I’m using an inverter with a diy startup/shutdown controller.
It triggers the pc to hibernate.
Can I use an external 5V power supply to power the standby pin on the motherboard while the inverter is off?
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
I want to use standby. I think the 5V on pin 9 is to keep the memory powered. I also see that pin 14 is 5V when the pc is off or in standby but change to 0V when it is on.
Can someone tell me the amount of current needed in standby.
No, because it depends on the system that's in standby.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
