Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 03-25-2008, 09:32 AM   #436
juve021 is on a distinguished road
Quote: Originally Posted by Robby BMW View Post
Ok, never mind.
I just read this:
Yeah, I've been trying this for a few days.
If I use the 3rd eye display with the JP2 pin connected to the data pin of the 3rd eye wire harness, can you please give me the procedure I need to perform for learning the sensors?
juve021 is offline   Reply With Quote
Old 03-25-2008, 10:19 AM   #437
DeltaBi's Avatar
DeltaBi is an unknown quantity at this point
This happens if the device is not connected to the USB port when the software is started.
However, after connecting the device, if you press the "Once" or "Continuos" buttons, the state should change to "On line".
This is because the program, before to read the data from the device, will try again to detect if the device is connected.
Thanks, Robby. Probably it is what happened: I connected the device before starting the software.
Anyway, I'm testing the kit using the "garden" method suggested by Glitchinthesyst (thanks!) and I'm having confusing results.
The learning procedure (done via the Centrafuse plugin by Wolfgang) looks like complete successfully, but then I don't get data from the sensors.
In two cases I get data which apparently did not belong to the correct sensor. I mean I was working with the yellow sensor and TPMS Doctor showed data coming from the green one (apparently the data was correct). In another situation the CF plugin raised an alarm for a low pressure on the 5th tire sensor (that I don't own!).
What can be wrong ?
Can the TPMS Doctor perform the learning procedure ? I would rather use a single tool just to avoid confusion in the confusion!
Thanks,
Diego.-.
DeltaBi is offline   Reply With Quote
Old 03-25-2008, 02:05 PM   #438
Robby BMW's Avatar
Robby BMW is on a distinguished road
Ok, in this case, check this two things:
1) The connection to the display must be done as in the picture below.
2) The display must be powered at least trough the RED and the BLACK cables.
Now, launch the configuration tool (without RoadRunner) and perform the learning procedure for each sensor, as described in the program.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 03-25-2008, 02:20 PM   #439
DeltaBi's Avatar
Robby,
I could not find where is described the TPMS Doctor learning procedure, could you please shade some lights on this subject?
Thanks,
Diego.-
[EDIT]
Do you refer by chance to the RRTMS Config Tool? Do the registration did with it works even with the Centrafuse plugin?
[/EDIT]
Old 03-25-2008, 02:36 PM   #440
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is a jewel in the roughHiJackZX1 is a jewel in the roughHiJackZX1 is a jewel in the rough
Attachment 48760
Is a power cable needed for people that decide just to use the USB board and reciever and not the LCD screen? I figured that the USB port is what supplied power.
HiJack ZX1 CFSC
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
BUG WORKOUT [10%]
INTERIOR MODS [45%]
OTHER MODS [10%]
HiJack ZX1 Work Log
Abeille ZX2 Work Log (maybe)
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 03-25-2008, 03:01 PM   #441
Robby BMW's Avatar
Quote: Originally Posted by DeltaBi View Post
Robby,
Thanks,
Diego.-
[EDIT]
[/EDIT]
The TPMS Doctor doesn't include the learning procedure, but you can use the configuration tool provided with the RoadRunner plugin.
It works with any front end, because the learnig procedure is an internal proces to the PIC, independent from any external software.
Simply launch the application and perform the learning procedure, ignoring everything else that refers to the configuration of the plug-in for RoadRunner.
Old 03-25-2008, 03:03 PM   #442
DeltaBi's Avatar
Ok, I'll try it.
Thanks,
Diego.-
Old 03-25-2008, 03:17 PM   #443
Robby BMW's Avatar
If you don't like cables, you can use some alkaline batteries
I joke
The USB port provides the power supply to the receiver only if it is removed from the original display and installed on the TMS-USB board, but if it keeps inside the original display, a power cable is needed.
