Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 10-12-2007, 12:47 PM   #1
Robby BMW's Avatar
Robby BMW is on a distinguished road
Lightbulb Custom USB tyre pressure monitoring interface
This threads explains how I've made my custom USB tyre pressure monitoring system by hacking this aftermarket kit bought on eBay.
The first step was to detect the RF transmission encoding method used by the sensors.
To do this it would have been required a very expensive logic analyzer, but fortunately I found this nice program that allows to simulate it (albeit with many restrictions) through the LPT port.
So the first thing was to open the display/receiver unit provided with the kit and, after having identified the receiver, start analyzing the data sent by the sensors.
- the display unit -
- the display unit opened -
- the receiver part -
After many samples, I deduced that the encoding method used from the system is a sort of PWM format (Differential Manchester) with dT (basic pulse element) time of about 50 μs and a bit period of 2xdT (about 100 μs).
Discovered this, I’ve noticed that the whole data packet consist of 12 bytes (96 bits) organized in this way:
Preamble (16 bits) - The preamble is a series of 15 logic ‘1’ bits followed by a single logic ‘0’ bit (FFFE in hexadecimal), used to recognize the RF transmission as a valid TX message.
Transmitter ID (32 bits): The 32 transmitter ID bits are used to uniquely identify each sensor.
Pressure (8 bit): The tire pressure in kPa is obtained by multiplying the unsigned binary value of this byte by 2.5 and subtracting 100 (the atmospheric pressure) from the result.
Temperature (8 bits): The temperature in °C is obtained by subtracting 40 from this unsigned binary value.
Battery (8 bits): The 7 least significant bits indicates the battery condition as percentage (100 indicate the 100% of charge).
Sensor state (8 bits): The bits 0 and 1 of this byte contains the following information:
00 = Initial mode (Pressure is measured every 0.85 seconds and data is sent every 0.85 seconds. This sequence is repeated 256 times)
01 = Normal mode (Pressure is measured every 3.4 seconds and data is transmitted every 60 seconds)
10 = Pressure alert mode (Pressure is measured every 0.85 seconds and data is sent every 0.85 seconds. This sequence is repeated 256 times)
11 = Temperature alert mode (If the temperature exceeds 120°C, the sensor device enters into the same measurement and transmitting pattern as the pressure alert mode)
CRC (16 bits): Implement according to CCITT (0xFFFF) standards.
- the whole data packet -
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Advertisement Sponsored links
Old 10-12-2007, 12:48 PM   #2
Robby BMW's Avatar
After a relatively long time elapsed analyzing the data, the goal was to develop a device able to perform some operation such as:
- Learn the univocal sensor ID (like when a pairing is established between two Bluetooth devices). To be used during the first installation in the car or if a sensor is replaced with a new one.
- Read the data sent from every sensor and after an analysis to verify the validity (correct sensor ID and correct CRC), store them waiting a PC request. Since there is no way to know when a transmission happens, it is essential do this in real time.
- Handle the communication with the PC.
In addition, the device should have been easy to connect to the PC, small enough to be comfortably placed everywhere in the car and possibly be self-powered.
My choice was to use a PIC 18F2550, a Microchip microcontroller whit USB 2.0 compliant features, internal E2PROM memory and able to work with a clock oscillator up to 48 MHz.
The first attempt has been to use an SMD hybrid module operating on the frequency of 433,92 MHZ, but after various tests with some modules available on the market, I've noticed that the best result was with the original receiver embedded in the original display module provided with the TPMS kit, so I've decided to cut out it and use it in my hardware.
- the display unit with the reciver part removed -
The schematic of the circuit is relatively simple and doesn't need further explanation, only a brief note about the transistor used to boost the signal coming out from the receiver, I've used a BC547 (European), but it isn't critical and can be replaced with an equivalent general purpose transistor like a 2N5818 (USA).
- schematic -
- copper side -
- components side -
- 3D view of the PCB -
Old 10-12-2007, 12:49 PM   #3
Robby BMW's Avatar
- the real device -
- the real device (copper side) -
The most difficult (and funny) part of the whole work was the development of the firmware for the microcontroller that, as described above, it should have analyzed the data received from the sensors in real time and, at the same time, to handle the data exchange with the PC.
This has led at the creation of an USB HID device, a particular device that doesn't require a driver installation on the PC where it will be connected, like a keyboard or a PS/2 mouse.
A Plug & Play device that make easy the development of software (stand-alone programs or plug-ins for the various Front Ends available on this forum) without the aid of special APIs.
In order to facilitate the communication between the device and PC, I have developed a simple communication protocol.
Basically the device waits for a request from the PC (1 byte) and returns the information required (4 byte).
