Old 07-20-2007, 11:15 AM   #1
dw_uk2000 is on a distinguished road
Newbie Carnetix p2140 - SX260 Question
Sorry for the longish newbie post.
But after reading the threads on here I decided to go with a Dell SX260 and the Carnetix p2140 setup instead of the Laptop that I had handy.
I've read all the threads on this but cannot get the following setup to work:
p2140 Input
2x Red - Positive Live via a fuse
2x Black - Ground
Yellow - Ignition
p2140 Output
Pri Red - Red & Brown cables on SX260 lead (12v)
Pri Black - Black & White cables on SX260 lead (Ground)
Sec Red - Red on Touchscreen (12v)
Sec Black - Black on Touchscreen (Ground )
Now when I connect the input and output connectors to the p2140, I dont get any led display. So I have checked the connections with a Voltage Test Light and found that the two input reds were fine, the connection between the p2140 and SX260 lead had no power. However when I tested that connection it seemed to make a circuit and the led display flashed.
Anyone have any ideas what is wrong.
Cheers
DAn
dw_uk2000 is offline   Reply With Quote
Old 07-24-2007, 05:29 AM   #2
Any ideas anyone?
Old 08-13-2007, 05:38 PM   #3
Anyone?
Old 08-15-2007, 12:28 PM   #4
Ruffy's Avatar
Ruffy is an unknown quantity at this point
Quote: Originally Posted by dw_uk2000 View Post
Anyone?
Would really need more detail on the connections. a Simple diagram made in MS Visio, MS paint or any program could help elaborate. Or pictures.
You say you're getting no red led power inside the carnetix? If so somethings off with your jumpers.
Does your sx260 run at 12v? How many amps does it draw (look at the power brick for the sx260)
You could be attempting drawing too much power at 12v thus overloading it. The lower the voltage the more power(amperage) hungry devices tend to be when talking about complicated electronics.
What is the Dell SX260? Is it a PC or laptop, if its a PC with it's own powersupply then connecting the outputs from the 2140 is completely wrong. If it is a desktop IE an optiplex then it expects 110v AC voltage not DC.
The Carnetix 2140 isn't properly suited to power a normal computer as they require multiple voltages via a mATX power connector on the motherboard.(12v+, 5v+, 3.3v+, -12v, -3.3v and potentially more) Then again if the SX260 is a special micro based setup it might accept dc via a wallwart. But I doubt it.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Carnetix P2140 & Dell sx260/270 BasicEvil Power Supplies 18 12-03-2007 04:06 PM
Newbie with a Roadrunner Config Question jay2000 Newbie 4 07-16-2007 01:24 AM
Carnetix P2140 Standby Mode Question ThunderStick Power Supplies 4 07-04-2007 10:19 PM
Newbie question jaydm General Hardware Discussion 25 10-21-2006 11:07 AM
Complete Newbie Question. DomesticImport Newbie 15 07-07-2005 07:24 PM
