The MP3car.com Store
Thread Tools Display Modes
Old 08-14-2007, 11:47 PM   #1
My Photos: (0)
Jeep Compass Ignition M2-ATX
I took apart the jeep compass HU and got all the wires figured out except the ignition power.
There are 2 + from the battery and 2 grounds, but no + igntion cables. I tested the + with a voltmeter to be sure.
For the M2-atx, how would that work?
--- + battery
--- + ignition
--- ground
and for the amp, would the power remote (12V or something) plug into the m2-atx board? (for that anti-thump)
plunderisley is offline   Reply With Quote
Sponsored Links
Old 08-15-2007, 06:13 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Tap into any line that is switched by the ignition.
Likely sources are the headunit wiring harness and a cigarette lighter (assuming it's only functional when the car is on)
I can't help you with the remote amp wire. It should say something about that in the manual, though.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-15-2007, 07:08 AM   #3
My Photos: (0)
could I safely run the amp, computer and whatever is plugged into the cigarette outlet all on 1 wire from the cigarette outlet?
Old 08-15-2007, 10:27 AM   #4
My Photos: (26)
No.
The cigarette lighter was a suggestion for the ACC line that the M2ATX requires to trigger startup/shutdown of the PC. The M2 simply senses voltage on this line, so the amount of power draw is negligible.
The circuit for a cigarette lighter is not designed to provide current sufficient to power an amplifier or PC.
You're going to want to run a power line directly to the battery to power these. Considering the setup you're looking at, I'd suggest a power line of 4awg (or lower, depending on the anticipated draw) going to a fused distribution block, with thinner wire going to the amplifier(s) and PC.
My setup is similar to this. I have two modest amplifiers and the PC (dead, as of now). One 4awg power line running straight from the battery to a distribution block that handles both power and ground lines.
My Worklog
Old 08-16-2007, 12:33 AM   #5
My Photos: (0)
Err I mistyped it.
Is the cigarette outlet enough for the m2-atx ignition switch? I have a dedicated power running for the battery +. I did get it to run today.
Also I was able to wire up the remote amp switch to the m2-atx remote amp jumper
Old 08-16-2007, 05:20 AM   #6
My Photos: (26)
Quote: Originally Posted by plunderisley View Post
Err I mistyped it.
yes, the cigarette lighter is enough for the ignition switch. IF you have any question, nmeasure the output on it with a multimeter to make sure it goes to +12v with the ignition on and 0v with the ignition off.
The ACC line that is required by shutdown controllers is just used for sensing voltage, nothing more. AS I said, the power draw on that line is negligible.
My Worklog
Old 08-16-2007, 07:14 AM   #7
My Photos: (0)
Good.
Exactly what I wanted to hear.
Now to get some sleep and work on finishing my setup today.
Old 08-17-2007, 08:09 PM   #8
My Photos: (4)
if that jeep compass is anything like my jeep it has one lighter that is always on and one that is only on when the ignition is on. I used this for my turn on lead and it works great. I did not have to go hunting for wires :P
westcoastrocks is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
M2 ATX installation trouble with ignition signal? Snortonnorton Power Supplies 16 07-26-2007 12:55 PM
M2 ATX power supply wiring question... 3 terminals Snortonnorton Power Supplies 5 07-25-2007 07:25 PM
Did I break my M2 ATX? CelicaGTS Power Supplies 8 04-29-2007 04:36 PM
m2 atx with hardoff=never Nerd2 Power Supplies 2 04-10-2007 08:53 AM
Wtb :: M2 Atx Dc/dc Psu !!! CoupeE46 Classified Archive 0 01-28-2007 03:06 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
