02-22-2006, 03:35 PM
#121
Quote: Originally Posted by b8bboi
(and not just halfassed it like Map Monkey).
Ouch!
I like both apps, go figure.
02-22-2006, 05:24 PM
#122
Man, I love this app. Great job, garo. I like how you totally skinned the Address and POI screens (and not just halfassed it like Map Monkey). I love the full-text search, too.
Got several questions on how to integrate it to RR, though.
1. Can I use RR to pull in info like ETA, ETR like I could with Map Monkey? Also, can I use RR buttons to send commands to GaroNav?
2. If I set the default size to 800x600, when trying to embedded GaroNav into a smaller window RR, it freaks out at first and tries to take focus of the whole screen. (See screen shot). If I click back to Main Menu, then click back to GaroNav, it'll be fine. However, some buttons will be hidden due to the difference in screen size between the default size (in Main.skin) and RR's embedded window size. Is there an easy way to fix this issue?
(Notice how the blue Menu button is cut off. Also the text that says "Current Position" is also cut off. Both are set to be at x=0).
3. Another problem is that when you execute a "CLOSE" command in RR to close GaroNav, it doesn't close gracefully. I think an instance still remains in Task Manager. Right now I have to close GaroNav using the Menu button first.
Use this RR config for embed Garonav.. see the screenshot
Use you directory for Garonav folder...
Edit:done my new skin for GN.... I tested it!
New edit:
for see the labels embed to RR skin, use the !GN command... in EXTERNAL_GPS.skin of RR skin if you use.
type:
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L01,177,446,466,025,000,255,255,27,"LCD Display Grid","!GNADDRESS>>TRACKNAME>>=Volume Audio ||VOLUME","SCROLL-LEFT"
Mauri
02-22-2006, 05:34 PM
#123
Thanks. I do know how to embed it. It's just that when GaroNav first opens, it kind of freaks out and posts images outside of the embedded window like the pic attachment shows. After that it's fine.
Here's a screenshot of the embedded GaroNav after I go back to Main Menu and then back to GaroNav.
02-22-2006, 06:20 PM
#124
This is one problem of settings of the label in GN skin...
Anchor the label with Top,Bottom etc....
You have the readme for make one skin ....I don't memory if Garo has put it in the upload of the packet...
I attach it to you, read in that as to do.
Mauri
02-22-2006, 07:32 PM
#125
Of course, read the txt files attached to the GN.
try to set always on top = false in the options screen.
Do you use the standard 800x600 skin?
This problem should not happen... But maybe it's possible. I'll check it.
02-23-2006, 12:53 PM
#126
Thanks. I missed the RR integration part at the bottom.
Yes, I do have <add key="AlwaysOnTop" value="False" />
I use 800x600 skins. The problem is the window I'm embedding GR in is only 649x420. When GR starts at first, it will try to expand itself out of the embedded window but after that it'll be fine. The first screenshot I posted in post #120 is when GR starts. The second screenshot in post #123 is when I return to the skin the second time. I think a solution for this is for GR to "remember" the last screen size and location like Map Monkey. Map Monkey has an option for this.
On a second thought, don't worry too much about this. I found out that if I start GaroNav before RoadRunner, it should embed fine in any situation.
02-23-2006, 07:15 PM
#127
Garo, may I make a few suggestions?
1. Full-text searching for POI/Favorites without having to select category first.
2. Commands to
- toggle AutoZoom
- toggle North Up/Direction Up
- Zoom In, Zoom Out
- Recently navigated to addresses on Navigate To screen
3. I found some commands like !GNETR don't work in RoadRunner. The only one I found that works is !GNADDRESS. Could you look into that?
4. Also not sure if this already works yet but semi-transparent buttons (like the new version of FreeDrive) would be very cool.
Thanks.
02-26-2006, 05:21 AM
#128
My new skin v.2 for Garonav
Ready for the download my new version 2 of the skin for GaroNav, to 800 x 600 of resolution.
Some screenshotses here under.
EDIT: all these screenshots are to low resolution and quality for evident dimensions of the files....
Download here:
http://mio.discoremoto.virgilio.it/f...uridisk&path=#
Select the file " Mauri.zip " (2,62Mb)
Besides available my complete skin for RoadRunner, in download in the web site of Garo,
link:
http://www.riccardogarofano.com/Defa...?page=Software
If you find some problem or comments for my skin, I beg to make to know in this thread.
Mauri
02-26-2006, 05:22 AM
#129
Another screenshots:
02-26-2006, 05:23 AM
#130
And embedded with my RoadRunner skin
02-27-2006, 10:54 AM
#131
garo, or anyone, I got a question. I'm using XPort to split the COM port (3) to COM5 to COM12. On the GPS Option screen, there's only two options, COM1 and COM4, both are not GPS ports. Clicking Find GPS doesn't work for me. Is there anyway you can directly specify a COM port in GN? I know all of my virtual COM ports work since I've tested them.
03-01-2006, 08:27 AM
#132
New different Compass...
Replace with this file in my folder/skin.
Mauri
03-30-2006, 11:31 PM
#134
I noticed that when you exit roadrunner, it still leaves an instance of GaroNav running in the background. Im able to duplicate this problem consistently. The GaroNav executable continues to run after Road Runner exits. You can see this my looking at the currently running processes in Task Manager. This is with the most recent build of Roadrunner, from 3/6 and the RC1 of GaroNav.
03-31-2006, 03:35 AM
#135
I know of this problem. I'll release in a few days the new version and then you will tell me if this fix the problem!
| Thread Tools |
| Display Modes |
Linear Mode
