M2-ATX Ignition Current Pull?
I think I should be ok but if someone could agree with me, it would make me feel a lot better about doing this...
I have the PC in the back with power running from a distro block to an M2-ATX which is in the trunk. Ignition power comes from a switched 12V circuit in the back as well.
I would like to install a 12V 3-way rocker switch near the driver seat to switch the Ignition line from "Switched 12V" to "Constant 12V" So I can get in and out of the car quickly and leave the PC on with the car off.
What I am curious about is, how much current does the Ignition lead pull? I'd imagine its not much but I want to make sure it would be safe to run the ignition cable from the front of the car to the back on (say 16 gauge wire) and into the ignition lead on the M2.
I looked through the M2-ATX Manual but did not see anything in regards to that...
