The MP3car.com Store
Thread Tools Display Modes
Old 07-03-2007, 03:08 PM   #1
My Photos: (0)
2001 Acura MDX constant 12v power outlet.
Hello,
Is there an easy way to convert any of the three 12v power outlets that are currently do not receive power while the car is turned off to one that receives constant power?
Thanks,
Keith
geobag is offline   Reply With Quote
Sponsored Links
Old 07-03-2007, 03:38 PM   #2
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (77)
the easiest way would probably be to disconnect the lead for that socket, then run a FUSED wire from a constant source. this can be from the battery but may be a bit of a hassle & overkill for just a lighter socket that will probably only handle like 20 amps max. if you know what your doing then you could get that constant power in the dash either at the fusebox or ign switch, but don't just tap any wire that's hot unless you know exactly what it is. you will need to tap a large circiut so you don't overload it.
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 07-03-2007, 09:27 PM   #3
My Photos: (0)
I need only to run a cell phone charger, what kind of amps will that pull, I was thinking of using something like this.
Would it work?
http://www.partsexpress.com/pe/pshow...number=071-580
Old 07-09-2007, 03:35 PM   #4
binary.h4x's Avatar
Vehicle: 2007 Honda Fit Sport
My Photos: (0)
I am a big fan of those "piggy back" style fuses. Although, they can be obtained cheaper at Autozone or similar store.
Fuse size would be determined by the gauge wire you are using the the max current handled by the adapter.
binary.h4x is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: How do I power my DC-DC PSU on my workbench? DarquePervert The FAQ Emporium 36 05-16-2008 03:47 PM
Power Supply/OPUS Kill Switch SpaceMonkey Power Supplies 8 08-11-2006 10:58 AM
extending wires on power inverter outlet tgm4883 Power Supplies 8 01-28-2006 12:09 PM
I need a cheap 12v power regulator. Nothing fancy, just one LCD JiminyC Newbie 4 08-18-2005 07:00 PM
Is it safe to connect my inverter directly to the car power outlet? b8bboi Power Supplies 2 07-21-2005 12:07 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
