10-11-2005, 12:07 PM
#121
Quote: Originally Posted by skippy76
Hey PURDoom: Keep up the good work. ONe constructive critasism is that we seem to be loosing a lot fo the map view. I would like if possible to have a whole screen map view with maybe an info pane at the top. If we select the info pane then a menu could appear taking up half of the screen, similar to RoadRunner's support of MapPoint. After a configured period of time the memnu then dissapears.
Andrew
don't forget... what ur seeing is also 800x480 in CF. If you are using road runner, there won't be all the centrafuge wraparound and there will be alot more map area...
10-11-2005, 12:28 PM
#122
1. you can press centrafuse's title bar to go into full screen
2. there is/will be an option in the custom menu to remove the gui enhancements
Screenshot at 800x480:
10-11-2005, 01:51 PM
#123
I think that iGmod needs its own forum under Support Software! Get it out of "Other Cool Stuff" and make PurDoom the forum leader!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
10-11-2005, 01:56 PM
#124
I'll second that!
10-11-2005, 01:59 PM
#125
If/when that happens i have plans to make all kinds of stickys. The how to code skins tutorial is going to be pretty extensive
10-12-2005, 06:00 AM
#126
hi PurDoom this is greate.. can you please how to use it i ran the igmod.exe file and it started iguidance but how do i change the car icons that are included in the ziped file i downloaded. Also how do i integrate it with frodoplayer.
thanks
10-12-2005, 07:43 AM
#127
Hi PURDooM,
I downloaded and installed the new preview. It's looking good!
I do want to let you know that whenever I hit the POI icon in the main menu, the program freezes. I know this is just a preview and maybe you're already aware of this, but I thought I would point it out just in case you're not.
Keep up the good work!
Kevin
10-12-2005, 12:21 PM
#128
Quote: Originally Posted by kbreeden
Hi PURDooM,
Kevin
Yea, whats actually happening is its saying "this action is broken" but you cant click the ok box because the menu is always on top  . Ill fix that right now for the next release.
I haven't thrown in the frodoplayer integration yet. As far as the car icons run the patcher in the patcher folder and it will make you have the big icons. I tried adding the eclipse icon for the car icon but it just didn't look right.
10-13-2005, 11:03 AM
#129
Don't know why, but my install is running GREAT! Load time is a little long but everything seems to work that I've tried. I would like to do some skinning so that it matches my RR skin though. I'd also like to see the option of selecting different ways of locating an address/poi (eg: city first, street first, by distance, by type, etc.) like the native options in IG. (BTW: Where's the wav file the makes the keypress sound? I'd like to change it.) Thanx!!
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
10-13-2005, 11:08 AM
#130
My install is also running very well with the latest IGMod preview embedded in CF. It seems very stable. I have not pushed every button, but so far the only issue I've seen is that it locks when I hit the POI button.
10-13-2005, 11:18 AM
#131
Hey if you wanna change the way to enter an address/poi here is how you do it:
in the skin.ini file filnd the text that looks like this:
Code:
ACTION
SHOW_MENU "SetDestination2"
HIDE_MENU "Main Menu V2"
END_BUTTON
then just change where you see "SetDestination2" to "SetDestinationConfer" and you will see the difference!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
10-13-2005, 11:33 AM
#132
the sound file is the wav file in the skin\blueice folder.
Everybody just hang tight before you start making your own skins, I am still designing how the default skin works.
Progress update: I just need to finish the POI functions (the program will automatically generate all the POI menus off of what is visible in iguidance until I program a new phonebook addon to igmod) so when that is done and I do some bugfixes on embedding the results window, I will have a release canidate to post.
10-13-2005, 02:12 PM
#133
Describe what you mean by a PHONEBOOK ADDON?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
10-13-2005, 02:16 PM
#134
Well the other day I went to go see a concert in the cities near me, and I thought I would let IG handle all the one way streets business for me. So I went to attractions, list all, and whatdya know the place isn't listed. That fustrated me. So I plan on finishing my igphonebook program that I was working on that rips the superpages.com database (it can parse my 763 area code in about an hour and make it about 8 mb large, containing every business, the businesses web site/hours of operation/products that they sell/gps coordinates/ect) and makes a nifty frontend for iguidance. So you could say look for product: tacos and it would find it. It will be designed to work with standalone ig as well.
But thats a whole different project alltogether. First I have to finish igmod
10-13-2005, 02:22 PM
#135
Raw Wave
so it wont actully add pois (graphically) but rather directions to the poi is what your saying?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
| Thread Tools |
| Display Modes |
Linear Mode
