The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 04-16-2007, 09:09 PM   #1
My Photos: (4)
Carnetix p1900 and mac mini
I hope this is the best place to post this question. Also search hasn't been working for me in the threads so hopefully this hasn't been answered already. So here goes. I am install a mac mini intel based computer in my wrangler. I will be using "Carnetix CNX-P1900 Ver. 2.2 Dual Output 140 Watt 12V DC-DC Regulator" as my converter. Now when i went to the site that makes them i seen some cables you can buy that would allow you to connect the converter and the mac mini together without and splicing(this is good for me because i want to use my mini in the home too without destroying the AC cable) next to those cables it says
(Note: Users of the CNX-P1900 V2.0 regulator and Intel-based mini will need to add a "resistor mod" to their P1900. Please check HERE for the P1900 V2.0 resistor mod). I assume this is me>>>>http://www.carnetix.com/p1900/cables...Mod/index.html
So i am not really positive what the resistor mod is for (I think its for sleep and stand bye mode)and or if it is necessary to have it. Reason being is that I really really don't want to soder things to the inside of my mini. If something goes wrong with it you can kiss my warranty goodbye. So any help would be great! thanks in advance and I can't wait to post my pictures after i am done!
westcoastrocks is offline   Reply With Quote
Sponsored Links
Old 04-17-2007, 07:08 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
I'm not an expert. I've installed a P1900/Mac mini one time.
The Carnetix PSU w/ the MacPac cable kit is ridiculously easy to install.
We did not do the resistor mod, but I believe this allows the Carnetic to sleep and resume normally.
Without doing that, the owner has to press the sleep (or power) button on the Mac after ignition to get it to come on.
I believe this resistor mod is the solution for this user. I would ask people just to be certain.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-17-2007, 08:36 AM   #3
MikeH's Avatar
Vehicle: 2007 Acura RDX
My Photos: (0)
We have cleverly hidden our FAQ page in the Mac support section...
http://www.carnetix.com/forum/showthread.php?t=593
If you have V2.2 you will not need the resistor mod...
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 04-17-2007, 03:50 PM   #4
My Photos: (4)
Oh that is awesome news! thanks a ton
Old 04-21-2007, 11:32 AM   #5
My Photos: (4)
Powering it
One other quick question. Do you think it would be better to steal the power from my head unit to power my inverter or to just run to the battery?
Old 04-21-2007, 06:51 PM   #6
My Photos: (26)
Both, actually.
You need +12v constant (from the battery) and +12v switched by ignition (from the headunit or some other ignition-switched circuit).
My Worklog
Old 04-22-2007, 10:03 PM   #7
My Photos: (4)
I typed that wrong. I did not mean get power from my wire harness from my cd player. I meant that the cd player is tied into the ignition is it not? If so i should be able to splice the yellow wire from the inverter into that wire harness to get it to work. If this won't work then i guess I will have to go searching for the main ignition wire. Let me know if this will work thanks
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
FAQ: Installing a Mac Mini in Your Car Bugbyte The FAQ Emporium 15 06-26-2008 02:24 AM
P1900 alternative power supply for Mac Mini johnsin MacCar 25 12-07-2006 09:05 AM
Carnetix P1900 Ver. 2.2 w/Mac Mini Core Duo - Startup Problems mrclean12 MacCar 13 09-05-2006 11:44 AM
Mini Mac 4 Porsche 944 4thChild MacCar 13 06-20-2006 07:57 AM
FT Carnetix p1900 with 3rd output 5v addon and mac mini cable for Opus 150 skippy911 Classified Archive 0 05-23-2006 05:48 PM
Sponsored Links
Ad Management by RedTyger
