Old 08-08-2007, 01:53 PM   #16
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Well with USB standards giving each port a max of 500mA. For each device plugged into that port, you're dropping the available power.
Code:
[] - 500ma (1) L___[] - 500ma (2) L___[] - 500ma (3)
That's how power is supplied. Now if I plug a device into hub 2 that pulls 200mA, it leaves 300mA for the other 2 ports, because port 1 can not (not supposed to) exceed 500mA. So if you plug into 3 that requires 400mA... something is going to be hurting.
My module supplies(makes available) a total of 1500mA. Making it perfect for power hungry devices, even more than one . The other thing is my modules can be set to be always powered on, for items like cell phones, or gps pucks that you would like to keep on...
Cheers
W3bMa5t3r is offline   Reply With Quote
Old 08-08-2007, 02:00 PM   #17
pim
pim is on a distinguished road
It would even be better if it would use the host's USB 5v to switch on and off, rather than the car's switched 12v.
This way, your connected devices will still be connected if your car pc shuts down, usually after you turn off ignition. Disconnecting your devices before shutting down may cause havoc.
Pim
pim is offline   Reply With Quote
Old 08-08-2007, 02:15 PM   #18
gokee2's Avatar
gokee2 is on a distinguished road
Nice, Very nice. Great Job You think I could pick up one of the data pass-thru modules at the next car meet?
ps: check this link out http://www.aximsite.com/boards/x50-x...-must-see.html
Can you make one of those Steve or teach me how to. LOL?
gokee2 is offline   Reply With Quote
Old 08-08-2007, 03:19 PM   #19
W3bMa5t3r's Avatar
Thanks, and sure. I'll try to have a few of each w/ me.
Dang... I haven't had a chance to look over it much since I'm at work, but it looks pretty sweet
Old 08-08-2007, 03:23 PM   #20
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
Quote: Originally Posted by W3bMa5t3r View Post
The modules supply 1.5mA of power, USB specs are 500mA per port, so this should do fine.
Both modules will supply up to 1.5mA total. And yes, the specs for USB ports is 500mA per port. I swear I wrote that above
Perhaps you could clarify. 1.5mA (which seems unlikely, but you wrote it twice like that), or 1500mA? I doubted it the first time you wrote it, was just plain confused the second time, and the third time it seemed far more reasonable.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 08-08-2007, 03:26 PM   #21
W3bMa5t3r's Avatar
Each module supplies up to 1.5A (1500mA).
1500mA for the one port with data pass through, or 1500mA shared for the two port, no data pass through.
Old 08-08-2007, 03:34 PM   #22
Raw Wave
Rob Withey's Avatar
Each module supplies up to 1.5mA (1500mA).
Still confused. There are 3 orders of magnitude between those two current values.
1.5mA is not the same as 1500mA. 1.5A is the same as 1500mA.
Old 08-08-2007, 03:48 PM   #23
W3bMa5t3r's Avatar
hmm lol ah gotcha. Sorry... The latter. 1.5A / 1500mA
Old 08-09-2007, 02:13 PM   #24
tn6478's Avatar
tn6478 is an unknown quantity at this point
do i have to use this if i am using a power usb hub. I have power connected to the hub so it would give enough power to all my device. Only thing i am using it for is my external 2.5 usb hd. Just a simple question.
tn6478 is offline   Reply With Quote
Old 08-09-2007, 02:50 PM   #25
W3bMa5t3r's Avatar
If the hub is working fine for you, then no.
This is mainly for devices that require more power than what a normal hub can supply.
Usually larger external hard drives, cell phone chargers, etc. OR if choose to use the option of the module, have a device always on.
Old 08-13-2007, 03:32 PM   #26
gokee2's Avatar
Hey Steve,
If I connect a non powered usb hub to your data capable usb module, will that usb hub posess the 1.5A power rating to effectively distribute to other connected usb accessories?
Old 08-14-2007, 06:07 PM   #27
W3bMa5t3r's Avatar
Hey Steve,
The module will supply the 1.5A, but it would depend on the circuitry of the non powered hub as to whether or not it would make full use of the power supplied. Most likely yes, but I wouldn't want to promise/guarantee that.
Hope that helps...
Old 08-14-2007, 06:28 PM   #28
gokee2's Avatar
Hope that helps...
I guess I will have to wait till Saturday then.
Old 03-02-2008, 01:32 AM   #29
W3bMa5t3r's Avatar
Never did post the updated pics here. I ended up only making (other than for my personal use) the 1 port with data pass-through. Pics below. More info Here.
Old 06-19-2008, 01:41 AM   #30
MoFo's Avatar
MoFo is on a distinguished road
Hey guys. Let me resurrect this one...
I want to make sure I got this right.
Say I have a regular ol' USB hub (non powered) that I ran from my trunk pc to my glove box..
Normally, in order to power it for "heavier" devices, I would have to plug in an AC adapter into an inverter and power the hub.
My question is...
with the device from this thread, can I connect it (w3bmaster's device) to the car's power then plug its USB cable into the hub... thus feeding power into the hub?
Therefore eliminating the need to use the hub's AC adapter?
Or am I way off base?
Thanks for the help!
MoFo is offline   Reply With Quote
Bytecc BT-200 USB 2.0 to IDE Adapter power? hauler34 Input Devices 1 11-07-2006 02:02 PM
Another USB standby idea: splice wire and use a relay?..need help S4Per General Hardware Discussion 4 11-04-2006 11:12 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
USB power issues - opinions please zaxxon Power Supplies 2 07-20-2005 11:03 PM
USB power & touchscreen issues... Ren77 General Hardware Discussion 1 12-11-2003 05:56 PM
