The MP3car.com Store
Thread Tools Display Modes
Old 07-26-2007, 12:44 PM   #16
XF_Falcon's Avatar
My Photos: (0)
Quote:
I was wondering if anyone would know, or be able to point me in the right direction. I'm trying to figure out which wire coming out of the back of the radio is the ignition or 'remote on' so I can tap into. It's a 2007 Mazda 3 and it's the last wire I have to run. Thanks for any information in advance!
Easy. Just get a multimeter, and set it to 12V DC. Get the negative side (usually black) of the multimeter and firly press it against the chasis of the car, or any metal part you are certain is connected to the chasis (or even a black ground wire if you know of one). Then get the positive side (usually red) and touch each of the wires at the back.
The one which gives you 0V when the ignition is off, and around 12V when the ignition is on accessories (or engine is started) is the wire you are after.
XF_Falcon is offline   Reply With Quote
Sponsored Links
Old 07-26-2007, 12:55 PM   #17
My Photos: (0)
Yup
Thanks man, I appreciate the response!
ledzippel is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
M2-ATX Problem - Fan runs but does not boot ! Autonator Power Supplies 62 11-14-2006 05:22 AM
M2 ATX Power on problem JWise1203 Power Supplies 5 07-26-2006 11:24 AM
BU-303, Signal when PC is off, NO signal when booted up. vairu GPS 7 03-09-2006 05:54 PM
Pinout Color Codes / Tables gummybear General Hardware Discussion 4 05-12-2005 03:05 AM
FS: LCD Controllers - $90.00+shipping infrared Classified Archive 98 07-20-2003 08:30 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
