06-14-2005, 04:32 PM
#46
Para Laura
Quote: Originally Posted by xBrady
Your wish is my command. Added that option and rewrote the whole thing at the same time!
Make sure you remove any older config files you had before.
I don't understand......???
You saying is no possible?? what old config???
06-14-2005, 04:39 PM
#47
Super Moderator
Just download the new version but make sure you delete the old files like the config.xml.
Installed.
-GPSSecure- - GPS Tracking
06-14-2005, 04:41 PM
#48
Para Laura
Ohh!! OK pal thank you very much for this.....
06-14-2005, 04:44 PM
#49
Para Laura
link is down!!!
06-14-2005, 04:49 PM
#50
Super Moderator
link is down!!!
Fixed
Installed.
06-14-2005, 04:51 PM
#51
Para Laura
Got it!!  but:
The new zip doesn't have a xml config file.....
06-14-2005, 04:53 PM
#52
Para Laura
jaja never mind it work and the xml files just pop up from no where
thanks a bunch ....
06-14-2005, 05:06 PM
#53
Para Laura
X I have a little problem with opacity and size ........ I try diferent setting but noting cahnge.....
Any idea???
06-14-2005, 05:24 PM
#54
Super Moderator
Any idea???
Remember that when AltTabber2.2.exe needs to be closed and re-opened to see the change.
The order you need to change things in:
Open the setup: adjust the opacity, size, etc..
Press save.
Close the setup
Open Alt tabber.
If you then want to change something:
Close Alt tabber
open the setup; edit it; press save.
Then reopen alttabber.exe
Installed.
06-14-2005, 05:57 PM
#55
Para Laura
Nope I did the steps and still doesn,t work.......is the .DLLin version in 2.2 a diferent one? (meaning that I have to register it)
I have altt 2.1.3 in one folder and 2.2 in other and making comparations the old size,opacity and location work fine but in the new one don't.....
Thanks for the support
EDIT: I also uncheck the "allow window drag" box and as soon as I save the settings and close setup I still can drag the square everywhere.
And this is what I get when double click the XML file:
06-14-2005, 08:13 PM
#56
Super Moderator
You were right about the dragging checkbox. I fixed that problem. I can't seem to reproduce thet problem you are having with everything else though. If you go into the setup, change the location, size, or opacity, then press the save button. Then close the setup. Then open the setup back up, what is the location, size, and opacity now?
You can't just double click the xml files anymore. They use a namespace that Internet Explorer isn't familiar with. if you want to view the config.xml you have to open it with notepad.
Installed.
06-14-2005, 08:34 PM
#57
Right Click possibly????
I know that you can insert a keystroke sequence and it works great but I was wondering if it would be possible to make one of the options a right click. I do not always have a mouse plugged in and the app I use now is not as nice as yours and has no oppacity.
Thanks for the great app!!!!!
06-14-2005, 08:42 PM
#58
Super Moderator
Good question. I'll have to look into doing that.
Installed.
06-14-2005, 08:45 PM
#59
Para Laura
THe opacity,size and possition is the one I saved....
What about the .dll is a new one oris the same than the other ver??
06-14-2005, 08:46 PM
#60
Super Moderator
No, the dll is the same. You don't have to register it at all.
So, after you close the setup and opened it back up the opacity was the value that you had changed it to?
Installed.
| Thread Tools |
| Display Modes |
Linear Mode
