Old 06-11-2007, 05:18 PM   #1
vladcarpc's Avatar
vladcarpc is an unknown quantity at this point
Is M2-ATX capable of powering these devices?
Here is my WorkLog (new):
http://www.mp3car.com/vbulletin/work...rst-carpc.html
The main question now is regarding the Power Supply.
I need power for the MoBo (12v), for the HDD (5v), USB Hub (5V) and Screen (12V).
Do you know how many connectors comes with M2-ATX PSU?
Do I need any optional parts for M2-ATX or maybe another Power Supply?
Thanks!!!
vladcarpc is offline   Reply With Quote
Old 06-11-2007, 06:49 PM   #2
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
I'm sure the m2 would be adequate. If I remember correctly the M2 comes with 2 molex connectors (hdd, cd-rom) 1 mini molex (is that what they're called?) for a floppy, and of course the 20-pin motherboard power connector. Also has an optional P4 connector you can get.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 06-12-2007, 10:08 AM   #3
vladcarpc's Avatar
Hi!
But what about the Screen? What connector is used to power the Lilliput?
Thanks!
\/ |_ /\ [)
1995 Civic Sedan EX
CarPC status: [||||||||||||] 100% - Phase 1 Complete!
YouTube video - WorkLog
Old 06-12-2007, 10:46 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Make your own. Wire the pose connector for the Lilliput screen to a male molex HDD connector.
Yellow wire is +12v and the black wires are ground. The red wire is +5v and won't do anything.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-12-2007, 11:00 AM   #5
vladcarpc's Avatar
Hi. So I will get the HDD connector and split it in 2, one will power the 2.5' HDD and the other will go to the Lilliput.
On the Lilliput side, I will change the connector to become a male HDD connector.
Is that it?
Thanks!
\/ |_ /\ [)
1995 Civic Sedan EX
Old 06-12-2007, 11:07 AM   #6
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
don't the smaller laptop drives require a specific power adapter?
not to mention an adapter to go from the 2.5" form factor to the 3.5" form factor for the IDE plug?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 06-12-2007, 11:22 AM   #7
That adapter usually has a molex HDD connector for power.
Old 06-12-2007, 12:10 PM   #8
vladcarpc's Avatar
Yes you are right. I've bought this adapter:
http://www.ciadosoftware.com.br/prod...&dep=7&cat=106
For around U$15,00 and it converts data and power for the small HDD.
\/ |_ /\ [)
1995 Civic Sedan EX
Micro ATX or ATX custardbomb Power Supplies 0 08-14-2005 07:48 AM
powering a VIA MII w/ a ATX powersupply boostedGT-S Power Supplies 3 01-20-2005 01:57 PM
A solution for powering 12v stuff inside zootjeff Power Supplies 21 12-17-2004 07:21 PM
Powering a datalux screen from atx psu Speedpass101 Power Supplies 1 10-08-2004 04:19 AM
Powering up normal ATX PSU KimaX Power Supplies 5 09-28-2004 01:08 AM
