The MP3car.com Store
View Poll Results: I'am using :
Hibernate 48 64.00%
Sleep 9 12.00%
Shutdown 18 24.00%
Voters: 75. You may not vote on this poll
Thread Tools Search this Thread Display Modes
Old 07-18-2007, 05:00 PM   #16
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Quote: Originally Posted by RedGTiVR6 View Post
It's no different than unplugging your TV, PC, etc. while not using it even when it's off to conserve energy.
Electronics draw a small amount of power even when 'turned off', this includes computers.
I've run the M1 and now the DSATX. I don't drive my car for days on end (sometimes I'll go a week solid without ever starting the car). NO MATTER WHAT, if I don't put the car on a trickle charge, the battery WILL be drained within a few days.
It's not a product not working as it should, it's a fact of electronics.
Hello Red, maybe what is confusing (and might be wrong) is the analogy that M-2's "hard off" is like "unplugging a tv from the wall" - maybe we need to stop using that analogy.
i don't believe that an appliance or electronics can consume power when unplugged; not from the original power source at least; a reserve inside itself maybe.
treetop777 is offline   Reply With Quote
Sponsored Links
Old 07-18-2007, 05:13 PM   #17
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
you can NEVER rely on aftermarket equipment to increase the value of your vehicle. It's not even something people consider when making an offer on a car. You will NEVER regain what you've put into it. If someone led you on to believe this, then they are sorely mistaken.
You don't do these things because you want your money back out of it, you do these things because you truely enjoy it.
Everyone has something they spend their money on, for those of us on this forum, CarPCs just happen to be one of those things.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-19-2007, 05:28 AM   #18
Vehicle: '95 / Mitsubishi / Pajero
My Photos: (0)
I don't have a problem with this as my truck is fitted with two batteries, and I carry an emergency start pack in the back.My pc is set to hibernate.
What I don't understand is the difference between hibernate and sleep. As the pc is basically in the same "shut down" state won't it consume the same small amount of power in either mode?
brodgar is offline   Reply With Quote
Old 07-19-2007, 08:18 AM   #19
_
My Photos: (90)
Even with two batteries and an emergency start pack....once you drain your batteries pas a point (unless they are deep cycle) they are shot and will never hold a full charge again.
As for the difference between the two states: http://www.terranovum.com/projects/e...y_v_hiber.html
Jan Bennett
Old 07-19-2007, 10:39 AM   #20
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
Hibernate here. If I know I won't be starting the car for more than a few days, I shutdown the pc, and UNPLUG the power cable from it!
Nola111 is offline   Reply With Quote
Sponsored Links
Old 07-19-2007, 07:58 PM   #21
meth68's CarPC Specs
Vehicle: 2005/Infiniti/G35 Coupe
My Photos: (0)
I finally got my car back and I have been messing with the power settings. Here is what I have going on. My M2-ATX is set to 5sec/2hour.
Here are the 3 options I tried so far and the results.
When I set my pc to "when I press the power button" in control panel to standby It will seem to work fine, I havent tested it after the 2 hours (about to do that in an hour or so) but the issue I have is when I get back in the car and start it, touch the screen it comes back from standby but streetdeck is closed?
When I set my pc to "when I press the power button" in control panel to hibernate and enable hibernate in the tab. I shut off the car, waited about 2minutes, started it back up and it would not boot correctly.
When I set my pc to "when I press the power button" in control panel to shutdown it seemed to work fine. I had it set like this yesterday, after 2 hours everything was shutoff just as planned.
Now my question is this, if you set it for standby, so after 5 seconds after shutting off my car the pc should go into standby, and after sitting for 2 hours it should shut down. If this is the case exactly what process does it go about when shutting down, after the 2hours is it shut down correctly or is it like a cold boot like you yanked the plug?
Thanks in advance.
meth68 is offline   Reply With Quote
Old 07-19-2007, 09:03 PM   #22
treetop777's Avatar
My Photos: (0)
Good question; i'm interested in seing your results. I bet you it (M-2) just cuts power abroptly after the 2 hours. Ideally it should hybernate from standy then cut power..
