05-29-2005, 01:47 PM
#16
Great Concept
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
05-29-2005, 01:52 PM
#17
Phone Control Moderator
05-30-2005, 04:36 PM
#18
Update!
Upon a improvident comment of Brave (  ), I've added a new feature that will collect all input and lookup for matching words in a dictionary.
If you're using a touch screen, this will improve the input a lot.
Since a dictionary is plain text, you can easily edit and expand it to adapt it to your needs.
To enable this feature, place the filename of the dictionary file within tag <Dictionary>. By default the list shows only 5 entries but you can alter this setting by setting <MaxDictionaryList> to any number.
05-30-2005, 05:47 PM
#19
LOL
it rocks
BraveCar 2.5
06-01-2005, 04:08 PM
#20
Update!
MWI now also supports task switching too:
Let's see, who's the first to figure out how it works
06-01-2005, 04:21 PM
#21
WOW, handy app! I might have to change my configuration to include this utility
Click the object or upper right to toggle task switching?
06-01-2005, 04:29 PM
#22
Right... you win... you can downoad it for free
(the upper left corner will switch to this mode immedeately)
06-01-2005, 05:23 PM
#23
Banned
Quote: Originally Posted by zorro
Pity I don't have a docking station for it... it'll be more comfy removing it.
You might be interested in this:
http://www.engadget.com/entry/1234000233044800/
One USB plug would connect EVERYTHING (including VGA).
06-01-2005, 05:58 PM
#24
That sounds interessting. I think I'll gonna try that.
Thx.
06-02-2005, 06:04 PM
#25
Just LOVE the Task Switching
BraveCar 2.5
06-03-2005, 02:27 PM
#26
Someone for Update?
I changed the behaviour once again and now you can use the right mouse button to switch back and forth between the dictionary list and the main WMI window, in case you're using a dictionary. If you switch to the dictionary list, scroll up and down to select the right item then press the mouse wheel for autocomplete.
Another feature: If you hold down the mouse wheel and you scroll up, you're able to erase previous inputs (scroll up and down to delete long phrases).
I also blocked any mouse wheel / right mouse messages as long as the MWI window is open.
At last, I've added a <DynamicPosition> to the configuration. Set this to true and the MWI window will popup near the current mouse cursor position.
06-05-2005, 02:31 PM
#27
Still more Update
Now with Volume Control:
Hold Down the right mouse button (as the MWI Window is not visible) and turn the wheel.
To specifiy what to control, set <ControlVolume> to either "Master", "Wave", "CD", "LineIn" (set it to "" to turn that feature off).
06-05-2005, 03:00 PM
#28
Just a suggestion, I have a tilt wheel mouse, you thinking of adding a feature for that?
06-05-2005, 03:15 PM
#29
I have one too... unfortunately, if you use the original driver, it captures mouse events and without, the tilt doesn't tilt anymore... at least, this is what I discovered on the Logitech.
BTW: What would you put on that extra buttons? I'm just curious.
06-05-2005, 03:33 PM
#30
Does it only print in caps? Or did I miss something?
FYI: You have to close the Logitech Setpoint program to get this to work. At least I did.
| Thread Tools |
| Display Modes |
Linear Mode
