06-16-2005, 08:17 PM
#76
Super Moderator
Quote: Originally Posted by Noldona
Here is an idea for the closing. How about setting it up so if you click both sides together it closes the program? Then you can have the rest of the options for whatever else.
Sorry, I'm not following you on that one. How do you click two places at once?
Installed.
-GPSSecure- - GPS Tracking
#77
Super Moderator
Quote: Originally Posted by fixerofallthing
I know it has not been very long but how has that right click thing coming?????
Ya, sorry guys. I'm going out of town in a few minutes so I won't be able to work on this till Sunday or Monday.
Installed.
06-22-2005, 02:42 AM
#78
Super Moderator
Got it done. Check the first post for updates.
Installed.
06-22-2005, 04:14 PM
#79
That is PERFECT!!! This going to make using the touchscreen without a mouse sooooo much easier! Thank you so much.
06-22-2005, 04:45 PM
#80
Raw Wave
hey xbrady great program
i dled this on my 2 machines both have 2k and i get errors on minimize everything and task manager
the other functions work fine
any suggestions?
same error on both machines
Code:
************** Exception Text **************
System.InvalidCastException: Specified cast is not valid.
at a.a(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/winnt/microsoft.net/framework/v1.1.4322/mscorlib.dll
AltTabber
Assembly Version: 1.0.1998.42331
Win32 Version: 1.0.1998.42331
CodeBase: file:///D:/ALTtabber/AltTabber2.2.1.exe
CodeBase: file:///c:/winnt/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/winnt/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/winnt/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/winnt/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
nuxr_lou
Assembly Version: 0.0.0.0
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/ALTtabber/Interop.Shell32.DLL
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
06-22-2005, 05:05 PM
#81
Super Moderator
any suggestions?
Ya, the problem with the task manager is I'm just calling taskmgr.exe from c:\windows\system32\taskmgr.exe
2k has the task manager somewhere else. If you switch it to 'Open Application' and then in the box put the path to the taskmgr on Windows 2k then that will work.
The minimize all I assume doesn't work becuase of the way that shell32.dll (that is the only thing I use that dll for) works. I believe it mimics pressing the Windows key and D. If you press Windows + D on your 2k machine does it minimize everything?
Installed.
06-22-2005, 05:51 PM
#82
Raw Wave
win+ d yea your good xbrady too good lol
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
07-23-2005, 04:05 PM
#83
Any way to make it alt-tab to specific windows? I usually have Frodo and Copilot open, but in order to use my steering wheel controls, a 3rd windows gets opened/put on the task bar. When I alt-tab, I'd rather not have to do it twice to get past the str whl control window. For instance, the left-click could be Frodo, and the right-click could be Copilot.
07-25-2005, 02:15 AM
#84
Hey, I am trying to have Alt Tabber send a keystroke. I have is all set up right in Setting.
Send Keystroke >>>Keystroke: F12
i am trying to have it send F12 but it doesnt work. Am I doing something wrong?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-25-2005, 02:52 AM
#85
Super Moderator
http://www.mp3car.com/vbulletin/show...7&postcount=27
That is where it tells you how to use the special keys. So it should be {F12}. Let me know if that works.
Installed.
07-25-2005, 02:53 AM
#86
Super Moderator
I'm trying to think of how to impliment that idea. I'll get back to you on that.
Installed.
07-25-2005, 11:19 AM
#87
I tried doing that, but it doesnt work. The F12 hotkey is suppsed to open up this magnifying utility. But when I click on the slected area it just minimizes my the screens. And yes i have it set to "Send keystroke"
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-25-2005, 11:55 AM
#88
Thanks xBrady
07-25-2005, 03:16 PM
#89
Super Moderator
Hmm, can you post a copy of your config file? Just open it up in notepad and paste it here.
Installed.
07-25-2005, 03:24 PM
#90
Here ya go:
<?xml version="1.0" encoding="utf-16"?>
<b xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" a="537" b="568" c="60" d="30" e="1.00" f="true" g="" h="" i="Send Keystroke" j="{F12}" k="" l="Do Nothing" m="" n="" o="Do Nothing" p="" q="" r="Do Nothing" s="" t="" />
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
| Thread Tools |
| Display Modes |
Linear Mode
