Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Other Cool Stuff
Old 09-07-2006, 03:23 PM   #31
clemen is on a distinguished road
Can I get the source then I shall fix it.
clemen is offline   Reply With Quote
Old 09-09-2006, 04:22 AM   #32
jennico is an unknown quantity at this point
hi clemens
watch this
http://www.car-pc.info/phpBB2/viewto...=130701#130701
thats what u need showgps 2.5 beta.
j.
jennico is offline   Reply With Quote
Old 09-13-2006, 10:04 AM   #33
mauri's Avatar
mauri is on a distinguished road
Is it possible to move in one custom position all the background bitmaps image?
I want to set my X and Y position for this....
Mauri
mauri is offline   Reply With Quote
Old 09-13-2006, 03:37 PM   #34
LESLIEx317537's Avatar
LESLIEx317537 is on a distinguished road
Hey all, sorry I can't test the program right at this moment. I have no clue as of why it would be reporting the wrong data, but I have on the way a new GPS Rx like the one I have in my car. The BU unit and it works with it in my car.
I will look into the code and see what I can find out. And why it is reporting the wrong data.
Mauri, you want to move all the gauges at once? You need to move them individually the way I set it up, then once you have it where you want it, you can lock them. But they do work on x and y coordinates. So I can code it so you can choose the x and y for each one if you want.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Relocating headunit and extending faceplate
Button app to Alt-Tab between two programs
LESLIEx317537 is offline   Reply With Quote
Old 09-13-2006, 03:56 PM   #35
Are you computer using imperial units, i was driving 53km/t today and it showed 5321km/t so maybe its a unit fail
Old 09-13-2006, 09:57 PM   #36
clemen, try showgps 2.5 beta thats what u need perfect for your purpose..
j.
Old 09-14-2006, 07:52 AM   #37
j.
No it isent, I just need the speed in text, and show is not simple enogh yo my purpose
Old 09-14-2006, 08:11 AM   #38
ShowGPS's Avatar
ShowGPS is an unknown quantity at this point
Lightbulb Oh, yes its simple...
Hello Clemen!
You can make your own skin for ShowGPS.
Easy by mouse in the program.
Go to Options -> More Settings -> Displays+Instruments
Disabled all you donīt need.
Then go to Display and make sure that no other skin is in the textbox and that "Menu remove"+"in the foreground" is enabled.
Save all by OK.
Now, go to Surface-> Disabled "Lock Surface"
Move the Displays or Text in ShowGPS to the position you like and by this resize ShowGPS.
Then press Key F8 to Remove the Menu.
Start ShowGPS with F2.
Okay, its a little work, but now its simple.
Bye
My english is bad...
ShowGPS - CarPC / Laptop Tool - POI / GPS / Tracking / Map
ShowGPS is offline   Reply With Quote
Advertisement Sponsored links
Old 09-14-2006, 09:10 AM   #39
Okay I will try, do you need a danish translation of ShowGPS`?
Quote: Originally Posted by ShowGPS View Post
Hello Clemen!
Save all by OK.
Bye
SDPIF digital Coax into car audio pieces RedGTiVR6 Car Audio 34 10-14-2008 01:06 AM
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Coaxial Digital VS Optical Digital MeeM Car Audio 5 06-01-2006 01:55 AM
SPDIF (digital coax) to Toslink (digital optical) convertor? Just curious... coachreed General Hardware Discussion 7 04-27-2005 11:33 PM
Digital to Analog Converter Maukio Car Audio 0 02-01-2005 12:58 AM
