Old 09-22-2007, 09:51 AM   #1
Any DC-DC psus support ATX 2.2/24-pin ATX
Greetings all. I just bought a Biostar NF61S Micro. So far, it's looking like a bad-*ss motherboard with a nice Sempron mobile 3000+ on it. However, I have been having problems with it where when I go to shut it down, the instant it's supposed to turn off, it restarts instead. I'm using an older 20 pin psu. I hooked the mobo up to my 24 pin ATX 2.2 powr supply in my main computer, and it seems to shut down perfectly. So, I am concluding that it needs the additional 4 pins to maintain proper shutdown operation (?). Do any of the DC-DC power supplies support the 24 pin connector? Or, if none do, does anyone know what kind of additional load on the power supply this would cause if I used a 20 to 24 pin adapter? I'm not using the PCIe slot, which is what I thought the extra 4 pins were for, but I'm guessing Biostar tapped off of it for something. This mobo also needs the P4 connector.
Crawdaddy is offline   Reply With Quote
Old 09-22-2007, 09:15 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
There are 20-pin to 24-pin adapters available.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 93 08-11-2008 09:40 PM
Tech Support Calls Rafster Off Topic 8 06-12-2006 11:49 AM
atx dc dc tre General Hardware Discussion 1 12-17-2000 07:24 PM
AT and ATX pin assignments drew General Hardware Discussion 1 11-22-1999 08:47 PM
dc to dc ATX power supply Kaizer Soze General Hardware Discussion 10 10-21-1999 07:47 PM
