Old 05-16-2007, 10:50 AM   #1
jdiazj1 is on a distinguished road
24 pin motherboard to a 20 pin power supply
Hello, I just purchased a new motherboard but noticed that it has a 24 pin power slot. I was planning on powering it with my dsatx 20 pin power supply. It this possible? What are the extra 4 pins on the motherboard for? I saw an adapter that allows me to connect a 20 to 24 pin
http://www.radioshack.com/product/in...entPage=family
Do I really need this adapter or can i just plug in the 20 pin into the 24 pin and just leave the other 4 pins untouched? And what exactly is the other 4 pins for? I was thinking power for a much faster and power hungry processor?
jdiazj1 is offline   Reply With Quote
Old 05-16-2007, 11:53 AM   #2
MibMib's Avatar
MibMib is on a distinguished road
In Most times you can use it - simply look at connectors - you 'll see that 20pin fully identical to part of 24-pin - simply connect it with right direction and position. Many motherboards works great with it. You can leave the other 4 pins untouched.
4 extra contact uses by very powerfull systems .....
If wires from connector don't takes warm-use it greatly
I also wrote about this problem in user guide of mine Pilot psu with pics of pinouts of connectors.
400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
MibMib is offline   Reply With Quote
Old 05-16-2007, 12:31 PM   #3
Ok, i just did some research and I found out some things... One of the threads here suggests that i can plug in the 20 pin molex into the 24 pin motherboard and just have 4 holes empty and that it works fine but I have a question. The 24 pin molex has 4 extra pins, pin 11 (+12v) , 13 (+3.3v), 21 (+5v), 24 (ground). But on the 20 pin molex, pin 11 is +3.3, 13 is ground, so if i were to plug this into the motherboard, it would get the wrong kind of voltage. So i dont understand why is it that some people say its ok to just plug in the 20 pin into the 24 pin motherboard when its going to be feeding the wrong pins into the board or am i in the wrong here. Can someone please clarify this? thanks
here is the links for the pin out
24 Pin
20 Pin
Old 05-16-2007, 01:26 PM   #4
MibMib's Avatar
You are wrong with pin numbers - look again at your links - it's ok!
pin 11 of 20- pin connector is same the pin13 of 24-pin connector.
Simply download mine user guide http://downloads.pilotpowersupply.com (160 Kb)
And look at Figure 3. of this user guide - I think it will be more clearly for you.
Cheers.
Old 05-16-2007, 01:59 PM   #5
So according to your pdf, i do not need the adapter and I could simply connect the 20 molex into the 24 pin motherboard connection. Ok, that helps thanks. I could save myself those 10 dollars for the adapter...
Old 05-16-2007, 02:20 PM   #6
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
Some will work and some will not. Trial and error i think.
But the extra 4 pins are for additional power or PCI-e i believe..
My Accord CarPC
john05srt4 is offline   Reply With Quote
Old 05-16-2007, 04:46 PM   #7
kamikaze2112's Avatar
kamikaze2112 is on a distinguished road
My Jetway 2ghz works fine with only the 20 pin connector plugged into a 24 pin socket.
kamikaze2112 is offline   Reply With Quote
Old 05-16-2007, 09:15 PM   #8
MibMib's Avatar
Just try it , if it will not work - then by an adaptor, and if you can , please post here results and motherboard's model also.
I am great wondering about your adapter's price
connecting a PSU to a board which doesn't a have 20 pin connector al_kaholik General Hardware Discussion 6 12-02-2006 03:21 PM
Car power supply (battery charger) from old pc supply stimps Power Supplies 8 08-24-2004 08:59 AM
HELP!! Power Supply wont supply power Saab General Hardware Discussion 3 08-28-2000 10:33 AM
power supply buzzing help thing i found... read if u have noise TimW General Hardware Discussion 2 03-22-2000 04:30 PM
Pin outs for AT power supply twins22 General Hardware Discussion 5 11-02-1999 08:01 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
