The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Other Cool Stuff
Thread Tools Display Modes
Old 02-23-2008, 05:22 AM   #16
BrianMay's Avatar
Vehicle: 99 fiat coupe by pininfarina
My Photos: (0)
ok
I'll wait
Virando costas ao mundo
Orgulhosamente sós
Glória antiga, volta a nós!
BrianMay is offline   Reply With Quote
Sponsored Links
Old 02-23-2008, 08:20 AM   #17
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Carwings skin has been added to thread.
Post #4
Enforcer is offline   Reply With Quote
Old 03-22-2008, 04:21 AM   #18
Confusion Master
Enforcer's Avatar
My Photos: (1)
Downloads back up
Old 03-24-2008, 10:53 AM   #19
BrianMay's Avatar
My Photos: (0)
thanks
Orgulhosamente sós
Old 03-25-2008, 12:52 AM   #20
kelmk's Avatar
Vehicle: 2002 BMW 330ci vert
My Photos: (100)
How can I set this to run when my computer resumes from standby?
kelmk is offline   Reply With Quote
Sponsored Links
Old 03-25-2008, 11:13 AM   #21
Confusion Master
Enforcer's Avatar
My Photos: (1)
If you are using RoadRunner as your frontend you can set it to run with the "ONRESUME" in Exectbl.ini
Not sure if other front ends have a similar function.
I will look into adding it as a direct option for future releases.
Old 03-25-2008, 11:28 AM   #22
kelmk's Avatar
My Photos: (100)
Cool thanks
I am using FreeIce so it doesn't have this option.
The idea I had last night and what brought me to this thread was this. I want to take a picture with a webcam every time my car is started or computer comes on. Then upload it to a server. This could either be used in case my car was stolen or else it could be like an automatic pic a day system. Then I would want the webcam to record video until the correct code is punched in and upload it to a server. Is this possible?
Old 03-25-2008, 11:34 AM   #23
Confusion Master
Enforcer's Avatar
My Photos: (1)
Well the program will certainly record a video (When it does this is user settable, straight away, after a certain time or after a number of incorrect entries.)
It doesn't do a single image yet and uploading isn't available yet.
It can start another program or batch file upon incorrect code entry and a seperate one on corrct code entry, so third party programs can be used to do whatever.
I will be adding tracking ability, either through my own tracking system or by connecting to the GPSgate one.
The new version when I release it will have the ability to interface to the MS fingerprint scanner(s).
Old 03-25-2008, 11:58 AM   #24
kelmk's Avatar
My Photos: (100)
That sounds cool. I will start playing with it and see what I can get going. The only thing I wonder about is if someone steals the car why would they try to punch in a code if they don't know what it is? That's why I want it to record video right away and upload it after a set amount of time if no code is entered at all, or if an incorrect code is entered.
Or maybe I could hook the ignition into the pc and the car won't start unless the correct code is entered. Interesting.
I have a fusion brain on the way so it is definitely doable.
Old 03-25-2008, 01:14 PM   #25
Confusion Master
Enforcer's Avatar
My Photos: (1)
It can also be set to record straight away.
Old 05-10-2008, 06:27 PM   #26
Confusion Master
Enforcer's Avatar
My Photos: (1)
Updated version with the ability to use a MS Fingerprint scanner as input.
Old 05-31-2008, 08:07 PM   #27
Confusion Master
Enforcer's Avatar
My Photos: (1)
Just a teaser. (no pics though, because there is nothing really to see)
Version 1.4x will have
Automatic pop up when resuming from standby/hibernation - this can be switched off if not required.
Authentication by USB memory stick, either by inserting when code required or by being left in.
Old 06-01-2008, 11:08 PM   #28
My Photos: (0)
Any finger print scanner?
Hi Enforcer
Great work.
I'm putting my car pc project together and was a bit worried about the security side incase the car got stolen and I think this should work a charm for what I need.
Will this work with any finger print scanner, or just the Microsoft one? The MS one is pretty boring looking, but I found this one, which would look much more in place in my car.
http://www.amazon.co.uk/Digital-priv...d_sbs_ce_img_2
Keep up the good work man.
mx5boy is offline   Reply With Quote
Old 06-02-2008, 06:16 AM   #29
Confusion Master
Enforcer's Avatar
My Photos: (1)
Not sure if it will work, as I have only tested on the microsoft one.
The microsoft one comes with software which allows it to work with most software that has a password input.
I would assume that one does the same, but without having in front of me I couldn't say for sure.
Old 06-16-2008, 03:43 PM   #30
Confusion Master
Enforcer's Avatar
My Photos: (1)
Bump for new version 1.4.x
New Features for 1.4.x
Hibernate aware, will now pop up after hibernate/standby
USB Key access.
Pause Frontend at startup, resume at exit for FreeICE
Added Config program for settings.
Screenshot of config program
Sponsored Links
vB code is On
Trackbacks are Off
Need wiring help for 2005 Grand Prix. derekmac Car Audio 33 09-21-2007 09:42 PM
M-Audio with ASIO volume control mkysimes2 Road Runner 6 04-16-2007 11:25 PM
Using Access Control as a shell in XP Angelus Other Cool Stuff 2 12-23-2005 09:34 AM
AIMEE Climate Control POLL Danceheaven Software & Software Development 19 08-21-2005 06:19 AM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
