New fully working OSK (Even the shift key replacing the OSK with the upper case OSK!
Also, progress update: Integration works excelent even in roadrunner. Zoomed speed is now programmed in and working even better than in igmod 1. I toyed with the idea of using anti-aliasing for zooming the speed, but that would practically kill your avaliable CPU cycles.
Its getting there...
Also, the skin is very different then before and gives full control of nearly every aspect of the skin to the user. iGmod has no idea what the differences are between the OSK and the buttons on the main interface untill you program in the rules for it to follow.
Ill make a big skin FAQ for the new design when the program is out.
Actions based on what region of an image are also now avaliable (so you can make one big OSK image and simply press regions of it to trigger pressing a key).
If any of that didn't make sense I am sorry, im on sleep deprivation and expresso coffee right now
