Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 04-20-2008, 11:05 AM   #481
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Quote: Originally Posted by rgarjr View Post
Dejan,
Boards look very nice man. I'm seeing that JP1 and JP2 dont have a header pin, did you not put one on there?
As say mrbean_phillip if I put this two jumper into board then is difficult to position the receiver... In packet I send this pins to...
_Dejan_ is offline   Reply With Quote
Old 04-24-2008, 07:44 PM   #482
juve021 is on a distinguished road
Anyone looking for a board, pm me.
juve021 is offline   Reply With Quote
Old 04-27-2008, 04:57 PM   #483
vinzer's Avatar
vinzer is on a distinguished road
Good day everyone.
First of all thank you for this GREAT !!!!! project.
I have two short questions:
I got my TPMS system, installed it on the vehicle, test it with the original screen which comes with it - everything works great.
I got my PCB board with PIC controller, installed it on the vehicle and tested connectivity woth USB using TPMS Doctor software. It shows ONLINE.
Now first question: I do not want to cut the board, so most probably I can make a connection inside the receiver from resistor R3 (as shown on the schematic) to the aviable PIN on the connector. I think I can use short wire inside the receiver to do that. The question is - how long shielded wire from the connector to the USB-PIC controller device may be ? Lets say 24 inches is too long ? And will my existed receiver and LCD screen continue to work while connected to USB-PIC controller ? Will it give any interfereence ?
Second question is: I connected the short wire inside the receiver from R3 to aviable pin, after with shielded wire I connected it to the USB-PIC controller. I run config tool from RR in order to learn the IDs of the sensor. I hit learn button on the left front tire and after that defllated it almost untill 0. My existed receiver showed me very low pressure and started to beep however on the computer screen it still blinks red ..... so looks like it did not learned. I tried other wheel and the same result. I am sure that my connection is OK. The lenght of the shielded wire from TPMS receiver to USB-PIC is around 22 inches. The question is: Should I first go to TPMS Doctor, erase all sensor's data and only after that go to Config tool and learn sensors ? Or while I choosed learn in Config tool it will automaticly erase existed sensor's ID and change it to the new one ?
I run only Config tool and no RR.
Please help me.
Thank you.
Regards,
Vlad
BMW X5 Carputer Project
Finished: 85%
http://www.mp3car.com/vbulletin/show...lots-pics.html
vinzer is offline   Reply With Quote
Old 04-28-2008, 05:34 PM   #484
rgarjr's Avatar
rgarjr is an unknown quantity at this point
How are you guys knowing where to chop the board up? Is it just by looking at the picture and doing it? Any tips on how to hack it up? I would think you can use a dremel with a cut off wheel.
My carpc worklog
rgarjr is offline   Reply With Quote
Old 04-28-2008, 05:49 PM   #485
_Dejan_'s Avatar
On my page you can see where you must cut board...
In back side off complete board you see something like line... Take receiver again and you will see what I mean...
Old 04-29-2008, 07:32 AM   #486
Robby BMW's Avatar
Robby BMW is on a distinguished road
Quote: Originally Posted by vinzer View Post
Good day everyone.
Please help me.
Thank you.
Regards,
Vlad
If you don't want to cut the board, you have to connect the TPMS display to the USB interface with a shielded cable with a length not exceeding 40 inches, as shown in this post, no connections are required inside the receiver, so I don't understand why you have connected a wire on R3.
The display can be used simultaneously with the USB interface.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 04-29-2008, 07:51 PM   #487
vinzer's Avatar
Robby Thank you for your answer. I am electrical engineer, so I opened the receiver and found that the output from the recivers RF goes to R3, thats why I connected the aviable pin on the connector directly to it. And after I checked that R3 is connected to this pin already but thru the resistance which I removed. Anyway I will try once again.
But still another question - in case if in PIC's memory some other sensor's IDs are programmed should I first clean the PIC's ID memory or Config tool during learning process will do it automaticly ?
Thank you
Finished: 85%
Old 04-30-2008, 12:11 AM   #488
mrbean_phillip is on a distinguished road
@ Rgarjr:
Please see this thread my reply 134
I have taken quite a few close-up pictures showing exactly where to cut etc.....
Be careful though, you can very easily render your TPMS useless.
Enjoy.
mrbean_phillip is offline   Reply With Quote
Old 04-30-2008, 12:27 AM   #489
rgarjr's Avatar
Quote: Originally Posted by mrbean_phillip View Post
@ Rgarjr:
Enjoy.
Some outstanding pics you got there for this project, thanks..
The cut looks really nice and straight.
My carpc worklog
Old 04-30-2008, 02:40 AM   #490
I dressed it with a file after cutting it with the Dremel
As long as the pics help you out, good...hehe
Old 05-02-2008, 09:03 AM   #491
Robby BMW's Avatar
Thank you
The PIC doesn't store any identical sensor ID, so if you want to pair some new sensors, a memory clean is not need, otherwise you need to reset the PIC memory through TPMS Doctor.
Old 05-02-2008, 07:01 PM   #492
vinzer's Avatar
Thank you very much for clear answer !
Finished: 85%
Old 05-05-2008, 08:24 PM   #493
rgarjr's Avatar
Well just got my TPMS kit all setup and running, finally. Was glad everything worked fine.
My carpc worklog
Old 05-05-2008, 08:29 PM   #494
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
I hope mine goes as smooth....
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 05-07-2008, 08:49 AM   #495
Robby BMW's Avatar
Glad to be helpful
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
