Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Other Cool Stuff
Old 10-24-2005, 12:32 PM   #166
kbreeden
Looking good, PURDooM!
I'm still having some trouble with POI in 2.1.2NA. I don't think it's the kind of POI problem you mentioned in your release notes. I'll document it and repost.
kbreeden is offline   Reply With Quote
Old 10-24-2005, 01:37 PM   #167
chrisk is on a distinguished road
Quote: Originally Posted by PURDooM
It *kindof* works with frodoplayer right now. Set it as an external app and make frodoplayer go into mini mode.
Ill improve that integration soon to look more oem.
Heres a pic of it running on frodo, there seems to be something up with the speed,ETA,DIST box and there is the gray window frame around it, but you know that already. also when I start the app it always starts in a small window and i have to maximize it. Is there a way to fix this so its full screen?
Thanks and im sending a donation now.
chrisk is offline   Reply With Quote
Old 10-24-2005, 07:50 PM   #168
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
Check out the new frodo. It supports SKINbedder, so it should support iGMod natively.
0l33l is offline   Reply With Quote
Old 10-24-2005, 09:09 PM   #169
PURDooM's Avatar
PURDooM is on a distinguished road
Woha, you shouldnt have that weird border around your buttons on the map.
Something must be wack with the transparent region by color code. Send me a message on aim dude and I can see whats going on there. (AIM = CanOpenerOfEvil)
The fullscreen problem is because iguidance doesnt like being stretched larger than screen size. Im brainstorming solutions.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 10-24-2005, 09:12 PM   #170
My Village Called
0l33l's Avatar
I've got some code for that. Hit me up on AIM
Old 10-25-2005, 08:14 AM   #171
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
ToyotaSoarerOfEvil?
tj!2k4 is offline   Reply With Quote
Old 10-25-2005, 02:48 PM   #172
DaPCWiz is on a distinguished road
would it be possible to make the confirmation on exit and option? it seems to screw up road runner.
DaPCWiz is offline   Reply With Quote
Old 10-25-2005, 03:29 PM   #173
Raw Wave
tj!2k4's Avatar
I have my iGuidance registry key set to read-only because I want to be able to run the GPS on COM16 and need the key to be read-only so that iGuidance doesn't reset it back to COM1:
When iGMod attempts to start, it displays an error that it couldn't modify something in the iGuidance Options key.. what is it trying to enable/change, and can the registry modification be disabled?
Old 10-25-2005, 03:39 PM   #174
you can undo the read only on ur registry and setup igmod so that it automatically sets your com port to 16 on load.... that's what i did (as per pur doom's suggestion) when I had that problem. That was iwth igmod 2.... I dunno how igmod reloaded works tho..
Old 10-25-2005, 03:47 PM   #175
Raw Wave
justintime's Avatar
justintime is on a distinguished road
I think you can just remove (or comment) the line on the ini that ways OPTIONS 123456 (or ssomething like that)
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 10-25-2005, 04:17 PM   #176
Raw Wave
tj!2k4's Avatar
thanks, but it appears to need to be able to write those setting every time it starts.
Old 10-25-2005, 04:18 PM   #177
Raw Wave
tj!2k4's Avatar
thanks, i'll look into that..
Old 10-25-2005, 04:20 PM   #178
Raw Wave
tj!2k4's Avatar
also i noticed a hollow red circle that appears in the vicinity of where iGuidance says I am.. looks like it might displaying the location where the GPS is really tracking..
Old 10-25-2005, 06:17 PM   #179
yep, that's what it does.... ask purdoom...
mmm I noticed that too....
Old 10-25-2005, 07:02 PM   #180
My Village Called
0l33l's Avatar
ToyotaSoarerOfEvil?
No. Its in my profile
iGMod Beta 1 release PURDooM Other Cool Stuff 175 12-28-2005 11:17 PM
Release 1.4 CENTRAFUSE BETA 2 veetid Centrafuse 32 08-02-2005 11:20 AM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
RELEASE - FreeDrive 0.51 Beta CdRsKuLL FreeDrive 39 04-20-2005 05:03 AM
RELEASE - FreeDrive 0.33 beta (D3 Frontend) CdRsKuLL FreeDrive 60 02-18-2005 04:08 PM
