The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 08-01-2007, 08:03 AM   #1
W3bMa5t3r's CarPC Specs
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Vehicle: 2004 4Runner SR5 V8 4WD
My Photos: (15)
Talking W3bMa5t3r's USB Power Modules
With a growing number of USB devices in my car, and wanting a few of those to be powered at all times, or to be switched on when the car is on, I built two new modules. The main reason was for my GPS tracking phone with Mologogo (boost I455, stays in the car, on all the time), and powering my Samsung A900 when I'm in the car using it for data transfer via bluetooth, cuz it sucks some serious juice doing broadband speeds.
Anyways, hooked them up and things have been gravvvyyy
The modules supply 1.5A of power, USB specs are 500mA per port, so this should do fine.
They have DIP switches to set the powering setup, either Always On, or On With Vehicle.
Just wire up the constant +12vdc, switched +12vdc and ground (and USB cable to CarPC for the first module).
Great for those higher powered devices, charging cell phones, ipods, etc.
Each module supplies up to 1.5A (1500mA).
1500mA for the one port with data pass through, or 1500mA shared for the two port, no data pass through.
More info HERE
The first has one USB port, with data pass-through, the module supplied USB power is isolated from the CarPC.
The second has two USB ports, NO data pass-through.
More info HERE
W3bMa5t3r is offline   Reply With Quote
Sponsored Links
Old 08-01-2007, 09:17 AM   #2
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
Great idea. I could use something like this for my USB DVD drive. But my DVD drive draws 1A at 5V. Are you sure your module is 1.5mA? Don't most USB ports put out 500mA?
Nola111 is offline   Reply With Quote
Old 08-01-2007, 09:27 AM   #3
W3bMa5t3r's Avatar
My Photos: (15)
Sure am. Both modules will supply up to 1.5A total. And yes, the specs for USB ports is 500mA per port. I swear I wrote that above
Old 08-01-2007, 09:38 AM   #4
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (130)
got these things made now huh steve. Good job! I'll be buyin one off ya once my new pc gets off the ground
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail, & CentraFusion
Old 08-01-2007, 09:41 AM   #5
W3bMa5t3r's Avatar
My Photos: (15)
Yeah, took me a while with the other million projects I've got going on lol. No worries just let me know. How's everything? Gonna be at the next meet?
Old 08-01-2007, 09:45 AM   #6
Cheekz185's CarPC Specs
Vehicle: 2002 Mitsubishi Galant
My Photos: (0)
HEY Steve this should be the thread to ask you this but I have used Boost Mobile on and off. I was just wondering how is the service for you? In my area there is never any service! It just sucks man! It really annoys me cuz i wish it had dam service. And i dont wanna spend another 20bucks (prepaid) to find out if the service got any better!... I would love to use the mologogo and boost but i cant cuz boost isnt good in my area!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 08-01-2007, 09:47 AM   #7
MySQL Error
My Photos: (130)
i'll be there for sure. no computer tho.. i'm in the process of repainting my **** brown interior lol.
03 Acura RSX Coupe
Old 08-01-2007, 09:56 AM   #8
W3bMa5t3r's Avatar
My Photos: (15)
Well to pull a quote from the W3bTracker GPS Tracking thread
Quote: Originally Posted by W3bTracker GPS Tracking
Just took my car out for a ride and tested out the software w/ my two different gps receivers (an older HI-204E and my new BU-355/5). Also had my (for tracking only) boost mobile phone going w/ Mologogo. W3bTracker actually kept on route, with better results than Mologogo.
Oh, and no one had asked about it, but I was running W3bTracker, went into hibernation and back out, it picked up where it left off and kept on tracking. Sweeeet
Hope that clarifies things But yeah... mologogo/boost was quite shoddy for some reason.
@Sonic... Good sheeet. Yeah I did the same w/ my interior. SEM vinyl dye is my(maybe your) friend. See you there then.
Old 08-04-2007, 03:43 PM   #9
Ruffy's CarPC Specs
Ruffy's Avatar
Vehicle: 2000/Chrysler/300M
My Photos: (0)
awesome, just what I wanted.
Well really I want a 12 port usb hub powered with those features each port getting 500mA
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 08-05-2007, 01:31 PM   #10
Ruffy's CarPC Specs
Ruffy's Avatar
My Photos: (0)
question, what kindof battery drain have you seen with leaving a device always on. I'm considering leaving my gps puck powered constantly to prevent cold boots.
Sponsored Links
Old 08-05-2007, 02:48 PM   #11
W3bMa5t3r's Avatar
My Photos: (15)
I haven't done any measurements on this yet, but I've had the I455 phone running 24/7 off the 2 port no data module. I've gone out to the car after 24 hours and had no noticeable affect on the battery, and I have a big motor to turn over. I'll be checking battery voltage levels later today and for the next 1-2 days as I'm letting the car sit (I'll prolly change the oil on Tuesday though, so I'll be cranking her back up then (well hopefully )).
Old 08-07-2007, 07:13 AM   #12
W3bMa5t3r's Avatar
My Photos: (15)
Ok, so the car has been sitting for 3 1/2 days with the cell phone running/charging off it. Just went out and checked the voltage on the car battery. It's sitting at 11.6vdc. So yeahhhh these modules are doing fine.
I'm not sure if a GPS puck would use more or less power as I know cell phones can suck some serious juice(cell battery) when using the gps module and uploading data, but it seems so far, that it should do fine on daily/almost daily drivers.
Old 08-07-2007, 10:18 AM   #13
Vehicle: '93 olds cutlas ciera
My Photos: (0)
my laptop is one of the few that leaves 5V powered on when its in suspend to ram.
The battery isnt one of the most powerful ones ever, my laptop pulling 22-25 WHR from it, I get anywhere from 2-3 hours.
as a test, I left the gps plugged in and running off the machine while the laptop was in suspend. (again, my laptop leaves USB powered up in suspend...)
The gps remained locked on for about 2 days before the laptop battery was shot.
They pull a noticeable amount of power, but I'd imagine a car battery has a heck of alot more go-juice than this laptop battery.
64 WHR battery, unfortunately Its reporting 41% wear now...during the test it was less than 20.
netman86 is offline   Reply With Quote
Old 08-07-2007, 10:28 AM   #14
W3bMa5t3r's Avatar
My Photos: (15)
@ netman86 - Good info Thanks
Old 08-08-2007, 12:35 PM   #15
gokee2's CarPC Specs
gokee2's Avatar
Vehicle: 2001 Infiniti I 30
My Photos: (1)
Hey Steve,
Here is my question: How are your great modules any different from say a regular USB Male to Female extension cable? I guess where I'm lost is that if you do connect say the data transfer module to your mobo USB and you run a USB powered HUB into your module you will have enough juice to power more than one "power" hungry device like an external DVD drive and say maybe an external HDD?
gokee2 is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Bytecc BT-200 USB 2.0 to IDE Adapter power? hauler34 Input Devices 1 11-07-2006 01:02 PM
Another USB standby idea: splice wire and use a relay?..need help S4Per General Hardware Discussion 4 11-04-2006 10:12 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
USB power issues - opinions please zaxxon Power Supplies 2 07-20-2005 10:03 PM
USB power & touchscreen issues... Ren77 General Hardware Discussion 1 12-11-2003 04:56 PM
Sponsored Links
Ad Management by RedTyger
