DS-ATX issue
When the red light turns on, shouldn't at least the fan for the power supply turn on? Everything looks like its working except that the power supply isn't providing any power. I have over 13.3 volts on the VIN line and the ACC line is high. I still need to verify if the polarity is correct but if that was the problem then I expect that the power supply fan should at least turn on.
[EDIT] Good news, looks like the computer turns on if I manually turn it on. So I suppose I need to build the reverse polarity switch. [/EDIT]
