Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 08-07-2008, 12:52 PM   #706
WuNgUn's Avatar
WuNgUn is on a distinguished road
Quote: Originally Posted by Robby BMW View Post
As I said in this post, it is possible to perform the learning procedure with the configuration tool provided with the RoadRunner plugin, even if you use Centrafuse.
There isn't need to install RoadRunner, just download the last release of RRTMS plugin from here end extract the program "RRTMS Config.exe".
And once the RRTMSconfig is setup, the Centrafuse plugin has access to this config info, and no further setup is needed (for CF)?
WuNgUn is offline   Reply With Quote
Old 08-07-2008, 12:55 PM   #707
WuNgUn's Avatar
This input buffer issue is not related to the audio stuttering issues some of us are having with the TPMS plugged into the USB port?
Old 08-07-2008, 01:02 PM   #708
Robby BMW's Avatar
Robby BMW is on a distinguished road
Don't pay attention to the other settings, just use the "Learn" buttons to pair the sensors.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Old 08-07-2008, 01:12 PM   #709
Robby BMW's Avatar
Does the problem occur when the TPMS is simply plugged into the USB port or only when the plugin is running?
Old 08-07-2008, 01:19 PM   #710
WuNgUn's Avatar
Just having it plugged into the USB port...
I haven't tried running it yet (still on the bench)
Old 08-07-2008, 02:29 PM   #711
Robby BMW's Avatar
Then is not a buffer problem, if the sortware is not running, there is no data exchange between the TPMS and the PC.
It sounds most like an IRQ conflict between the USB and the soundcard.
Old 08-07-2008, 05:03 PM   #712
Lok
VENDOR - Portal Media
Lok's Avatar
Lok is an unknown quantity at this point
Sorry for not searching Robby . It looks like I may have a sensor problem because I used the RR config utility with no luck. Tommorrow I am going to have the sensors checked and also I am going to take a couple of additional tires (regular not low profile) and have sensors mounted for testing. If there is a problem after that I guess I'll need to have a look at the reciever board... I am still using the 3rd eye hacked with the solder-on daughter board.
Lok is offline   Reply With Quote
Old 08-07-2008, 05:10 PM   #713
bes51659's Avatar
bes51659 is on a distinguished road
Quote: Originally Posted by DigitalVampire View Post
Do you have detailed snapshots of the sensor board...I'm curious to know the transmitter chipset.
The chips, apart from what I think is the sensor itself, is inside that white stuff. Probably to make it more dureable for vibrations. No way to detect whats inside. But I get the feeling it is discrete and not a chip(!)
No, the problem was due to a bug in the management of the USB input buffer.
Maybe you have confused the program flash memory, that require a second voltage supply to be programmed with the internal EEPROM, that can be written and erased directly by the program.
As I said I have not read the spec of the pic. But I am glad that it was a PC sw issue and not a PIC sw issue :-)
Looking forward to try it out this weekend!
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Old 08-08-2008, 12:02 AM   #714
WuNgUn's Avatar
Now why didn't I think of that? Even though it does this regardless of which USB port I use...
Maybe turning off IRQ assignment for all onboard USB ports? Or manually assigning them (if the hardware shows up in the BIOS that is).
Thanks for the tip...I'll look into it.
Old 08-08-2008, 12:09 AM   #715
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by bes51659 View Post
I have just installed the 3'd eye sensors on my wheels.
[media]http://web.comhem.se/mulle4/tpms_sensor.jpg[/media]
Quality is not impressive. I manage to destroy one sensor.
[media]http://web.comhem.se/mulle4/brokensensor.jpg[/media]
The instruction manual was not specific on how to place washers. I did not use my sense, and placed alu washer on wrong side first as I tried to do it as I could see from picture in manual. Alu washer goes on the outside...
The aluminium nuts also loose shape once fitted, and it is a bit difficult to refit the tyres. At least the low profile 18" I've got on my E46 BMW.
The washer for the insex nut at the sensor also gets deform once mounted.
The pin for holding the pin still when fastening the nut did not fit 3 of the 5 sensors I tried.
In short, you get one chance to do it right and you cannot refit a sensor once used.
I think we have already discussed this and decided that you don't need to use the valves supplied with the system. The actual sensor is the black bit and as long as it is secure in the wheel/tyre it will work.
Anchoring it to the valve is just a convinient way of securing it.
Enforcer is offline   Reply With Quote
Old 08-08-2008, 03:03 AM   #716
bes51659's Avatar
Sorry if I missed that (and other things) given that the thread is now 48 pages (!)
Anyone tried a different assembly? For the balanceing of the wheel to work it has to stay put. Epoxy?
Old 08-08-2008, 08:59 AM   #717
Confusion Master
Enforcer's Avatar
48 pages, puh! that is nothing you should see some of the skin and plugin threads.
O, and it might have been in a different thread about the TPMS so don't beat yourself up about it
Old 08-08-2008, 09:14 AM   #718
WuNgUn's Avatar
I would think good quality, double-side tape would work...just put it on a horizontal surface. That way, with the wheel spinning, centrifigal force will 'push' it harder in place.
On that note, I find the valves that come with the kit to be different somehow. I've gone to two service stations for air, and both time the air just leaks out past the nozzle instead of going into the tire!
I gotta find somewhere to get air!
Old 08-08-2008, 09:41 AM   #719
Lok
Lok's Avatar
When I go to the tire shop in a bit I will see if I can get the sensors mounted with tape to rim instead of messing around with the valve stem. I have some really nice industrial grade high temp stuff that should work.
Old 08-08-2008, 09:45 AM   #720
Confusion Master
Enforcer's Avatar
I think some of the OEM ones are strapped to the wheel with the strap going all the way around the wheel.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