The following table shows the protocol details:
00H (0) Abort any pairing request (see below) --> Returns: Nothing
01H (1) Sensor 1 pairing request --> Returns: Nothing
02H (2) Sensor 2 pairing request --> Returns: Nothing
03H (3) Sensor 3 pairing request --> Returns: Nothing
04H (4) Sensor 4 pairing request --> Returns: Nothing
05H (5) Sensor 5 pairing request --> Returns: Nothing
10H (16) State of a pairing request --> Returns: X,0H,0H,0H
Where X is the number of the sensor to be paired, or 0 if the pairing has been completed.
21H (33) Sensor 1 data request --> Returns: P,T,B,S
22H (34) Sensor 2 data request --> Returns: P,T,B,S
23H (35) Sensor 3 data request --> Returns: P,T,B,S
24H (36) Sensor 4 data request --> Returns: P,T,B,S
25H (37) Sensor 5 data request --> Returns: P,T,B,S
Where:
P is the pressure in kPa obtained by multiplying the unsigned binary value of this byte by 2.5 and subtracting 100 (the atmospheric pressure) from the result.
T is the temperature in °C obtained by subtracting 40 from this unsigned binary value.
B is the battery condition, the first seven bits of this byte indicate the percentage of charge.
S is the operating state of the sensor, 00H is storage mode, 01H normal mode, 02H pressure allert mode or 03H for temperature allert mode.
As example of how to use this device in your code, you can download a RoadRunner plugin and its source code here.
It is also in development a plugin for Centrafuse (thanks Wolfgang). For more information, see here.
- the final result-
Related downloads:
Schematic & PCB (created with Eagle CAD)
Parts list & PCB scaled 1:1 (PDF - Adobe Reader)
RoadRunner PlugIn (Bynary and source code)
Centrafuse PlugIn (Developed by Wolfgang)
Old 10-12-2007, 01:02 PM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
You have another PM.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-12-2007, 01:55 PM   #5
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
friggin awesome subscribed
turbocad6 is offline   Reply With Quote
Old 10-12-2007, 02:07 PM   #6
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Enforcer is online now   Reply With Quote
Old 10-12-2007, 03:02 PM   #7
BrianCheung is an unknown quantity at this point
you are ******* awesome. Thank you
BrianCheung is offline   Reply With Quote
Old 10-12-2007, 04:22 PM   #8
ilyassx's Avatar
ilyassx is on a distinguished road
Great man!!
The old setup http://flickr.com/photos/ilyassx
The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
Jetway J7F2WE VIA C7 1.5 GHz
512 DDRII 533
3.5" SATA2 H.D.D 200GB
M1-ATX
ELM327MS OBDII
Creative Audigy 4
PROGRESS:[########-]90%
ilyassx is offline   Reply With Quote
Old 10-12-2007, 05:44 PM   #9
Nomader's Avatar
Nomader is on a distinguished road
robby do you think you can somehow market those?
i am sure there will be huge interest..
Nomader is offline   Reply With Quote
Old 10-12-2007, 06:31 PM   #10
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
Damn, I wish I could integrate my SmartTire monitoring system like that.
Awesome. Just plain awesome.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 10-12-2007, 07:14 PM   #11
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Subscribed!
Does the one you have, have the option for the remote display? I think it was the 2nd gen of it that had this and the first had the lcd integrated. I wouldn't be surprised if it communicated with the lcd head via serial communication. I've been meaning to check it out forever but my money/time has been taken up elsewhere.
update
Check out this thread. Maybe ask pastypyro how he made out. It appears to use a serial comm chip for communicating with the display.
shotgunefx is offline   Reply With Quote
Old 10-13-2007, 02:05 AM   #12
sstylos is on a distinguished road
I would suggest to open a donation thread via paypal.
An open source product is allways better .
What do you think?
sstylos is offline   Reply With Quote
Old 10-13-2007, 06:13 AM   #13
fatman1121 is an unknown quantity at this point
that bloody awesome, id love to get me some of them, they'd make tyre pressure monitoring and changing so much easier for 4x4 on sand drivin
fatman1121 is offline   Reply With Quote
Old 10-13-2007, 10:19 PM   #14
inh
inh is an unknown quantity at this point
Sooo cool Robby! Im seriously contemplating buying one of those same exact kits and putting it together, provided you would share your PIC and PC code =]
I can only imagine how long it took to decipher the data stream...
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 10-14-2007, 01:51 AM   #15
turbocad6's Avatar
yeah man, I've been trying to find that same kit in the us but haven't found anything like it, I don't know if the vendor you bought from will ship to the us, do you have any manufacture info or any other info of where I could find that same tpms setup?
I think if you just build the interface & sell it a lot would want it, I would buy it for sure
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
USB self powered hub, which one htsource General Hardware Discussion 5 07-26-2007 04:31 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
USB Earthmate - patch for gpsd support dignome GPS 4 04-05-2005 11:44 AM
Looking for feedback on initial components, USB vs. PCI, power related mostly S4Per Newbie 4 04-06-2004 10:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
