Feature requests are fine! I created the portion of the program that goes out to weather.com and downloads all of their available information. They have quite a bit. They have information about your location, such as lat/lon, sunset/rise times, the exact location of the weather observations. Current conditions like temp., cloudiness, barm readings, wind, etc. You can pull an extended forcast like 5 or 10 days, as well as weather alerts. I'm going to first do it for MM and then look into Free Drive. I don't use freedrive, but i would imagine that any gps software that will give you your location will work.
I already entered code to check for the internet. I'm running into problems where it crashes if you aren't online. I will obviously correct this.
I'll play with it this weekend and hopefully have a test program for you to try.
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
