07-26-2005, 05:10 AM
#91
Super Moderator
Quote: Originally Posted by Cheekz185
Here ya go:
<?xml version="1.0" encoding="utf-16"?>
<b xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" a="537" b="568" c="60" d="30" e="1.00" f="true" g="" h="" i="Send Keystroke" j="{F12}" k="" l="Do Nothing" m="" n="" o="Do Nothing" p="" q="" r="Do Nothing" s="" t="" />
Try setting each of the four options to that keystroke and see if you get anything. What type of application are you trying to send the keystroke to? Is it something running in the systray? If so then that may be the problem. Let me know if it is.
Installed.
-GPSSecure- - GPS Tracking
07-26-2005, 10:33 AM
#92
Yea it is something running in the sys tray. IT is an app called gZoomHotKey, made by Marvin/033l. And i also tried setting everything to {F12} and still nothing. But i got a fix. I made an autoit script to press F12. SO in alt Tabber i just have it "open application" and it opens the script.
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-26-2005, 03:40 PM
#93
Super Moderator
Ya, the problem with applications running in the systray is they never gain focus. So what the sendkey command does is it will send the key at whatever program has focus. So the way I have it coded is when you press alttabber alttabber will gain focus so then alttabber alt-tabs once to give the last application focus and then it sends the key to the app that had focus before alt-tabber. I don't know how to send a key (haven't looked into it) globally like your keyboard does.
Nice fix though!
Installed.
07-26-2005, 03:46 PM
#94
Yeah I am glad i got that working, its a really cool program, I have it fixed on top of CF disconnect button so you cant even see it. Just gotta hit the left/right on the disconnect button and it does whatever.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
08-17-2005, 04:37 PM
#95
This looks like a great program but the link appears dead. Can someone help.
08-17-2005, 06:59 PM
#96
Super Moderator
So host 2 of 4 is now down. Here try this one, the link is ugly but it works:
s91409509.onlinehome.us/AltTabber2.2.zip
Installed.
09-06-2005, 09:30 PM
#97
Registered User
Love your program, pretty much the only way I can use CoPilot with my frontend
Is there anyway for me to send the keystroke WinKey + D
Ive also created another mirror for you
http://www.dwoloz.com/AltTabber2.2.1.zip
09-06-2005, 10:37 PM
#98
Super Moderator
Good to hear you like it
Unfortunetly there isn't a way to simulate the Winkey because it is a special key. But that keystroke shows the desktop right? If so there is already an option in the list that will do that if you are using Windows XP. Let me know.
Thanks for setting up that mirror. Always good to have another download spot!
Installed.
09-07-2005, 01:26 AM
#99
Registered User
I tried that option and it doesnt work the same as winkey + D
I run Centrafuse and if you use the option in your program Centrafuse doesnt minimize but if you use winkey D it minimizes
09-07-2005, 03:55 AM
#100
Super Moderator
Updated with version 2.2.2. This one mimicks the Winkey + D exactly now. Plus you don't need that shell32.dll anymore because the old way I was doing it used that .dll.
Installed.
09-07-2005, 04:01 AM
#101
Registered User
I dont mean to be forward but I would like to have your children
Seriously though, thanks
09-07-2005, 04:02 AM
#102
Super Moderator
lol
No problem. Let me know if you want any other changes.
Installed.
09-07-2005, 04:08 AM
#103
Registered User
Cant seem to get this new version working
Everytime I get this message (even after the config file is created and everything)
Error
Failed to load config file. Loading with default settings.
OK
09-07-2005, 04:09 AM
#104
Super Moderator
Just realized I uploaded the wrong file. Try the download again.
Installed.
09-07-2005, 04:12 AM
#105
Registered User
It works woohoo
| Thread Tools |
| Display Modes |
Linear Mode
