Quote: Originally Posted by
roundeye
The computer and power supply are being bench tested and I have not installed them in my car yet.
Smart move.
Quote:
I have powered up the computer numerous times with a standard computer power supply.
It's so much easier like that, isn't it? Mine's presently on the bench, as well.
Quote:
After hooking up the psu to a car battery and re checking everything (battery voltage, all connections including wire gauge)the computer will not turn on. There is no indication what so ever that the computer is receiving power. The Opus psu will flash the green light twice.
According to the manual it can mean one of 4 things
-the polarity of the 2 wire power switch connector from J9 to the ATX mother board is incorrect.
-the atx mother board bios settings are incorrect
-locked up mother board or soft ware crash
-Faulty DC-DC power supply
What are the PC specs?
Quote:
The only other issue that I have had is an alarming noise from the power supply that sounds like screech. this starts after about 10 seconds and does not subside. I believe that the sound emanates from small grey box about 20mm in length and width and 5mm high labeled 4R7 0637 which I believe is an output transistor. It also gets extremely hot to touch.
Don't know what to say about this, other than it certainly doesn't sound good.
Quote:
any suggestions would be appreciated.
YEah. Get in touch with Opus POst your PC specs.
Quote:
I have called opus numerous times and have been stuck on hold. I have left messages and received no response back. I am really frustrated and wish that I had bought a different power supply.
Be persistent. OPus is a great company, and there are a large number of members here who have praised their tech support.
Who am I likely to have a quicker replacement with mp3 or Opus?[/quote]
