
NoPistonPC's Avatar
NoPistonPC is on a distinguished road
Quote: Originally Posted by Custommx3
Will the versions have the ablility to link apps to buttons on the menu page?
This is the one thing I think most people wanted on Media car.
Yup, that's easily done, but it will have to wait until the more important stuff is done (unless of course, you want to implement it yourself...hint, hint )
Quote: Originally Posted by MatrixPC
I am going with more mods on the audio/video player searchable stuff. I refer directory base like winamp, media car. I don't really like to type anything while driving. Remote control to skip a song is much usable for car environment.
MatrixPC, more mods, and Custommx3, I'm a little confused here. You guys are all having issues with having to type in part of a name to search the DB, correct? Why are you assuming that that is the only way that a DB has to be used? The user interface and how it is used to navigate through your music and video files is completely independent of the underlying DB. You can create a UI that looks just like a file browser for navigating through your music (like MediaCar), but that would run completely off a pre-generated database. The advantage of this is that you have to load all the information about a file just once. So, when you want to see a list of 500 files in a folder, you can get it instantaneously with a single SQL query instead of opening and closing 500 files just to get the artist and title of each one (or even just the filename). Operations through the OS are VERY slow compared to the DB (do you notice how you have to sit through that "Loading..." screen in MediaCar every time you go to the music screen for the first time? It's because coyote is building a mini-DB in memory each time, so even he is using a DB). The only disadvantage I can see to a DB is that you have to re-sync it each time you add files, but that is something that can easily be solved through a background daemon process that won't interfere with playback or your startup time.
Okay, having said all that, the design of Headunit is such that it would be very easy to give the user an option of pre-generating a DB or just browsing files on the fly, so don't be disheartened. You should actually try to run the current version of headunit, you will find that even with pre-generated DB, it still looks and feels much like MediaCar. That brings us to our next issue:
Quote: Originally Posted by brandon
You know, if you are planning to go the long haul with this thing, it wouldn't take much work at all to create your own mini-linux distro dedicated to your new "headunit" software. Sort of an install-and-go for people who have mini-itx or similar systems.
I think that would be nice to see. Plus if you used FB in the stead of using X.... maybe based off of debian?
Pudge also mentioned this as well. I believe the Xcar project is trying to do just this. I 100% agree that a special distro targeted towards EPIA-based mobos is the way to go and would allow a lot more people to run linux-based CarPCs. If you or anyone else has the expertise and time to do this, I will try to help out as much as I can, but unfortunately, I don't have much of either. Hopefully, the Xcar guys will release something soon.
BTW, brandon, I already tested out headunit in a FB using Qt/Embedded and it works wonderfully, so that's not a problem at all. However, we may have to go the XDirectFB route so we can get Wine programs running (like routis/destinator).
MatrixPC, to download the code, just follow the instructions posted on the first page of this thread for how to use CVS. Then read the INSTALL file that is included in the CVS tree. It will explain the packages you need. mobileh1, momanz, and Pudge (partly) have all got it running so you can also ask them for help. If you have a really old distro (RH 8 is pretty old), it may make more sense to first upgrade to Fedora Core 2 or gentoo to save yourself a lot of headaches with dependency issues. Good luck! You can always PM me.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
NoPistonPC is offline   Reply With Quote
Old 07-06-2004, 05:56 PM   #63
NoPistonPC's Avatar
Also, if you anyone wants to help with coding, documentation, testing, distro-generation, etc... please let me know. That is the whole point of open sourcing this thing.
Old 07-06-2004, 06:22 PM   #64
more mods's Avatar
more mods
My fear was that you were going to do as frodo has and try to put the browser on the audio screen. One of the key elements of my skin in the lcd2 font, and it takes a lot of space. Adding anything more than mediacar already has in the audio player would make using my skin impossible, as it is already cramed full of text.
Glad to hear you are keeping the browser, and I do understand that DB isn't always bad. I just like to browse through my music like Artist/Album/ and play everything in it, it's just like popin in a CD, instead of all that sort by artist, album, song or search, its just too much for me while I'm driving. As long as my skin will work and I can browse the directory full screen i'll be happy.
Thanks again
Old 07-06-2004, 06:54 PM   #65
NoPistonPC's Avatar
That makes a lot of sense. Thanks for explaining your reasoning.
Old 07-07-2004, 01:00 PM   #66
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
NoPiston, cool thank, I am downloading FC2 now.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 07-07-2004, 01:06 PM   #67
brandon is on a distinguished road
Maybe that is something to look at / work on in my future, as I've mentioned before I am a Debian GNU/Linux developer so I have some experience in this sort of thing. But my home life has been rather hectic as of late so I don't have much time to devote to anything anymore... plus I'm one of those people whos interests change at the drop of a hat.
I've never looked at XCar, but have looked at DashPC and really wasn't all that impressed with it.
Who knows, something like this might peak my interests though, only time will tell.
brandon is offline   Reply With Quote
Old 07-07-2004, 01:34 PM   #68
Phat Boy
Pudge's Avatar
Pudge is on a distinguished road
Matrix if you need any help getting it running in FC2, drop me an IM.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
Pudge is offline   Reply With Quote
Old 07-07-2004, 03:49 PM   #69
MySQL Error
MatrixPC's Avatar
Cool thanks guys.
What supprise me is that CF2 is part of the original RH. Man, that a long time since my last RH installed.
I have using RH since version 5, but mostly as an end user. So installing is not that hard for me. Once I get everything up, looking thru the code and maybe I can help you guys with whatever I can.
Old 07-08-2004, 07:46 AM   #70
NoPistonPC's Avatar
Windows port completed!
I finished the port of HeadUnit to Windows. So, now it is truely cross-platform
You can download the win32 binaries from the sourceforge page (but it may take a few days for the mirrors to be updated with the file). In the meantime, you can get it here:
HeadUnit (Windows Zip File)
Just unzip it to a folder and run headunit.exe. The first time you run it, it will ask to select the folder containing your music and videos and then it will build the database. NOTE: DVD support isn't fully there yet (it currently just displays the title menu).
I used DirectShow filters to do all the audio/video/DVD playback so the program requires no external apps to run.
Old 07-08-2004, 08:46 AM   #71
[iG] is on a distinguished road
o_O kick ***
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Old 07-08-2004, 08:53 AM   #72
Hmm! Just did a quick testdrive.. Few problems. I cant get any sound! The audio browser also doesnt seem to want to load the entire directory, just lets me double click on a file to add it to a list. Most buttons are blanks right now, but I'm assuming thats probably due to the fact that you just didnt have the time to port all the features .
Oh yeah, the skin screws up in some places (Ex: 3/4 of the button 'press down' while the other 1/4 remains 'up' - maybe wrong coordinates?)
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Old 07-08-2004, 09:30 AM   #73
Custommx3's Avatar
Custommx3
My top right hand button stays hilighted no matter what, volume control doesnt work either. I see there are a few buttons you havent emplimented, but its getting there!
Awsome work.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 07-08-2004, 09:58 AM   #74
cyber's Avatar
cyber is on a distinguished road
Sure, I'll take a look...I'm always looking for a reason to keep my coding skills sharp.
cyber is offline   Reply With Quote
Old 07-08-2004, 10:26 AM   #75
Marsupial's Avatar
Marsupial is on a distinguished road
MSVCP70.dll is missing...? what does that mean?
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
CarPC sound through car speakers without a headunit?, how? DSM97RS Car Audio 40 07-03-2006 07:38 AM
More Fuel to the Fire (New Frontend Software Screenshots) qjones Other Cool Front Ends 82 10-20-2005 04:38 PM
