Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 09-06-2009, 03:23 AM   #1051
steven765 is an unknown quantity at this point
Might anyone have a close up of the soldering job to connect the pin at R9? I'm about to cut my board and want to A: make sure I cut it correctly, and B solder the pin on the correct side of the resistor.
Reason I ask is Robby's original pic it appears to bridge the resistor so I'm not sure.
Thanks,
steven765 is offline   Reply With Quote
Old 09-06-2009, 03:29 AM   #1052
f1racr is an unknown quantity at this point
I asked the same question when I first made mine up. If it's the resistor I think you mean then you can remove it as it's not needed which is why Robbies pics seemed to show him bridging over it, it's not needed was the answer I got and mine didn't seem to work when I left it in at first now they do so...........
f1racr is offline   Reply With Quote
Old 09-06-2009, 06:19 AM   #1053
lez
lez's Avatar
lez is on a distinguished road
ok i've not posted on this thread in agesssssss, but i did buy the system, its worked in my car fine, i now want to add the usb option.
whats best way to move on, who if anyone is doing the boards/pics etc.
dont make me read back through all these pages lol, i've had the kit a year since the initial start of the thread, too much reading!
lez is offline   Reply With Quote
Old 09-27-2009, 02:12 PM   #1054
WuNgUn's Avatar
WuNgUn is on a distinguished road
Hey Alok...
System has been functioning beautifully...until today.
It started telling me the front right (one of the new sensors I bought from you) sensor battery is dead...no pressure showing, and reading 120 degrees celcius.
Could the sensor actually be toast? Or maybe a software issue?
WuNgUn is offline   Reply With Quote
Old 09-27-2009, 02:35 PM   #1055
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Try spreading some butter on it and see how it tastes.
Enforcer is offline   Reply With Quote
Old 10-01-2009, 04:52 PM   #1056
Lok
VENDOR - Portal Media
Lok's Avatar
Lok is an unknown quantity at this point
Hey Alok...
I have two suggestions for you:
1.Try re-learning the sensor and see if starting picking up correct data, there is no way the battery can be dead that quickly, even the sensors I use for testing for the last two years still haven't run out.
2. The sensor may have actually broke from hitting a speed bump, incorrect installation, or a pothole.
Lok is offline   Reply With Quote
Old 10-01-2009, 07:55 PM   #1057
WuNgUn's Avatar
Hahaha...butter...funny!
I'll try a relearn and cross my fingers!
Thanks...
Old 10-12-2009, 05:07 PM   #1058
WuNgUn's Avatar
Just a FYI..I relearned the 'bad' sensor, and it picked up and started functing correctly...awesome!
Old 10-17-2009, 08:03 AM   #1059
Kosti is on a distinguished road
Thinking of adding this to my carpc setup, just curious to know the following, as not 100% if it's been asked or mentioned..
[1] How long is the battery life of the sensors and can they be changed
[2] Will having WiFi, BT, GPS, RadioTuner affect operations of the USB TMS
[3] Will these fit to any car wheel(RIM)
[4] Anyone got these in Sydney Australia, where's the best place to buy besides mp3store?
[5] Has anyone invented the use of the rotating wheel to charge up the batteries?
[6] Will a sensor know which tire it's in? Maybe in future versions, if so when?
Kosti
Kosti is offline   Reply With Quote
Old 10-17-2009, 10:18 AM   #1060
Confusion Master
Enforcer's Avatar
[1] Approx 5-6 years , no
[2] Possibly, I have noticed seems WiFi seems to affect it, but have not 100% proved it yet
[3] Would say no, because there bound to be at least one type of wheel it won't fit.
[4] n/a
[5] Not really worth considering the batts last 5-6 years.
[6] It does when you program the receiver
Old 10-17-2009, 08:08 PM   #1061
Thanks for the reply!
[3] What options are available if it dont suit a wheel?
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
Old 10-17-2009, 08:26 PM   #1062
Confusion Master
Enforcer's Avatar
Well the sensor fits onto the supplied valve, which should fit most wheels, but I can cases where it won't due to the size and the way the wheel maybe made.
I guess you can try and strap it to the wheel.
or somehow stick it, but that would be highly unreliable and you may find you end up with a rattle in your wheel.
Old 10-24-2009, 01:28 PM   #1063
lacning74's Avatar
lacning74 is an unknown quantity at this point
I've been having to relearn my sensors more and more it seems. They get stuck on readings for days or read super high incorrect PSIs and temps. After master reset and relearn the readings work again.
This is becoming a pain. I would like to install and forget.
2007 Mini Cooper eee PC worklog
lacning74 is offline   Reply With Quote
Old 10-24-2009, 03:14 PM   #1064
vicky_obee's Avatar
vicky_obee is on a distinguished road
Hi
Can some 1 pls help me with the TPMS software ( by Roby )
well the sensors work fine and shows the press and temp...
but for some reason i am not getting the Batt indication ( it shows empty ) nor am i getting the audio warnings ( of course its not mute )
Can some 1 pls post in there copy of this working INI file
Vicky
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
vicky_obee is offline   Reply With Quote
Old 10-24-2009, 06:08 PM   #1065
CannonBaller is an unknown quantity at this point
Quote: Originally Posted by vicky_obee View Post
Hi
Vicky
You should write out everything you did in step-by-step format. And what skin, rr version, etc..., your running.
At this point no body knows what you did or didn't do.
This way we can fill in the blanks.
CannonBaller is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
