Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Other Cool Stuff
Old 08-10-2005, 11:08 PM   #31
What do you mean exactly by poll?
kembond is offline   Reply With Quote
Old 08-11-2005, 08:34 AM   #32
I'm sorry, and you are....?
frodobaggins's Avatar
As in asking for the data, instead of getting events.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 08-11-2005, 09:20 AM   #33
Get new version at top.
Code:
Changelog ****** FrodoXMService.exe 1.0.0.2 --Bug Fix: ChannelChange event bug fixed. ****** FrodoXMService.exe 1.0.0.1 --Bug Fix: Out of order data in emulation mode. ****** FrodoXMService.exe 1.0.0.0 Original Release
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-11-2005, 09:08 PM   #34
entr0py's Avatar
Nice work frodo I have been playing with this in VB.Net. What do MSK.exe and RH.exe do located in the services folder?
VIA EPIA M1000
Casetronic C134
512MB, 40G Hard Drive, 8x DVD-ROM
Xenarc 700TS ULTRABRIGHT
Griffin Powermate
Jeff Bipes AUX-IN for Audi's
Opus 150W
WinXP sp2
myHTPC, VoiceMate Pro
Street Atlas 2001
entr0py is offline   Reply With Quote
Old 08-11-2005, 09:27 PM   #35
entr0py's Avatar
I am having problems getting the CurrentChannelData Event to fire. Using VB.Net 2003:
Private Sub XM_CurrentChannelData(ByVal Number As Integer, ByVal Station As String, ByVal Artist As String, ByVal Title As String, ByVal Genre As String) Handles XM.CurrentChannelData
MsgBox("Current Channel Data") 'message box does not show up
End Sub
I also tried this in your vb project as:
Private Sub MXM_CurrentChannelData(ByVal Number As Long, ByVal Station As String, ByVal Artist As String, ByVal Title As String, ByVal Genre As String)
MsgBox ("hi") 'did not fire
End Sub
Could you confirm if this is a bug or a problem with my code?
VIA EPIA M1000
Casetronic C134
Griffin Powermate
Opus 150W
WinXP sp2
Street Atlas 2001
Old 08-12-2005, 12:49 PM   #36
End Sub
End Sub
I will look, are the other events firing ?
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-12-2005, 12:50 PM   #37
They are helper applications for various functions, they must always
remain in the same directory as the service app.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-12-2005, 01:16 PM   #38
entr0py's Avatar
Is there anyway to contain them as one exe? I used Microsoft Server 2003 Resource Kit tools (svrany.exe and inssrv.exe (sp?)) to create a windows service in services in the control panel. I have not full tested it yet it seemed to work with just the FrodoXMService.exe and FrodoXMService.ini I will have to add those helper apps in the same directory and see how it functions.
Yes other events are firing, the ones I am using that are working are SignalStrength, ChannelData and CurrentTime.
Thanks for this kick a$$ service. Now I just need to get ListViews working properly in .Net, they changed there behavior compared to vb6
VIA EPIA M1000
Casetronic C134
Griffin Powermate
Opus 150W
WinXP sp2
Street Atlas 2001
Old 08-12-2005, 01:18 PM   #39
Jeep's Avatar
new to XM
Hi!
Nice work with the "Frodo XMService" Just quicly tested the client dll with C# looks like it will work just fine.
I'm new to XM radio as we don't have it over here... What XM radio recivers is "XMService" working with ?
Btw, what are the "MSK.exe" and "RH.exe" that is in the Service folder?
Jeep is offline   Reply With Quote
Old 08-12-2005, 01:23 PM   #40
To answer both your questions, here are the exact definitions of "MSK.exe" and "RH.exe"
MSK.exe - is "Make Sure Kill" It is called when the service is shutting down, in case
of an unrecovereable error, it will make sure the service terminates properly.
RH.exe - is "Restart Helper" It is called when the service is restarted, does the same
function as MSK, but also restarts the app, and some other minor checks.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-12-2005, 01:24 PM   #41
entr0py's Avatar
Read post #37
VIA EPIA M1000
Casetronic C134
Griffin Powermate
Opus 150W
WinXP sp2
Street Atlas 2001
Old 08-12-2005, 01:25 PM   #42
XM PCR, and the XM Direct/Commander.
For the Direct/Commander, you will need to build/buy a cable.
Information on this is in the Hardware Development Forum here.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 08-14-2005, 04:00 PM   #43
Beta 4 Released - Just a Bug fix, new info/links at the top.
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Old 09-12-2005, 10:05 AM   #44
IntellaWorks's Avatar
Development Question.
What sort of XM hardware does this .DLL support? or Does it interact with any driver that the XM hardware comes with?
I have no XM service (although purchasing very soon). This makes it diffacult to start designing an app (for obvious reasons). I know there's an emulation mode, which I'm going to play with.
I'm @ work here so can't play too much and its quite possible I may anwser some of my own questions later tonight when I get this thing in the .Net IDE.
I also may have missed something but could someone kindly point me to an SDK? Well, maybe I wont need an SDK once I take a look @ the VB6 project example...
My main question would be what hardware and digital radio service do you guys recommed? Thnx!
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 09-12-2005, 07:23 PM   #45
http://www.mp3car.com/vbulletin/hardware-development/41001-xm-carputer-guide.html
FrodoPlayer.com
TeaBaggins.com
[H]4 Life
I'm a lesbian too.
I am for hire!
Instructions on getting FREE wireless internet from T-Mobile using GPRS bankingdom Wireless Communications 296 Today 09:54 PM
How to use your VERIZON cell for FREE internet racerboy6996 Wireless Communications 219 07-28-2008 03:02 PM
Pre-Release Thread: Frodo XM Service frodobaggins Software & Software Development 10 08-04-2005 04:10 PM
OT: Web to mail service thenominous General MP3Car Discussion 2 01-13-2003 10:37 AM
