Old 06-25-2007, 07:00 PM   #1
Snortonnorton is an unknown quantity at this point
M2 ATX power supply wiring question... 3 terminals
Hi, I'm a total newbie so I have an easy question, and yes, I've already tried searching and reading schematics...
On the M2 ATX power supply board, there are 3 main power terminals. One is ground, one is direct battery, and other is ignition power.
My question is, Do I have to use both power terminals? (run a power line to battery which should be at least 8 gauge in order to use a 30-40 amp inline fuse) and run a fuse tap wire from ignition fuse block?. Plus the ground wire.
I'm asking because I want to know does the M2 ATX just need the ignition power to know when to power on computer? and If I have to use such a heavy guage wire for the battery line, then how would you use a heavy gauge line to the ignition wire?
I want my PC to power on when I start car and then I'll have the jumper setting to turn off computer a certain length of time after car is off...
thanks for any input
Snortonnorton is offline   Reply With Quote
Old 06-25-2007, 07:16 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
yes the ignition line is for the remote sensing to turn on/off your computer with the start of your car. Just like an amp.
If you want the sdc functionality, then of course you need to connect it.
The ignition line draws almost no power, so you can use any guage wire.
Old 06-25-2007, 10:26 PM   #3
ok, now it makes sense.
thankyou.
Old 07-25-2007, 08:07 PM   #4
Cyberphox's Avatar
Cyberphox
since the ignition line draws little power, do you think there would be interference if you ran it in a flex tube with the speaker wire? Reason I am asking is cause I have the Streetwires Smartwire that has 9 wires inside and i am running 8 of them to the 4 channel amp and was wondering if I could make use of the last wire by tapping into the ignition 12v switched line?
Cyberphox is offline   Reply With Quote
Old 07-25-2007, 08:23 PM   #5
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
Shouldn't be a problem. The RFI generated by the low current demans of the ignition sense should me minimal, if anything.
Michael
Wiredwrx is offline   Reply With Quote
Old 07-25-2007, 08:25 PM   #6
Cyberphox's Avatar
Cyberphox
hey thanks for the quick response and advice..
ATX Motherboard... power supply questions msreyes General Hardware Discussion 1 05-09-2006 09:01 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
fs: mastero mk-3.5 120w atx dc-dc power supply infinkc Classified Archive 7 05-16-2004 07:06 PM
Easy ATX power supply queston dudah85 Power Supplies 1 07-10-2001 01:59 AM
power supply question perlmax90 General Hardware Discussion 0 12-08-2000 12:16 AM
