Old 05-20-2007, 02:19 AM   #1
dotinga00 is an unknown quantity at this point
My motherboard has a non standard 24 PIN power connector
My computer is a HP Pavilion s7730 with a Asus MOCA-AR (OEM) motherboard (can't select it in the model list...). I need to use the computer in a car, so i need to adjust the power supply. For use in my car i will use:
http://www.mini-box.com/M2-ATX-160w-...8&category=101
The problem is that this device has a 20 pin, and the Asus MOCA-AR a 24 pin power connector. A normal adapter (from 20 to 24 pin) like this:
http://www.tigerdirect.com/applicati...751&CatId=1107
won't work, because the 24 pin connector is much too large for my motherboard. I have made a picture of the power connector from HP Pavilion power supply (black one) and my 20 PIN (white) connector.
http://www.nb.nu/power%20atx24.jpg
Any change to find an adapter for this (or make one by myself?)
Kind regards,
Marcel
dotinga00 is offline   Reply With Quote
Old 05-20-2007, 10:14 AM   #2
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
The short answer is make it yourself or use a different MB.
HP, Dell and others sometimes use non-standard PS parts. It may actually use different voltages and or pin outs.
Be very careful as mixing up the wires can break your MB.
Use a meter to measure the voltage of each wire before attempting to use an adapter or different PS.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 05-20-2007, 10:23 AM   #3
tracker64 is on a distinguished road
you can still plug 24 pin power from psu to a 20 pin port, works on most motherboards ! just the 4 extra pins will OVERLAP the plug, if theres room on the edge, it'll work.
tracker64 is offline   Reply With Quote
Old 05-20-2007, 05:54 PM   #4
TruckinMP3's Avatar
This statement assumes the MB uses a standard pin out, this is not always true for Dell or HP.
Use a meter to make sure before you let the smoke out.
TruckinMP3
Read the FAQ!
Old 05-21-2007, 05:28 AM   #5
Thanks for your answers.. To buy a new motherboard. a jut bought this computer a few days ago:-(
Ok, i'll make it myself and will measure before i act. But i still have to get the right connector (the black one). Does anyone of you recognize ths connector? It is much smaller then the regular 24 pin atx connectors....
Marcel
(if interested i can upload some imagesof my BMW E39 touring)
Old 05-22-2007, 04:23 PM   #6
tony2socks is an unknown quantity at this point
I'm interested in your solution or what the pinout of the connector is.
The tech at HP gave me the following for a 20 pin based on the motherboard, but I don't believe he knew what he was talking about:
ATX Power Connector
Pin Signal Name Pin Signal Name
1 +3.3 V 11 +3.3 V
2 +3.3 V 12 -12 V
3 Ground 13 Ground
4 +5 V 14 PW_ON
5 Ground 15 Ground
6 +5 V 16 Ground
7 Ground 17 Ground
8 PWRGD (Power Good) 18 -5 V
9 +5 VSB (Standby for real-time clock) 19 +5 V
10 +12 V 20 +5 V
tony2socks is offline   Reply With Quote
Old 05-24-2007, 11:36 PM   #7
ATX Power Connector
1 +3.3 V 11 +3.3 V
2 +3.3 V 12 -12 V
3 Ground 13 Ground
4 +5 V 14 PW_ON
5 Ground 15 Ground
6 +5 V 16 Ground
7 Ground 17 Ground
10 +12 V 20 +5 V
No, the motherboard as a 24 pin connector, which uses exactly the same pinout as ä regular connector.
Anyway, i did loose my patience. I have cut the wires, and soldered it directly on a regular connector....
kr,
Marcel
Old 05-24-2007, 11:57 PM   #8
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
kr,
Marcel
So it really was a regular ATX connector, but they shrunk it down?
Old 05-25-2007, 06:25 AM   #9
Indeed......
Ir was this connector
http://www.molex.com/pdm_docs/sd/430252400_sd.pdf
Marcel
Old 09-10-2007, 10:59 PM   #10
frankr127 is an unknown quantity at this point
I have the same computer. You have a nano-atx motherboard. I'm setting my computer as we speak. Here's the link got the adapter. I still haven't ordered it but it should do the job.
http://www.mini-box.com/Nano-Power-A...=8&category=13
frankr127 is offline   Reply With Quote
Old 11-20-2007, 06:57 AM   #11
wywywywy is on a distinguished road
Hi,
I have the same board, and I just want to say that I bought the above adaptor and it DOESN'T do the job. They are of different size.
So the quest continues...
wywywywy is offline   Reply With Quote
Old 11-24-2007, 03:52 AM   #12
AcuraTLFan
I had the same problem. Two ways to solve
1) buy the hp power supply for ~$55
2) buy a 24pin atx extender cable ~$5 + Time + Effort
You get this....not very pretty, but it works...glue gunned it to get it to stay
AcuraTLFan is offline   Reply With Quote
Old 11-24-2007, 05:59 AM   #13
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is just really niceDarquePervert is just really niceDarquePervert is just really niceDarquePervert is just really nice
Some electrical tape or shrinkwrap or braided sleeving or split loom will pretty that up substantially.
Hell, even bundling the individual wires with zip-ties would improve aesthetics.
Now that you have the function, go for some form.
Quote: Originally Posted by Heather
Upon the advise of the mods, your inflammatory signature was deleted as well, under the same grounds for deleting the thread you started.
Old 03-08-2008, 11:10 PM   #14
Hi all,
Just want to say that I managed to get some of these 24-pin connector, with socket pins.
If anyone needs help & wants one I can post it for the price I paid for them, which is £3.25. I will have 9 left. They are currently being sent to me from Hong Kong.
Thanks.
Old 03-09-2008, 06:37 AM   #15
AcuraTLFan
Any pictures? Are the connectors and pins already crimped?
FAQ: Power Supplies Explained (Part 1) Bugbyte The FAQ Emporium 14 06-10-2007 07:45 AM
24 pin motherboard to a 20 pin power supply jdiazj1 Power Supplies 7 05-16-2007 08:15 PM
headrest lcd s video connector pin out hot_sedan LCD/Display 0 08-01-2006 02:47 PM
Flex ATX motherboard, power supply - can someone confirm canadiandream Newbie 8 05-13-2006 07:21 PM
getting an odd motherboard to power on karmann Power Supplies 13 11-28-2001 05:27 PM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
