08-12-2007, 03:33 PM
#1
Vehicle: XM 2.1 TD
Fitting ring terminals for earth / power connections
Ring terminals are a great way to get power from your battery or an earth at some point for your equipment, but if the connection is no good, you can run into all kinds of problems, I just had to fight a right monster of a job as some previous technician had done a wonderful job of crimping a wire by its insulation, which then came loose...
While it may seem common sense to some people how to fit a crimp terminal, I like to solder them, so here goes....
1) First strip and prepare ends of wires, don't forget to side plastic barrel over wires now!
2) Apply some solder to the wires, and then crimp into the connector
3) Apply more solder to the ring terminal, it should 'run' into the voids around the wire
4) slide plastic barrel over connection and clamp, its now secure for life.
Lez.
XM 2.1TD ~ Morette triple headlights+HID ~ Leather kit ~ XC70 alloys
Exhaust rear boxes removed ~ meshed air filter
08-12-2007, 03:49 PM
#2
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
I would take the extra step of using electrical tape or heatshrink tubing (preferred) over the plastic barrel for an additional layer of protection. The plastic barrels have a tendency to slide back and forth along the wire.
My Worklog
08-12-2007, 03:53 PM
#3
Fusion Brain Creator
Vehicle: 2001 Honda Civic EX Coupe
+1 for heatshrink. Allthough I am guilty of using duct tape for some of those temporary connections.
08-12-2007, 03:57 PM
#4
Raw Wave
Vehicle: '97 Vauxhall Corsa 1.5 TD
+2 for heatshrink.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 512Mb flash DOM, 8Gb CF HDD, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
08-13-2007, 08:48 AM
#5
Raw Wave
Vehicle: '02 suburban with quad captain seating
+3 for heat shrink.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
08-13-2007, 12:05 PM
#6
Vehicle: XM 2.1 TD
That should not happen, as the barrel should be crimped, reducing its size so it cant move back over the thicker part of the terminal, but yes, I do agree some of them dont behave as they should and if you have some heatshrink, ditch the barrel piece altogether and just heat shrink it.
Lez.
08-24-2007, 08:49 PM
#7
that is the worst or close to crimping i have ever seen
DONT use side cutters or plyers to crimp, spend (here in nz) $70 for the proper crimp ratchet controlled hand tool
you dont have to remove the sleeve to get solder to flow up the terminal, a good iron with heat will make it flow
i use a ratchet crimp tool for work just about every day cept weekends and never had any problems
08-25-2007, 03:49 AM
#8
Vehicle: XM 2.1 TD
Nice to see for only your third post on here you having a knock noob.....
1) I crimped it with the side cutters I admit, reason, they were to hand, it applies pressure in a thin solid line, just what you want with a crimp, not a broad area that reduces the amount of pressure, like you get with most $5 crimp tools, dont go even thinking of telling people to but $70 tools, its never going to happen among a group of people that are into self build.
I had a guy the other day telling me how good a mechanic he was as all his tools were snapon, makes no difference where the tools come form, its whose hands they are in that makes the difference.
2) its a 5c connector, If you dont move the sleeve up the wire, it melts. Doh!
Lez.
08-25-2007, 10:30 AM
#9
Vehicle: 1998 Jeep Grand Cherokee 5.9L
I agree with DP. Electrical tape is very easy and makes sure it is secure. Solder does not always adhere well and connections can break. Thick layer of electrical tape prevents bendage. Nice job of soldering though.
Don't you need a special heat gun for heatshrink?
Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D T7200 / MB: MSI Fuzzy 945GM2 / SC: E-MU 1212M SC / RAM: Corsair 512MB / HD: Hitachi 7K200 2.5" 100GB / DVD: Panasonic UJ-815B / PSU: Opus 150w / LCD: 7" Xenarc
08-25-2007, 10:58 AM
#10
Vehicle: XM 2.1 TD
yes its 30 years of practice, which is why it does adhere well and does not break!
Once I had to solder some wires into a cabinet, all bared ends were to be 6mm in length and tinned for 4mm, the insulation of the wire must not show signs of heat at the end.
Once all the wires were prepared and passed, they had to be soldered into the board.
I hated those hundreds of wires I had to do...........
Any old heat gun will do, but the original way is to hold the shrink above the soldering iron, because when heatshrink first came out, hot air guns were not around and took some finding.
Of course if you did it that way now, you would get hundreds of posts about how you were doing it wrong........
Lez.
08-25-2007, 11:20 AM
#11
No. Any heat gun will work.
I actually use the heat from the soldering iron tip.
My Worklog
08-25-2007, 11:24 AM
#12
Raw Wave
I do it with the soldering iron. Or I use a match if I am somewhere it is difficult to get power to. I'm going to hell, aren't I?
Personally I do not tin before crimping either, just solder afterwards. I think everyone has their own techniques.
08-25-2007, 12:05 PM
#13
I like the large hammer & concrete floor method myself.
Who needs a crimper.
Though you do have to be careful because if you just hit it at the same angle, it will just bow out and be pretty useless. Then glob the thing with solder, and duct tape or heatshrink around it.
And I actually do have a heatgun used to unwrinkle the skin on my RC plane that gets plenty hot, but I usually use a lighter. I dont smoke at all, but I have accumulated like 50 lighters of various styles from el cheapo gas station lighters to this stainless stell looking lighter. I dont really know how I got them all.
08-25-2007, 08:46 PM
#14
using the right tool always does the job right in the right hands
if you are melting the sleeve then the person is using a soldering iron to hot or not soldering correctly
Alot of people solder by putting the solder onto tip and think it shold flow incorrect, tin tip of gun, the put tip onto the area to be soldered and put solder directly onto work
http://www.ee.ryerson.ca:8080/~jkoch/soldering.html
also you sholdnt twist wiring with your hands if going to solder as oil and fat from your fingers can prevent solder from flowing
the $70 tool here in nz so other places shold be hell of alot cheaper, very handy as they crimp 3 diff sizes, if you dont lose it you will keep it for years
08-26-2007, 09:53 PM
#15
Yes but you also have to do a cost analysis. Same reason why most of us buy our own parts and assemble the PC that way.
If you do like 2-3 connections, that is $70/3 so $23 per connection. Now if you do this alot, then $70/n, gets smaller and smaller as n increases. So if you can use a hammer and a soldering iron to get the same results although it may take more work, or not look as pretty , then why not. If you already have the tools, then use them. Be creative. Tool A can work with Part A, and Tool B can work with Part B, but if you try hard enough you can get a flat head to work in a phillips or square head screw.
| Thread Tools |
| Display Modes |
Linear Mode
