Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 08-06-2008, 09:03 AM   #691
LYHTSPD is on a distinguished road
Quote: Originally Posted by Robby BMW View Post
@ wiggy, goosey, Dj-[NRG], mrbean_phillip and all those who have problems performing the "learn" procedure, I've found an issue with the USB buffer that causes an abnormal termination of the procedure.
The problem has been fixed in the last releases (1.30) of my two programs TPMS Doctor and RRTMS, so please download them, upgrade your systems and let me know if this solve.
As usually, I recommend everyone to terminate all the programs that have direct access to the TPMS interface, like RoadRunner, Centrafuse and TPMS Doctor, before to launch RRTMS Config and to perform the "learnig" procedure.
I am glad to hear that you may have found the culprit. Thanks again for all your hard work on this Robby!
LYHTSPD is offline   Reply With Quote
Old 08-06-2008, 10:31 AM   #692
Lok
VENDOR - Portal Media
Lok's Avatar
Lok is an unknown quantity at this point
Quote: Originally Posted by juve021 View Post
Just to let anyone who is still looking for a 3rd eye TPMS know, Viva Performance has them in stock again: http://www.vivaperformance.com/catal...roducts_id=444
Hey guys,
If you are looking for a kit we are working on one right now. I think I posted this link somewhere in the thread but i know there's like a million posts now so here it is again if you can't find it. (http://www.portalmediapc.com/forums/showthread.php?t=10) Its cheaper than the 3rd eye (less than $200) and you don't have to hack together a system as it will be all on a single circuit board (we are going surface mount on the components as well to speed up production and reduce costs). I will be selling the sensors too as part of a complete USB kit (I am getting them directly from malayasia). Also Robby is going to help me with getting the chips programmed so you don't have to worry about having a different unit than the rest of us as it will work exactly the same. Right now we are working on getting a waiting list together for the initial run(only 8 spots are left) and those buyers will get the units at a bargan price, but after that MP3car will most likely be handling the online sales and the price will be significantly higher.
Lok is offline   Reply With Quote
Old 08-06-2008, 10:37 AM   #693
Quote: Originally Posted by Lok View Post
Hey guys,
Sounds good Lok! Thanks for taking this thing by the reigns and getting it moving in the right direction.
Old 08-06-2008, 11:43 AM   #694
DigitalVampire is an unknown quantity at this point
Excellent Lok...The completely integrated USB kit would be very welcomed. You have a PM.
The 3rd eye TPMS unit was way too over-priced. TPMS kits from other vendors are available for $60-$100 and offering more or less the same functionality. But since the USB TPMS PIC was based on the 3rd Eye kit, we were pretty much stuck with it.
www.dentalteam.org
DigitalVampire is offline   Reply With Quote
Old 08-06-2008, 02:11 PM   #695
wiggy's Avatar
wiggy is an unknown quantity at this point
I second that
wiggy is offline   Reply With Quote
Old 08-06-2008, 02:14 PM   #696
Quote: Originally Posted by wiggy View Post
I second that
Did Robby's update fix your issue Wiggy?
Old 08-06-2008, 02:24 PM   #697
wiggy's Avatar
I have not got the usb board back yet ( on its way as we speak) , but as soon as it arrives i shall try the new software ...fingers crossed
Old 08-06-2008, 04:39 PM   #698
Lok
Lok's Avatar
I am having problems with the learning procedure as well using Dejans board and a hacked 3rd eye...I know Robby has updated the Doctor and the RRTMS but I am using CF however and I was wondering if there was a way around this issue without me having to load up RR...
Old 08-06-2008, 05:29 PM   #699
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
Hi,
With new TPMS doctor work ok? Im tell that Im report this problem to Wolfgang(He develope plugin for CF) and he answer me that he will look in code...
_Dejan_ is offline   Reply With Quote
Old 08-07-2008, 08:07 AM   #700
bes51659's Avatar
bes51659 is on a distinguished road
I have just installed the 3'd eye sensors on my wheels.
[media]http://web.comhem.se/mulle4/tpms_sensor.jpg[/media]
Quality is not impressive. I manage to destroy one sensor.
[media]http://web.comhem.se/mulle4/brokensensor.jpg[/media]
The instruction manual was not specific on how to place washers. I did not use my sense, and placed alu washer on wrong side first as I tried to do it as I could see from picture in manual. Alu washer goes on the outside...
The aluminium nuts also loose shape once fitted, and it is a bit difficult to refit the tyres. At least the low profile 18" I've got on my E46 BMW.
The washer for the insex nut at the sensor also gets deform once mounted.
The pin for holding the pin still when fastening the nut did not fit 3 of the 5 sensors I tried.
In short, you get one chance to do it right and you cannot refit a sensor once used.
A bit disapointed of the poor quality and I have not yet got to the point of learning sensors and receiving data...
One question: Without looking into the spec of the pic the learning problem must be in the writing/erasing of EEProm/flash in the pic. Or possibly some powersupply issue as write cycles might require a second voltage supply. What do you think? Is there a new pic sw in the pipe?
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Old 08-07-2008, 12:15 PM   #701
Lok
Lok's Avatar
I had my sensors professionally installed at Discount Tire Co. They had no problems in the installation but I was told that if I were to hit a large pothole I would most likely break a sensor (maybe all of them). This was due to the fact that I have ultra low profile tires and also because the sensors didn't sit flat against the Rim (the way my enkies are designed they couldn't) they actually were sticking out.
By the way I don't think anyone answered this yet but is there a way to do the learning procedure without CF or RR?
Old 08-07-2008, 12:31 PM   #702
bes51659's Avatar
Yes, I had a pro break my sensor too :-)
[media]http://web.comhem.se/mulle4/tpms_wheel.jpg[/media]
€100 including stabilizing.
Old 08-07-2008, 12:37 PM   #703
On a positive note, we got to know what is inside the sensor
Do you have detailed snapshots of the sensor board...I'm curious to know the transmitter chipset.
www.dentalteam.org
Old 08-07-2008, 12:43 PM   #704
Robby BMW's Avatar
Robby BMW is on a distinguished road
As I said in this post, it is possible to perform the learning procedure with the configuration tool provided with the RoadRunner plugin, even if you use Centrafuse.
There isn't need to install RoadRunner, just download the last release of RRTMS plugin from here end extract the program "RRTMS Config.exe".
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 08-07-2008, 12:50 PM   #705
Robby BMW's Avatar
No, the problem was due to a bug in the management of the USB input buffer.
Maybe you have confused the program flash memory, that require a second voltage supply to be programmed with the internal EEPROM, that can be written and erased directly by the program.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
