11-02-2005, 10:07 PM
#226
Quote: Originally Posted by kbreeden
PURDooM,
I'm having a heck of a time getting IGMod to embed properly in CF the first time I try. I'm using CF 1.5 now but was having the same problem with 1.4. I mentioned this in a post a few days ago. I'll try to get you a screen shot of what it looks like when it doesn't embed properly.
Me and JIT are having issues embedding with the standalone mode disabled as well. Is that what your problem is?
11-02-2005, 10:49 PM
#227
if I have stand alone disabled.. and I exit, it works great. BUt then if I reload it, it gives me a blank gray screen. If I try to close the blank gray screen via RR, it pops up the "are you sure". THen I have to click yes and load up igmod again, and then it reloads correctly.
11-02-2005, 10:58 PM
#228
*goes and removes the "are you sure" screen*
its causing too many problems.
11-03-2005, 02:02 PM
#229
I wrote a program which will embed anything in centrafuse and let you resize the embedded window. So now you can have a normal sized 1.4 window without the titlebar in cf 1.5. I still need to figure out a good way to invoke fullscreen...
11-03-2005, 02:42 PM
#230
As I was driving around last night I noticed that a blank white screen flashed about every 5 secs and the speed zoom window would vanish as well. Don't recall this before but I wouldn't have noticed it in the day with a white background. I'll check it out more tonite.
Will there be a way to trigger the "menu" without having the button on top of the map image? I'd like to have a menu button on my RR skin (outside the IG window) that would bring up the IGm menu.
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
11-03-2005, 02:44 PM
#231
I looked at the windows that open when I have the problem and one says "IGMod Reloaded" and the other said "--IGMod Reloaded--". I changed the window in CF settings to "--IGMod Reloaded--" and it seems to be working. Could be I was just using the wrong window name. Ineed totest it some more.
11-03-2005, 09:55 PM
#232
I drive ususally at night on a extremely slow computer and don't notice that flashing unless I am in the middle of making a turn. However, I don't use RR right now either, I should test that for a few days.
How does RR pass information to iG? Keypresses? I could make hotkeys for buttons if needed.
The problem is I have 2 windows named --iGmod Reloaded-- in memory if not using the standalone mode.  Still examining this some more.
11-03-2005, 10:27 PM
#233
MySQL Error
I thought I was just loosing my mind, I am using IGmod with centrafuse and it flashes the square box at the top only when you have the map in night mode. It will not flash with the map in day mode, or if you drive under 10mph in night mode.
11-03-2005, 10:31 PM
#234
Raw Wave
I have not noticed any flashes. What area are you refering to exactly? I use this at night every night, and honestly have not noticed.
11-04-2005, 08:58 AM
#235
Terminal flasher
Yes its done with keypresses. If you wanna make hotkeys for the buttons i'd suggest you take a look at iGkeys n use the same hotkeys. That way people that are using the zots skin can actually use iGmod
11-04-2005, 03:18 PM
#236
I just installed iGmod and it looks great, but it's changing my tracks automatically. If i switch out of igmod, my track (whether mp3 or xm) stays.. but when I go into igmod, the track starts changing every 5 seconds or so.
Anyone have any ideas?
BTW, i'm running Roadrunner with MC2.0 skin.
2006 Nissan Titan LE Truckputer
[I]No installation thread yet[/I
2002 BMW 330Ci Steel Grey Metallic *Sold!*
Installation Thread
11-05-2005, 12:33 AM
#237
MySQL Error
up at the top of the window
11-05-2005, 02:54 AM
#238
OH i know.
To determine if you are in guidance mode it checks pixel 0,0 on your map for the color dark blue.
Which also happens to be the color of lakes and rivers at night.
I recomend making the color slightly darker/lighter in your theme.ini if you can. Or wait until I have a creative fix for the problem.
11-07-2005, 11:25 PM
#239
hey purdoom love the program but quick question...I'm running igmod as an external app with frodoplayer, is there a way to have it remember it's window size to what it I had it set to? This isn't an issue with hibernation, but when I occassionally restart my computer and load igmod, I want it to be able to be the same window size I had it at before reboot, so I don't have take my mouse into the car and resize it manually. Keep up the good work.
11-08-2005, 12:50 AM
#240
I think it remembers but it has to be a. non maximized and b. you have to close the program the correct way (press x, press yes i want to quit).
| Thread Tools |
| Display Modes |
Linear Mode
