Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 07-10-2008, 12:31 PM   #601
LYHTSPD is on a distinguished road
Quote: Originally Posted by HiJackZX1 View Post
The units tell you their battery life. I notice in CF it tells me the preasure, temp and battery life, so its not like you will have to guess or anything.
PS: there has to be a way to open them, then seal them back with no issues....
Quote: Originally Posted by bes51659 View Post
HiJack and LYTHSPD.
Even if I deflate the tires when not used (which I beleive might deform the tires) the batteries will eventually loose its juice. And that is independend on if I know that it will happen in advance with the battery indicator. In fact I'd prefer not to know rather to see "the ticking bomb".
Is this the way OEM systems work too? I have browsed thru http://www.realoem.com/bmw but did not find replacement sensors.
Have you got a good contact to ask about this, LTHSPD? PM me and I will ask. (I need to ask about how to exchange my four sensor 5's anyway)
I am on a customer's site at the moment... but I can elaborate more on the OEM stuff when I get back tonight. I will shoot you a reply to your email as well.
LYHTSPD is offline   Reply With Quote
Old 07-10-2008, 12:43 PM   #602
Lok
VENDOR - Portal Media
Lok's Avatar
Lok is an unknown quantity at this point
I just got my kit from Brandon and are reading thru this thread to learn more.
I am concerned about the sensor battery. If it lasts for 5 years as the manual say I will most definitely need new tires before that happens. I would like to make sure that the sensor batteries are full when changing tires and replace them if they are below say 67%.
Seems like a waste to get new sensors because the battery is flat, and what if there's no sensors on the market any more?
Has anyone opened a sensor and tried to replace the battery?
I would suggest replacing sensors rather than replacing the battery. As Lyhtspd, bobby and the others know the sensors are really not too expensive and I would think it cheaper to buy new ones then go thru the hassel of trying to open them and put them back together (not to mention the safety risk, you are messing with your tires, a sensor that breaks apart may cause a leak or even worse!)
Lok is offline   Reply With Quote
Old 07-10-2008, 01:40 PM   #603
HiJack and LYTHSPD.
HAHA! I snuck away some free time to post a reply!
I have worked with a few OEM manufactures of TPM sensors. (I work for a company that builds the machines that builds the sensors). Nearly every OEM uses a very similar (internally) sensor that uses a 5 year battery. I have seen a few use a 7 year battery, but not many. I am sure they have their reasons.
The 5 year limit is for the sensor being constantly inflated. Like I mentioned before, if it goes below a certain pressure, it will go into a low power mode which should lengthen the life of the battery considerably. You should be able to deflate and store the tires horizontally without any problems.
Old 07-10-2008, 03:03 PM   #604
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
So what happens when this kit is eventually discontinued and there is no way to get replacement sensors?
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 07-10-2008, 05:26 PM   #605
Lok
Lok's Avatar
5 years from now they should have tires that re-inflate themselves so I would think you won't need them anymore .
Old 07-10-2008, 05:30 PM   #606
bes51659's Avatar
bes51659 is on a distinguished road
So its because of the low power mode in low pressure I don't get data with TPMS doctor with the kit on my desk? (doctor version 1.2, connection is green)
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Old 07-10-2008, 05:46 PM   #607
rgarjr's Avatar
rgarjr is an unknown quantity at this point
Either we can try and make another type of sensor work with the unit or we throw away the TPMS PIC/Receiver board away..
Or
Like some of these guys say, after 5 yrs or so we will have our little flying cars and we wont need tires j/k
My carpc worklog
rgarjr is offline   Reply With Quote
Old 07-10-2008, 05:52 PM   #608
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
In five years we'll all be driving electrically powered flying cars.
Enforcer is offline   Reply With Quote
Old 07-10-2008, 06:31 PM   #609
bes51659's Avatar
I know now that sensors have unique id's (explained in message format description in ..hrm.. post 1) and that id 1-5 labeled sensors can be used in any combination without getting a conflict. The id tag is only a way of remembering which wheel goes where.
LTHDPS quote "If you use the TPMS Doctor, you should be able to see what the sensor IDs are after you teach them."
Q1) So the sensor id 1-5 is stored in the sensor? I did not see the ID in the message description. When is it sent? So the teaching process involves writing to EEProm in sensor? And it does not envolve saving info in PC register or similar? Learning is sensor only and PC is stupid as ever?
