Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Other Cool Stuff
Old 08-27-2005, 09:09 PM   #91
anik321's Avatar
is 'restaurants' missing from anyone elses POI ? I dont see it when using iGmod, but its definitely there when I use just iguidance by itself.
99' V6 Solara SE.
'05 CBR600RR
Baltimore MD.
Shuttle XPC| 512MB | 120GB 3.5" Seagate
Opus 150W PS | Rikaline 6010 GPS
7" Lilliput 619 | Centrafuse | IGuidance 3
anik321 is offline   Reply With Quote
Old 08-27-2005, 09:49 PM   #92
Alpha4 is working pretty well, I started to make a brushmetal skin
camsgs3 is offline   Reply With Quote
Old 08-27-2005, 09:50 PM   #93
Osk....
Old 08-28-2005, 12:19 AM   #94
PURDooM's Avatar
It got moved to businesses to save menu space. You can move it around if you look at the skin.ini for a while and figure out how it does its actions in iguidance.
Badass
By the way, if anyone wants to know how to acompish something with the skinning engine, feel free to ask. I wish to start a igmod skinning FAQ soon.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 08-28-2005, 03:30 PM   #95
I just finished the BrushMetal skin, just skinned what was already there. I didnt add new icons. If i have time during the week ill do it
Anyone have a place for me to upload
Pur-can we change the font and get rid of that yellow box in the next release?
Main Menu:
Old 08-28-2005, 03:36 PM   #96
fromplanetbob's Avatar
check your PMs
Can u put the PSD files up there too?
fromplanetbob is offline   Reply With Quote
Old 08-28-2005, 03:49 PM   #97
Quote: Originally Posted by fromplanetbob
check your PMs
Just uploaded it to you, the PSD i will post too, i just have to clean them up
thanks
Old 08-28-2005, 04:37 PM   #98
PURDooM's Avatar
Ill edit the source in beta 2 release to make the program generated fonts/colors customizable. I was lazy and justified my lazyness concerning the fonts and lables with the idea that the skinners could make their own labels into images, but that really sounds like an assload of work. Instead ill make "custom styles" for the text which can include a couple effects and different background images rather than a solid color.
I also still need some of the bugs indentified people in the alpha so I can fix them before I push out beta 2. Or ill just spend a bunch of time and find them myself
Old 08-28-2005, 05:36 PM   #99
Raw Wave
justintime's Avatar
Stuff I've found in alpha 4:
1) Lots of button flickering upon initial load
2) Starts in MAIN MENU by default. why?!
3) I see a lot of flickering of iG and IGmod windows when navigating the menus. I realize what it is doing in the 'background', but this is a real fast PC! (P4 2.8 Ghz 800fsb H/T w/ 768 MB RAM)
4) Is there a delay between the time I click a button, and the time it executes? I notice a 1/2 sec delay when zooming. If I do up/down arrow instead, to bypass igMod, it is immediate.
5) When I use 'Directions', I can't see the MAP button. All I see is Navigate. Sometimes I just want it to show me the map, which iG allows!
6) There is a deadlock situation if I do... Special Detination->CityCenter-> ... and then I attempt writing the City name and clicking NEXT. All it does is popup an iG window (off screen, but I can see if because I have dual monitors) and even dismissing etc puts me in a deadlock with constant flickering between screens.
Thanks!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 08-28-2005, 05:41 PM   #100
PURDooM's Avatar
Thanks!
Explination of some minor flickering: Instead of allowing the user to actually see all the resizing business during loading and the old iguidance menus before a skinned menu, the program sees the command DOMENU in the skin file and screenshots the screen, and makes a big screenwide ontop window containing the image on the topmost window. That way when things are resizing, its all behind the window which looks just like the desktop/frontend/whatever. When this image is dropped, iguidance appears white and attempts to redraw itself. Also as a sideeffect of how igzoom v2 and igmod work, the program is incappable of taking screenshots of the buttons on the iguidance map, so when switching between menus the buttons on the map dissapear for a second.
Im looking into a better solution for it still. For the time being however, this is more ellegant than allowing the user to see all the crazy resizing that happens.
Logic bug in the skin file concerning the "no gps is connected window" I think. I see that a bit too and need to fix it, its getting on my nerves. Its not by design choice, thats for sure
Everything else: Plenty thanks for your investigative work, nearly all of those other bugs are unacceptable in a release. I will investigate and fix them all in the next couple days now (provided I find time between studying for my classes)
Old 08-28-2005, 05:47 PM   #101
PURDooM's Avatar
Updated previous post; I had alot of typos.
Perhaps I should get more sleep.
Old 08-28-2005, 06:02 PM   #102
Playerbeat's Avatar
This is probably going to sound stupid but how the hell do you close this app?
Playerbeat is offline   Reply With Quote
Old 08-28-2005, 06:16 PM   #103
PURDooM's Avatar
If in a frontend the frontend should be in charge of closing it, otherwise click the map somewhere (to put the iguidance window into focus) and press alt-f4.
Alternatively you can kill it off from task manager under the applications tab, or you can kill either igmod.exe or iguidance.exe in the processes tab.
Thats in the readme for alpha 4 as well.
Old 08-29-2005, 01:07 PM   #104
PURDooM's Avatar
Still working on wrinkling out the beta 2 bugs. Progress is moving slower now that my classes have started.
New BlueIce skin ive been working on:
Looks like the menu image is a little missaligned.
Old 08-29-2005, 02:35 PM   #105
Zebelkhan's Avatar
Would you kindly drop out of school until AFTER you finish this????
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Release 1.4 CENTRAFUSE BETA 2 veetid Centrafuse 32 08-02-2005 10:20 AM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 03:13 AM
RELEASE - FreeDrive 0.51 Beta CdRsKuLL FreeDrive 39 04-20-2005 04:03 AM
RELEASE - FreeDrive 0.33 beta (D3 Frontend) CdRsKuLL FreeDrive 60 02-18-2005 03:08 PM
