Go Back   MP3Car.com > Mp3Car Technical > Hardware Development > Portal Media Car PC Gadgets and Accessories
Old 11-06-2009, 08:08 AM   #16
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
is everyone having problems with the valve cores leaking?
ThunderStick is offline   Reply With Quote
Old 11-06-2009, 11:20 PM   #18
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
I'm still waiting on replacements promised at the Baltimore AFK.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 11-13-2009, 09:32 AM   #19
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Add me to the list of working setups!
RR Screen (cant wait for the CF3 version)
Valve pic
And lastly, the receiver, placed under the armrest
I do have a problem though... specifically sensor number 1 will not learn. I completely deflated/inflated my tire with RRTMS learning and it did nothing. You can see in my screen picture that the value for that front left tire is outta wack.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-13-2009, 11:04 PM   #20
GizmoQ's Avatar
Did you run TPMS Doctor.exe and it recognized sensor 1? When you learned it did the banner go away? If so, just wait a day for all the sensors to recycle to normal mode. Then just relearn the one sensor by deflating it, once the banner goes away pump it back up and wait 15-30 minutes for it to return to normal mode. Should work right from then on.
Otherwise you got what we call a "lazy" sensor. Moving the receiver to d different location sometimes fixes it, but no one has a definitive solution.
Old 11-15-2009, 12:21 PM   #21
Terminal flasher
yes it recognizes it, and it seems to get the very first reading from the sensor each time. but 90% of the readings after that miss. I've moved the receiver all over the car to no avail. Lazy sensor indeed. Spose when i have some cash i'll swap the spare sensor with sensor 1
03 Acura RSX Coupe
Old 11-20-2009, 05:45 AM   #22
debugger's Avatar
debugger is on a distinguished road
Does ELM scan software pull data from factory installed TPMS? Can these be used with factory equipment?
http://incarCPU.com
debugger is offline   Reply With Quote
HFP for Linux Bluetooth Hands Free samr7 Linux 87 10-16-2009 12:06 PM
USB recognition issues Brycestro Software & Software Development 0 10-25-2007 11:35 PM
USB Keyboard not working after hibernation XxAndyxX General Hardware Discussion 5 11-11-2005 04:38 PM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 01:07 PM
usb mouse stops working corsamel General Hardware Discussion 3 10-18-2003 06:53 AM