Q2) Since I have not seen or preformed the learning process yet I just want to get confirmation that learning is not a pairing of ID 1-5 and wheel position. It is pairing of unique serialno and wheel position. The wheel position is what gets stored in the sensor. Correct?
Q3) I got contact with one sensor (id1) on TMPS doctor 1.2. Why did I get sensor data from one sensor in ambient pressure and not the others?
Q4) I will use RR but I am currently just testing the hardware. Is there a standalone app/skin that will work and look as the RR skin?
PS. Should maybe a thread be started in the "own inventions" subforum or a sticky? I am sure everything has been asked more than once. But finding it is like searching for a needle in a hairstack.
Old 07-11-2008, 03:29 AM   #610
allypally is an unknown quantity at this point
Robby,
This is the TMS skin.
It was working for awhile, but now the Spare is not displaying.
RoadRunner Skin
RRScreen "TMS"
I01,204,327,115,153,"TMS_ALERT_FL:B"
I02,73,269,98,138,"TMS_ALERT_FR:B"
I03,497,273,63,99,"TMS_ALERT_RL:B"
I04,363,236,56,89,"TMS_ALERT_RR:B"
"TMS_ALERT_ST:B"
I05,644,28,138,161,"TMS_ALERT"
I06,694,514,25,15,"TMS_SILENT:B"
B01,630,507,97,86,"TMS_SILENT",""
B02,727,507,67,86,"EXIT",""
L01,433,37,173,28,255,120,0,28,"BMW-E36","TMS_PRESSURE_RR","LEFT"
L02,430,80,123,28,255,120,0,28,"BMW-E36","TMS_TEMPERATURE_RR","LEFT"
L03,30,37,173,28,255,120,0,28,"BMW-E36","TMS_PRESSURE_FR","LEFT"
L04,30,80,123,28,255,120,0,28,"BMW-E36","TMS_TEMPERATURE_FR","LEFT"
L05,433,491,173,29,255,120,0,28,"BMW-E36","TMS_PRESSURE_RL","LEFT"
L06,433,535,123,28,255,120,0,28,"BMW-E36","TMS_TEMPERATURE_RL","LEFT"
L07,30,491,173,29,255,120,0,28,"BMW-E36","TMS_PRESSURE_FL","LEFT"
L08,30,535,123,28,255,120,0,28,"BMW-E36","TMS_TEMPERATURE_FL","LEFT"
L09,623,251,173,28,255,120,0,28,"BMW-E36","TMS_PRESSURE_ST","Spare"
L010,626,289,117,28,255,120,0,28,"BMW-E36","TMS_TEMPERATURE_ST","SPARE"
"TMS_ TEMPERATURE_ST"
Y01,"SLIDER_BATTERY\SLIDER_*.gif"
S01,559,77,47,34,559,77,47,34,H,01,"",0,"TMS_BATTE RY_RR",""
S02,156,77,47,34,156,77,47,34,H,01,"",0,"TMS_BATTE RY_FR",""
S03,559,532,47,34,559,532,47,34,H,01,"",0,"TMS_BAT TERY_RL",""
S04,156,532,47,34,156,532,47,34,H,01,"",0,"TMS_BAT TERY_FL",""
S05,748,289,47,34,559,77,47,34,H,01,"",0,"TMS_BATT ERY_ST",""
"TMS_BATTERY_ST",""
END
allypally is offline   Reply With Quote
Old 07-11-2008, 06:29 AM   #611
Confusion Master
Enforcer's Avatar
remove "spare" from the tooltips.
Old 07-11-2008, 06:52 AM   #612
I was under the impression the the "Left" and "spare" were just comments. How would that effect the display?
Old 07-11-2008, 07:36 AM   #613
Confusion Master
Enforcer's Avatar
The tooltips/comments are also used for alignments, so left in there aligns a label to the left, right aligns it to the right, center centres it.
However having something unexpected in the might cause a problem and it is more likely with an extension plugin label than a standard label.
Old 07-11-2008, 07:40 AM   #614
Thanks for the explanation. I will give it a try
Old 07-11-2008, 07:42 AM   #615
Confusion Master
Enforcer's Avatar
BTW It's only a suggestion not a definite solution
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