Wait a minute - i think that can be done from the windows power settings..let me go play!
Old 07-19-2007, 09:20 PM   #23
My Photos: (0)
I am not sure how it shut down but right now I have my pc set to standby. It stayed on standby for atleast 10 minutes (I tested it) then i left the car alone for 2.5 hours I just checked and my gps light is now off so the pc is shut down. But I have no idea if it was shut down like a hard boot or shut down properly?
Old 07-19-2007, 09:45 PM   #24
treetop777's Avatar
My Photos: (0)
Turn the key and see how it come back alive; if it boot from scratch i think you can assume M-2 pulled the plug (or better say "cut power") while it (the puter) was still in standby.
Old 07-20-2007, 09:14 AM   #25
My Photos: (0)
Well standby worked, after about 45min I went out started my car and it came back from standby. Tried again after 2 hours and the pc was off.
treetop777, I know its powered off. My question was how its getting to that power off stage. Is it smart enough to do the legit shutdown method or is it just cutting the power and risking corrupting some system files and such.
Old 07-20-2007, 09:26 AM   #26
Serialk1llr's CarPC Specs
Serialk1llr's Avatar
Vehicle: 2008 Subaru Impreza WRX
My Photos: (0)
Hibernate. I drive daily. However I usually do a full shutdown/restart in my routine every week to just freshen things up. But yeah, like many others, I do a full shutdown if i don't plan on driving it daily.
Current Rig
Inspiron 5100 Laptop
*2.2 Ghz CPU
*368 MB Ram
*32meg OnBoard Vid
Carnetix 1900 PSU
BU-353 GPS Antenna
iGuidence Nav Software / Mappoint for POI's
Linksys USB WiFi
D-Link USB Bluetooth 2.0
Xenarc 700IDT
Eclipse CD4000 HU
Serialk1llr is offline   Reply With Quote
Old 07-20-2007, 10:24 AM   #27
Vehicle: 1977 Ford Fairmont GXL
My Photos: (0)
It's already been hinted at, but my idea would be to have a dead switch somewhere between the battery and the pc, so that you can not only shut down but also "unplug it from the wall" if you know you are going to park up for a week. I walk to work and can only drive a/h so this is a feature I am attempting to incorporate into the design phase.
bluebird is offline   Reply With Quote
Old 07-20-2007, 11:28 AM   #28
MibMib's Avatar
Vehicle: TLC80
My Photos: (0)
Oh , i think , you'll need a very powerfull switch, i don't know where to get it, do you know? The best way is using powerfull relay which drives by small switch what do you think about it ?
400Watt CarPC power supply for powerfull systems- thaks for Beta testers- it was perfect.
Remember - AMD Athlon XP (socket A) powers from 5v rail in most times !
MibMib is offline   Reply With Quote
Old 07-20-2007, 12:14 PM   #29
mst
mst's Avatar
Vehicle: Golf GTI 1983
My Photos: (0)
Wink
Ebay!
CAR STEREO AUDIO 12V CIRCUIT BREAKER FUSE 100 AMP CB100
Item number: 220131812652
mst is offline   Reply With Quote
Old 07-20-2007, 06:41 PM   #30
My Photos: (0)
Call me primitive, but I was thinking about two screws and a thickish copper plate for a switch, or a simple way to disconnect from the battery (my battery is in the boot, so perhaps a simpler option).
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Can't tell SD not to open GPS COM port rburhum StreetDeck Bug Reports 7 06-28-2007 09:37 AM
How does SD handle power and shuting down? Troy McClure StreetDeck 4 07-13-2006 04:02 PM
Resume after hibernate scrutinized ldave PowerVoice 6 02-09-2006 11:04 PM
Audio crash after hibernate (USB alerts) Peoples RR Bug Tracker 11 03-10-2005 01:29 PM
Flash Memory Speeds? (CF & SD cards) eCar™ Off Topic 0 03-25-2004 12:11 AM
Sponsored Links
Ad Management by RedTyger
