The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 05-16-2007, 10:12 AM   #1
My Photos: (0)
M1 ATX Problem 5v Rail Under Voltage
I'm having issues with my M1 ATX. It has been working for just under a year. However, recently my carpc has not been booting properly (only boots about 20% of the time), 'no boot device can be found'. I have replaced the Hdd and still had the same issue so I checked the rails of the M1 ATX.
Both rails stayed constant when the engine was on, off and reving. However the 5v rail sometimes starts and stays at 3.9v to 4v resulting in me not booting. But sometimes it starts and stays at 5v.
I'm using a Via EPIA-M Mobo, and Lilliput 7" touch screen and a 2.5" Hdd. So I am well under the max 90Watts. I estimate my peak consumption to be no more than 25W.
Has anyone had this problem before?
does anyone have the schematic so I can find the problem?
Any help is really appreciated!
Thanks!
uhohrobbo is offline   Reply With Quote
Sponsored Links
Old 05-16-2007, 12:46 PM   #2
MibMib's Avatar
Vehicle: TLC80
My Photos: (0)
I think it's a problem of dryed polar capasitors of 5v rail - find them,on PCB and try to change - use same voltage and capasitance , also see at marking - if they "low esr" type - use the same, if you'll change it by new same -be attentievly - check the polarity before istalling them !!!.
400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
MibMib is offline   Reply With Quote
Old 05-17-2007, 10:42 AM   #3
Beehphy's CarPC Specs
Beehphy's Avatar
My Photos: (0)
I've attached a PDF of the best "Low ESR" caps I've found. you can order any of them on digikey.com. just use the PN in this doc to search.
I found some info on the web about many batches ot bad electroltic capacitors being sold to computer manufacturers, causing premature failure of the products. Something about a stolen manufactureing process that's missing some inportant info causing them to fail early.
http://www.badcaps.net/
This may be a contributing factor...
Beehphy is offline   Reply With Quote
Old 05-18-2007, 03:44 AM   #4
My Photos: (0)
Ok thanks for your suggestions. I have done a visual inspection of the board and everythink looks ok. Unfortunately as you probably know the board is multi-layered so determining which caps are on the 5V rail is tricky. Does any one have a schematic or pcb layout for the m1 ATX?
cheers
Old 05-18-2007, 09:34 AM   #5
MibMib's Avatar
Vehicle: TLC80
My Photos: (0)
Oh ...... you can simply use a multimeter to determine which one of caps
Old 05-21-2007, 04:49 AM   #6
My Photos: (0)
I have located the 5V caps. But the capacitance meter I have only goes up to 200uF which isn't very much considering the caps are 1500uF. But at least I was able to test that none of them had shorted.
I did notice however that the board ticks! Only very very quietly you would need all fans turned off etc but it definately ticks when it is turned on! Anyone noticed this before?
I guess this is the PWM feedback loop but I just want to check that all m1 ATX's make this noise?
Old 05-25-2007, 06:26 AM   #7
My Photos: (0)
Just to update. After probeing the board I found that Q8 MOSFET transistor has a 5v input, a 5v switching and only a 4v output. So it looks as though the MOSFET may have popped. I have a replacement IC on order and I shall let you know if i fix it!
I replaced the MOSFET over the weekend and it fixed the problem. Woohoo!
Thanks for you help!
Old 04-20-2008, 03:35 AM   #8
Fabius's Avatar
Vehicle: 1999/BMW/320D
My Photos: (0)
what type the mosfet are used to replace it??
i have the same problem, an q8 it's broken....
Fabius is offline   Reply With Quote
Old 04-20-2008, 07:15 AM   #9
My Photos: (0)
I just replaced it with the same mosfet. From what I remember the part number was quite clearly marked on the IC. One thing to note though is that I also had to replace my hdd. I guess the hdd died and started to pull too much current from the psu and popped the mosfet.
Old 04-20-2008, 11:50 AM   #10
Fabius's Avatar
My Photos: (0)
yes, same conditions...
my MB doesn't work too, the HDD are fault and the mosfet q8 it's exploded!
from circuit i know that it's N channel mosfet and i temporary replaced it with irfz48V and it's work....but to make a better work it's wil replaced with same mosfet original.
what sign have IC marked?
FDS--????
thanks
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
M1 ATX + Centrino 1.5 Ghz + AOPEN XC CUBE MZ855 luckyno Power Supplies 4 01-06-2006 09:19 AM
Wanted. M1 ATX Lead.. CdRsKuLL Classified Archive 1 08-12-2005 09:57 PM
Powering USB 2.0 Hub off HDD +5v Rail - Any problems? sq_geek Power Supplies 12 06-07-2004 09:11 PM
Need opinion on main board Michael Szilagyi General Hardware Discussion 31 06-27-2003 06:10 PM
replaced MAX chips and still 12v on 5v rail surfer6262 Power Supplies 5 07-15-2002 11:51 AM
Sponsored Links
Ad Management by RedTyger
