Old 09-01-2007, 04:42 PM   #1
Hessian's Avatar
Hessian is an unknown quantity at this point
Opus 120 and Sleep in 2007 Mustang
I have an Opus 120 in my 2007 Mustang. The mb is a VIA CN13000.
I have the power supply hooked up as follows:
Yellow 12v on the power supply to 12v constant yellow from the harness.
Black ground on the power supply to black ground from the harness.
Red 12v on the power supply to red ingnition from the harness.
Ive tried with and without the jumper pin 3 (standby power) on the Opus.
I have Windows XP to go into sleep when power is pressed.
Problem:
The OS sleeps, monitor turns off. After 40 sec or so the Opus shuts off anf I get the 4 blink response from the Opus.
Any ideas?
Hessian is offline   Reply With Quote
Old 09-01-2007, 04:44 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Switch the yellow & red wires from teh opus.
red shoudl be constant 12v and yellow should be switched ignition.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-01-2007, 05:57 PM   #3
Hessian's Avatar
Battery 12V
According to the Opus 120 guide the two yellow wires (4/5) are +Batt and the red wire (3) is On/Off or ACC. Am I not reading that correctly?
Old 09-01-2007, 06:42 PM   #4
Wait a sec. You're saying that the system is turning on as normal and the only issue is with shutdown?
I misread your post then. Sorry about that.
have you contacted Opus Solutions? They're really good about supporting their products.
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
