Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Support Software > Other Cool Stuff
Old 08-04-2006, 08:32 AM   #31
njwashor's Avatar
njwashor is on a distinguished road
Quote: Originally Posted by MatrixPC
For some reason, it fly very high instead of 1250 I set.
When I go view property of the NW link, it zoom in but slowly zoom out to 10K+.
Hmmm... thanks for the update Matrix, and I'll have to take a look into that. Maybe if you could do me a favor and see what is getting printed out in the link file for range, then we can see if it's my app or if GE for some reason isn't handling the linked file correctly. Let me know, and thanks for the help.
Nate
njwashor is offline   Reply With Quote
Old 08-05-2006, 03:08 AM   #32
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
I think it's more likely be GE problem. The link file printed correct value. It's one of the camera' fly to view setting. I try all 3 different setting, but they all the same. I just has no idea and can't really use it cuz the collected data only show frwy and highwy.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-08-2006, 11:28 AM   #33
T.N.T is on a distinguished road
I have the same problem, I stay at 15k - 20K ALT.
The FLY TO - TOUR SETTING was by default set to SLOW.
I put it at 20% and now it work WELL.
SLOW----------|------------------------------------------------FAST
Very Good Apps ! A MUST for OFFLINE GE User ! Canadian can'T have CHEAT GPSR internet connection for the moment. Maybe it will change with new PORTABLE WIFI TECHNOLOGIE offered by ROGERS and BELL.
GReat Continuation to all DEV who spending time in TOOLS and little APPS like that !
T.N.T is offline   Reply With Quote
Old 08-09-2006, 11:02 AM   #34
mkkyah is an unknown quantity at this point
Dear njwahor,
Yes it's now moving and seems like building the cache. Now I'm trying to choose best values for speed and range. Here are my experiences:
- I have seen that I was exiting Cache Builder after building the kml file. So it was flying to starting point and waiting there. You have to write an "idiotproof" guide
- No you don't need an internet connection at the start; if you uncheck the Network Link before you close GE, it starts also offline next time, otherwise it fails to login like you said.
My last question: Cache builder is not starting from the NW point I am imputting. Is this normal, will it come to that point later, or is something wrong?
mkkyah is offline   Reply With Quote
Old 08-09-2006, 05:27 PM   #35
MySQL Error
MatrixPC's Avatar
Coollllll, that works.
Only recommendation is speed factor need to be a little slower
Old 10-13-2006, 11:45 AM   #36
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
anyway someone can recommend me some settings that would allow me to build the cache at a very low zoom level. Here are my settings now :
Miles East: 50
Miles South: 50
Range: 300
Speed Factor: 1
Resolution: 5
as its building its only going down to about 30mi. I'd like to go down to about 700ft.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 10-15-2006, 09:04 AM   #37
tamerlouis is an unknown quantity at this point
Another useful software
Hi Guys.. This is Tamer Louis..
Thanks Nathan for the useful GE Builder...
I made another program which have some other features..
1. It scans the areas in order, it doesn't take random snapshots. It takes snapshots from left to right till the row is fully scanned and then it goes to the row below it, and so on.. till the full area is scanned.
2. You can set the space between snapshots.
3. It stops when it finishes the full scanning and gives the user an information message.
Anyway, you can try it...
You can download it from my web page at www.geocities.com/tamatimo.geo/files
the file name is GEV.zip
Any comments are welcomed ...
my email address is tamerlouis@yahoo.com
Good luck
tamerlouis is offline   Reply With Quote
Old 10-15-2006, 09:06 AM   #38
I forgot to tell you that GEV stands for Google Earth Voyager
Old 10-16-2006, 12:46 AM   #39
morris_the_cat's Avatar
morris_the_cat is an unknown quantity at this point
Should Google earth be running at the same time? What are typical values for space between snapshots, & refresh? Thanks.
morris_the_cat is offline   Reply With Quote
Old 10-16-2006, 02:40 AM   #40
Yes, Google Earth has to be running at the same time.
For the snapshots values, it's the height and width of your image at the selected altitude... For example, if you choose an altitude of 600 meters, you will see that google earth will display an image of a height of about 450 meters and a width of about 700 meters. To get the best values for your snapshots just choose an altitude on GE and then by the ruler tool get the width and height of your image and set those as the snapshot values.
The typical values for refresh if you run an area for the first time, is about 15 to 25 seconds depending on the internet speed.
For quick refresh, set the "Fly to Speed" option to Fast (You can get it from GE -> Tools menu -> Options -> Touring tab).
Thanks.
Old 10-16-2006, 05:22 AM   #41
Version 1.2 is available now!
I have uploaded version 1.2 with a progress bar and some ordering.
Enjoy !
Old 10-17-2006, 07:48 AM   #42
Version 2.0 is now available with advanced options to set starting from a specific point.
This will be useful if you close the program and need to run it after a while from the last point it was stopped at. This will remove the burden of starting from the very beginning and scanning snapshots that are already scanned.
Old 11-11-2006, 03:42 PM   #43
amitag is an unknown quantity at this point
Hey, thanks for the tool..
However i am not able to figure out how to set the following:
Then you set up Google Earth to read in the KML file as a network resource. Set it up to refresh every second and to fly-to the location..
After i start the tool, a kml file is created which keeps on updated, i click to that file and the location opens up on GE. But, it does not move (get refreshed) automatically.
can anyone help..
amitag is offline   Reply With Quote
Old 11-28-2006, 03:35 PM   #44
artkrime is an unknown quantity at this point
Hi all, im new to this but well ive been readin into this and got ge setup in RR, but when I go offline the stuff is still cached but when i type something in to "fly-to" it will give me the network error, i can only manually look at the place.. is there anyway around this? i have setup the cashbild file as network link. thanks in advance
artkrime is offline   Reply With Quote
Old 11-28-2006, 03:46 PM   #45
SteveC is on a distinguished road
So just how big is the USA at 700' resolution in terms of GB or should that be TB
RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
Webmaster for the European Ford Scorpio Site
SteveC is offline   Reply With Quote
Finally my 2000 Toyota 4runner google earth equipped car puter eacarrender Show off your project 32 05-31-2006 09:48 PM
Google Earth: How? sux89 MacCar 9 03-15-2006 09:05 PM
Google Earth SKIN (in progress) RPM_VR4 SB Skins 6 02-15-2006 07:45 PM
Embedding Google Earth to RR Asskick Road Runner 11 02-10-2006 10:44 AM
Drop-down menus don't work? Read this! gnomad Announcements 0 10-14-2005 02:15 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
