Old 09-03-2007, 11:40 AM   #1
Mazda6gp is an unknown quantity at this point
Automatic Standby with Ignition
I control the pc to hibernate with the com port (rely), UPS function and the Ignition (ICC).
How will I go about to do the same but only put the pc in standby.
Mazda6gp is offline   Reply With Quote
Old 09-03-2007, 01:14 PM   #2
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
WHat ever you set to make it hibernate, change it to standby. That MIGHT be set in control panel>power options>advanced.
Michael
Wiredwrx is offline   Reply With Quote
Old 09-03-2007, 02:27 PM   #3
I only have Hibernate and Shutdown, e.g. I don't have standby as an option.
Is there a way to insert this option or anther program that can do this in XP?
Old 09-03-2007, 02:54 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
The ability for the PC to standy and/or hibernate is a function of the BIOS.
So...
You would need to set up the option to standby in your BIOS setup.
Unfortunately, this also means that you will have to reinstall WInXP to load whatever components are required for standby, as WinXP only loads these upon installation, as far as I know.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-03-2007, 03:45 PM   #5
I can enter standby when I set it up to go in standby with the power button.
I can build a controler to hit the power button on Icc on and off, but I first want to know if I can do it with software.
Old 09-05-2007, 04:37 PM   #6
ankitgoenka is an unknown quantity at this point
anyone who figures this out - schamatics please!
::CONFIG::
Pentium 3 @ 950Mhz
Intel 815 MOBO
256MB RAM
80GB HardDrive
DVDROM
ATI Radeon 9200
ATI Remote Wonder
235 ATX SMPS
500VA UPS
300W DC to AC Inverter
::FRONTEND:: I need suggestions please
::OPERATING SYSTEM:: TinyXP
ankitgoenka is offline   Reply With Quote
Old 09-06-2007, 02:21 PM   #7
This is the controller I use. There is a delay on and off when switching the Ignition. The second part pulse the computer's on / off switch for about a second.
Old 09-06-2007, 02:26 PM   #8
thanks...
please give part list also
::CONFIG::
Pentium 3 @ 950Mhz
Intel 815 MOBO
256MB RAM
80GB HardDrive
DVDROM
ATI Radeon 9200
ATI Remote Wonder
235 ATX SMPS
500VA UPS
Old 09-06-2007, 02:55 PM   #9
2 x relays look at the relay contacts
2 x 1000uF caps they operate the second relay
1 x 10 k resistor
1 x 100uF cap
1 x BC107 NPN transistor
The switch is the ignition (ICC)
My way of putting the computer in standby.
I use a 7805 regulator to keep 5 volt on the memory when I put the computer in standby mode.(on the power plug)
I use anther relay to switch the inverter off once the computer is in standby mode.
Old 09-07-2007, 12:40 PM   #10
Arrow
Have u actually implemented this circuit - and is it working for certain. Kindly confirm.
Also considering u have knowledge on circuitry - kindly let me know the spec's of a DIODE that I should use for a TankCircuit. the ones mentioned on the forum are not available.
I am using the following setup:
DC to AC inverter - SMPS powering the Computer
now when i crank the car the inverter goes through a power surge and the Carputer reboots!
::CONFIG::
Pentium 3 @ 950Mhz
Intel 815 MOBO
256MB RAM
80GB HardDrive
DVDROM
ATI Radeon 9200
ATI Remote Wonder
235 ATX SMPS
500VA UPS
Old 09-07-2007, 01:59 PM   #11
The circuit work. I am currently using it.
I use an inverter to the standard computer power supply.
I use a relay to keep the inverter on until the computer switch off. This relay gets powered from the computer power supply.
I use a second relay to switch between the main battery and the tank battery when I start the car. This relay gets powered from the wire going to the starter.
I am using a 2A diode between the main and tank battery.
Make sure that the tank battery is fully charged
Old 09-08-2007, 01:04 PM   #12
Thank you very much...ur very kind...I would request you to take the trouble of kindly giving schamatics of the crank proofing circuit with specs of relays and battery used...I have a 12V 7.5Ah battery
::CONFIG::
Pentium 3 @ 950Mhz
Intel 815 MOBO
256MB RAM
80GB HardDrive
DVDROM
ATI Radeon 9200
ATI Remote Wonder
235 ATX SMPS
500VA UPS
Old 09-08-2007, 01:34 PM   #13
Search for this subject
Tank Circuit FAQ - Computers and Power cutting out
and use this link
http://www.mp3car.com/vbulletin/power-supplies/20359-battery-based-tank-circuit-tested.html
DSATX and Standby HyperZulu Power Supplies 3 06-14-2007 05:33 PM
Standby issue - goes into standby and comes right back out ckny General MP3Car Discussion 7 03-25-2007 08:10 PM
XP-Mini Automatic Standby and WakeUp Help stevemahon StreetDeck 8 01-26-2007 10:11 AM
Opus 150 -Ignition failed PORTUGAL Power Supplies 18 08-29-2005 12:03 PM
Standby issues. Seriously confused here. maxxell General Hardware Discussion 11 04-16-2005 02:26 AM
