Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 01-30-2008, 12:32 PM   #256
juve021 is on a distinguished road
Quote: Originally Posted by Robby BMW View Post
I am still working on it, please be patient, it is almost ready
This is a screenshot of the preliminary release:
Wow awesome
juve021 is offline   Reply With Quote
Old 01-30-2008, 05:16 PM   #257
mrbean_phillip is on a distinguished road
Nice going, Robby
I have my setup all soldered up, so will probably get the sensors fitted on the weekend, to test it out.
Came out well, and I have to admit, DeJan's PCB's looks very good - I am awaiting a 2nd one to finish off for AllyPally, just got the 1st one yesterday.
I am considering designing a new board for those that wants to use the data-out line on the connector from theTPMS, and possibly locate this board inside the original unit, with a USB cable soldered to the PIC PCB, and an USB plug of one end to connect to the PC.
Should work pretty well, just need to check space inside the original housing.
Looking forward to your test software though, will make things easy for us.
Thnx for your efforts, it is appreciated!
mrbean_phillip is online now   Reply With Quote
Old 01-30-2008, 05:37 PM   #258
Ces///M3
just a quick question, is the 3rd eye kit mounted completely internally or is it sensors similar to tire valve caps ?
Ces///M3 is offline   Reply With Quote
Old 01-30-2008, 05:40 PM   #259
DigitalVampire is an unknown quantity at this point
The 3rd eye sensors are suited for mounting inside the tubeless tyre replacing the existing valve stem.
www.dentalteam.org
DigitalVampire is offline   Reply With Quote
Old 01-30-2008, 05:48 PM   #260
Quote:
Has anyone tried a diffrent TMPS system, like the Valet?
I suggest you read the last few pages of the thread, it answers your question.
Enjoy.
Old 01-30-2008, 08:12 PM   #261
Quote: Originally Posted by Fmode
Hello,
sorry for being absent for while and not reading here...
I noticed this thread just before the question to buy Smarttire sensors again or to change the system to a cheaper one. So I decided to change (my summer-tires also need new sensors...)...
I choose the Waeco TPMS (www.waeco.com) stuff for only 100 Euro and with 4 sensors but without a display (which I, and I guess you guys too, don't need) and it would be good to have a system from a vendor "with a name" (in 5-6 years if you need new sensors - but the batteries could be exchanged easily).
Can you verify which Rf-chip is on your receiver board? Is it the same TDA5200 ASK Receiver, or not - if different, can you give us a part number, please Fmode
Old 01-31-2008, 01:07 AM   #262
inh
inh is an unknown quantity at this point
Looks great Robby!
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 01-31-2008, 03:34 AM   #263
almera's Avatar
almera is on a distinguished road
Nice work again Robby, I'm also waiting for this sw, because I couldn't manage to get data from the hw, what could be wrong ..
almera is offline   Reply With Quote
Old 01-31-2008, 04:43 AM   #264
@ Almera: Are you running Roadrunner when you launch the Configurator?
You have to - just launching the configurator without running RR frontend will not "detect" any id's from any wheel-sensors.
As soon as you foolow Robby's install-tips in the RR plugin forum, and then launch RR, and then the configurator, you can press the "learn" button for any sensor, and it will blink a few times, and then stop blinking.
After a short while, you may see some flashing red alarms in RR on the TPM screen, indicating - press and temps, albeit incorrectly, meaning that the sensors is communicating to the PIC, and the PIC to the plugin s/ware on your frontend.
Old 01-31-2008, 05:08 AM   #265
FMode is on a distinguished road
the problem is there is no number on this receiver... and I can't look inside (if you are really interested I can try to get a small hole...)...
your TDA5200 will need analog discrete parts to work... but you are a very tough I guess ...
or didn't you find a source for complete receiver-modules ?
Here is one:
http://www.funkmodul.com/funkmodule/empfaenger.htm
you should take ERX-06 because it has the max. sensitivity...
Where did you get your tire sensors ? Why don't you buy the Waeco Kit with Receiver ? (4 sensors = 99 Euro , 4 sensors+receiver = 99 Euro ) (or do you want to build/sell a finished kit ?)
FMode is offline   Reply With Quote
Old 01-31-2008, 05:56 AM   #266
Erm, I have the 3rd Eye kit, and I made one working setup based on Robby's PIC, but I am just interested to know if yours use the Maxim IC or the TDA chip - my bet is your's is very similar to the ERX-06 you linked to....
I would like to develope a smc solution, which includes RF Receiver, Robby's PIC (but SMC) all onto one pcb, which would make it easier, cheaper, and much smaller.
Just luv tinkering, that's all
edit: There is a very nice Max1473 evaluation kit available, which I can very easily adjus to suit our needs, and provided Robby can provide TSOP 18F2550's, it would be very easy to do an industrial-grade, robust design
I am awaiting pricing on the eval kit, will keep everyone posted.
Old 01-31-2008, 10:39 AM   #267
almera's Avatar
Thanks, actually I have succeed in the learning process, but still can't see any data in RR. Checked plugin configuration also, seems ok. Maybe something wrong with my hardware, thanks for help, cheers
Old 01-31-2008, 11:38 AM   #268
Robby BMW's Avatar
Robby BMW is on a distinguished road
Arrow Release TPMS Doctor, a new standalone utility to test the TMS-USB Receiver
Ok guys, the new software is availabel for the download here.
Change Log:
1.00
- First release.
1.10
- Fixed the discrepancy between the pressure detected and the raw data displayed.
- Fixed a little issue with the detection of the battery level.
- Improved the description of operating state of sensors.
1.20
- Fixed a another issue with the detection of the battery level.
1.30
- Fixed a bug with the USB buffer.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 01-31-2008, 11:54 AM   #269
almera's Avatar
Thanks Robby, I will try it..
Old 01-31-2008, 01:14 PM   #270
Attachment 47742
Wait so Robby, can I use this to test my receiver if I DO NOT have the sensors installed in my wheels?
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