Old 03-25-2008, 03:59 PM   #444
HiJackZX1's Avatar
I joke
HAHA, if I go the battery route, i will have to fill the whole cargo area with batteries...... Ok, i will most likely cut the 3rd eye board.... I have installed all components and there is no way i am adding more cabling.
HiJack ZX1 CFSC
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
BUG WORKOUT [10%]
INTERIOR MODS [45%]
OTHER MODS [10%]
HiJack ZX1 Work Log
Old 03-26-2008, 12:43 AM   #445
inh
inh is an unknown quantity at this point
Just ordered the last TPMS from Viva that they had in stock.. Coupon code still works though =]
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 03-26-2008, 04:02 PM   #446
DeltaBi's Avatar
Robby,
I've completed the learning procedure using the RRTMS config tool and now the sensors are correctly coupled with their respective colors. As you may know I was using the "garden" method to wake up the sensor because I still don't have them mounted in the car wheels (thanks Glitchinthesyst for the idea).
[Note for others that are in the same situation: I inserted each sensor in plastic container and put it under pressure while the other sensors were placed in a isolated metal box, just to be sure;I then fired the learning procedure on the software and at the same time lowered the pressure in the cointainer to let the sensor send its data and register it.]
After having registered all the sensors I've tested them putting them all togheter in the plastic container and then raising and lowering the pressure just to be sure everything was okay.
In this situation I've noticed that in some cases the data showed by the TPMS Doctor was not consistent. I mean that sometime the pressure values from the sensors where not equal (they were supposed to be equal because they were in the same container!): some of them remained for a long time at the old value, sometime it was only for 10 or 15 seconds, sometime for much more time (I could probably dare to say for ever, at least minutes!).
As you may understand this is pretty important as I would like to be notified of a pressure change as soon as it happens!
Do you believe that this problem is related to having all sensors at short distance (inside the container) and thus could their radio transmission be jammed by each other? Or could it be that the firmware on the PIC does not handle batch of changes all at the same time (in a real situation I suppose this is not common)...
Thanks for your comments.
Diego.-
Old 03-26-2008, 05:17 PM   #447
WuNgUn's Avatar
WuNgUn is on a distinguished road
I powered up my TPMS to check the function...
Prior to it learning the sensors, does it read 'dead' on pressure, temp and battery? Specifically, the battery...I need to know (before going to the tire shop) that the batteries are okay in the sensors...
Can this only be accomplished after the learn function?
Hey Delta...how'd you pressurize this 'container'? Would a large mouth Coke bottle work if I just applied pressure with my mouth over the opening?
WuNgUn is offline   Reply With Quote
Old 03-26-2008, 05:44 PM   #448
DeltaBi's Avatar
Yes, as far as I know you have to "learn" the sensors before you can read any of the values.
I've used a garden hand sprayer with a wide filler mouth like this:
The mouth is big enough to insert the sensor.
I don't think the coke bottle will work because you would need to apply a fairly large amount of pressure.
Old 03-27-2008, 08:18 AM   #449
Robby BMW's Avatar
Robby,
Diego.-
The problem is not due to the short distance of the sensors, but to the simultaneous transmission.
The PIC firmware analyzes any signal coming from the receiver, in the same way the original display does, but if there are more transmissions at the same time, the result is the sum of the various signals, then garbled data. It is a physical fact.
About the issue that you had during the learnig procedure with the Centrafuse plugin, there is a new update that should solve that problem. Take a look here: http://forums.fluxmedia.net/showthread.php?t=2356
Old 03-27-2008, 08:25 AM   #450
DeltaBi's Avatar
So this is a design limitation, am I correct? Anyway I suppose it does not happen in the real world, unless you drive an F.1 car and have 4 mechanics working at the 4 wheels at the same time
About the Centrafuse plugin I've already noted and installed the new release by Wolfgang, thanks. It's a nice piece of software!
Bye,
Diego.-
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 147 02-21-2009 08:09 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 03:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 03:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 10:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 09:52 AM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
