08-26-2008, 03:59 AM
#736
1) Yes used the latest versions
2) How do you clear the data ? It's not obvious
3) I'll try this and see what happens....
4) I've had a read through all of the pages, but couldn't see anything obvious.
08-26-2008, 04:06 AM
#737
You've should have found how to reset values with TPMSDoctor.
I've also read thru the pages and put links to the most interesting posts at bottom of page. Amongst other things how to reset learning and data.
08-26-2008, 04:24 AM
#738
2) Hold Shift button on your keyboard then click Robby's logo.
08-26-2008, 04:34 AM
#739
Wow thank you so much bes51659, that is very very useful, I'll give this a go tomorrow and see how I get on.
08-26-2008, 10:49 AM
#740
Quote: Originally Posted by f1racr
Robbie, I'm hoping you can help me out.
I've got some boards and your PIC's from LYTSPEED and recently got my 3RD Eye kits and put them all in place, but I'm not sure on what I should be seeing.
I've downloaded your TPMS Doctor and it seems to see the sensors, but I can't really tell.
I've put one of the sensors into a small sprayer so I can pump it up to simulate pressure in the tyre as I don't want to mount it on the car yet.
1 of the sensors shows 1.8psi, the other 3 show - .4psi which in itself is interesting since that means they're in vacuum, but it's so small I'm not worried.
When I try and run the TPMS config tool and select pair, then pump up the sensor, nothing happens........... I don't know why one sensor shows higher than the others.
Only thing I can think of is that when I was soldering the boards in place, there was a resistor I think in the place where one of the pins from the PCB needed to be soldered. I'm not sure if I need to solder on one side or the other side of this resistor, I'll show a picture below........
Can you tell me the best process I can go through to test my sensors.
I have 3 kits in total, 3 USB interfaces and 12 sensors to sort out.
You should remove the small resistor and solder JP1 on both sides.
_______________________________________
Car installation 95% [ ■■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
08-26-2008, 05:33 PM
#741
Great thanks Robbie.
08-27-2008, 01:00 AM
#742
Thank you to all who helped........... all 3 systems are working now and I have another 4 on the way from Dejan so I know what I'm doing now........
Ironically it seems that keeping the receiver well over 1 metre away from the sensors gave the best results....... too close and it seems to get confused.
Thanks again to all who gave assistance.
08-31-2008, 07:43 PM
#743
did anything come of this, are the board available to buy? as i have no idea what to do very interested in the system but dont have required skills to solder/make board ect
09-03-2008, 11:00 AM
#744
VENDOR - Portal Media
New TPMS PCB
Hey guys, here are some pics of the PCB we are working on. I will have pics of the whole production process shortly for those of you that are interested in the PCB assembly production process.
09-03-2008, 11:42 AM
#745
Wow.
I'd decided against adding this feature as it wasn't very cost effective but i think now its cheaper and an all in 1 kit i'll reconsider.
P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,ROADRUNNER, iGo8, Custom Freedom 2.1
09-03-2008, 01:29 PM
#746
Lok, I am having trouble seeing your pictures. Anyone else having issues?
09-03-2008, 01:48 PM
#747
Good panelisation... How many layers is the board?
No issues seeing the panelised PCB snapshots.
09-03-2008, 01:55 PM
#748
Another question.
I see that the PIC is an SMD now.
Nice choice from a production point of view, but how is the fimware upgrade planned if Robby releases a firmware fix some time down the lane? Can this be done via USB?
09-03-2008, 03:40 PM
#749
Quote: Originally Posted by DigitalVampire
Another question.
There is a 6 pin header used for programming and reprogamming if needed, only problem is that you will most likely have to send them in if they need to be reprogrammed as I am sure most of you don't have a progammer lying around and also because Robby would like to have control over the firmware. I don't think the current design will support reprogamming via USB but you have to ask Robby about that. Oh and its just a double sided board, there isn't much on the back though.
LYHTSPD if you can't see the pictures here then check either Centrafuse forums or Portal Media forums as I have them posted there as well.
09-04-2008, 12:44 AM
#750
It ain't easy being a green moderator
Location: Steps out the front of Henson's workshop or Sydney
have you got an idea on the price including sensors yet?
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
| Thread Tools |
| Display Modes |
Linear Mode
